This thread is privately moderated by Dan Elliott, who may elect to delete unwanted replies.
Old Nov 26, 2011, 12:44 PM
Dan Elliott is offline
Find More Posts by Dan Elliott
Dan Elliott
United States, TN, Nashville
Joined Jul 2011
Quill Wingsail Skinned, servo camber control
I have finally finished the Quill wingsail with camber control servo. Next I'll test it out before the lake gets to cold.
Dan Elliott is offline Find More Posts by Dan Elliott
Old Dec 04, 2011, 10:11 AM
Jim Ryan is offline
Find More Posts by Jim Ryan
Jim Ryan's Avatar
Cincinnati, OH USA
Joined Oct 2000
Wingsail Gyro Stabilization
Hello Dan,
Very interesting reads on your wingsail projects. I didn't read every single posting on the other thread, so please forgive me if this has been discussed already.
You said in the previous thread that your wingsail catamarans are very skittish because you're running without ballast (as a cat shold be sailed). This of course is just as one would expect; at model scales things move too quickly for the pilot to react.
Have you considered installing a helicopter-type heading hold gyro on the servo that controls angle of attack of the wingsail? With a heading hold gyro the boat could make instantaneous adjustments in wing pitch, thereby largely (if not entirely) eliminating capsizing.
Jim
Jim Ryan is offline Find More Posts by Jim Ryan
Old Dec 06, 2011, 03:01 PM
Dan Elliott
Joined Jul 2011
Jim, That sounds very interesting. Question, Does using a "heading hold gyro" with a servo do away with the need for a channel on your radio contoller? One of the problems I have is most "Surface" controllers for boats only have 2 channels. I've resorted to using two radio control units for the catamaran, one for rudders and winch, and the other for the camber servo.
Old Dec 07, 2011, 03:16 AM
Jim Ryan is offline
Jim Ryan's Avatar
Cincinnati, OH USA
Joined Oct 2000
A heading hold gyro would plug in line between the receiver and the servo that controls angle of attack on the wingsail, so in that sense it doesn't require any extra channels. However, that said, it's best to set up the gyro with separate gain control so that you can dial down the gain (to keep the gyro from being too hyperactive). That requires a second channel.
Because so many guys in the heli world are converting to flybarless control systems, you can find heading hold gyros at very reasonable prices on the Heli FS/W forum. You can expect to pay around $60 shipped.
Examples of reputable gyros that you can find in this price range would include Futaba GY401 and Align GP750. I have lots of experience with both these. I personally don't bother with the really cheap gyros, although some swear by them. Note that some gyros (like the GP750) REQUIRE a digital servo; these will burn up a regular analog servo. The GY401 on the other hand can work with either digital or analog servos.
As for channel availability, back in my RC sailing days I used an aircraft-style transmitter. The stick for rudder control worked fine because it was like a tiller. Naturally if you're on FM, you'd want to get a module-style Tx and swap the 72 MHz Rf module for a surface unit.
I'll be glad to discuss this in more detail if you're interested.
Jim
Old Dec 07, 2011, 11:27 AM
Dan Elliott
Joined Jul 2011
Yes, I would be very interested. I wonder if you could suggest a transmitter that could be adapted to control tandem rudder servos, mainsail & jib winch, wing camber servo, and gennicker winch? I'm trying to incorporate all the sailing functions of the AC45's into my model. I've even considered making it a two man job, one controlling the mainsail winch and steering, while the other controls wing camber and deployment of the gennicker. It may be a bit ambitious but I'd like to do it all from on transmitter.
Old Dec 07, 2011, 02:54 PM
Jim Ryan is offline
Jim Ryan's Avatar
Cincinnati, OH USA
Joined Oct 2000
Dan, I can quickly get out of my depth here since I don't do model yachting, but it sounds as though you'd need 6 channels, but I'd aim for an 8 or 9 channel radio so that you have have the TYPE of control you want.
For instance, tiller could be on the left stick (Mode 2), but winches you might want to control with a three position toggle switch - center off, down reeling in and up playing out on the sheets. Gyro gain takes a two-position toggle switch - up for heading hold and down for rate.
Here's another approach: You could have wingsail control on the right stick. Up and down could control camber, and left and right could control angle of attack.
I'm sort of thinking out loud here, but these are some of the options.
Are you running 75 MHz or 2.4 GHz? The latter would allow you to use an airplane radio with no mods.
Jim
Old Dec 07, 2011, 03:24 PM
Dan Elliott
Joined Jul 2011
I am currently using a Spektrum DX 2.0, 2-Channel 2.4GHz DSM Radio System. I really like your idea of using the Right stick flight controls to control the Wing's reach and camber. Using a three position toggle switch to deploy the ginnicker could also work. And, Left stick could control the rudders. All great ideas Jim. I'm starting to see how one might use a airplane radio to control the Cat just like a plane. I've already created plans/templates for a new longer set of hulls, and a slightly shorter Wing in anticipation of a need for more room for extra winch and servo (more wieght) but first I'll use the set I have to test theory.
Old Feb 07, 2012, 01:26 PM
compositeyacht is offline
Find More Posts by compositeyacht
Joined Feb 2012
Wingcat
Dan
I have been searching the internet for a way to build a RC AC 45. I would like to ask you about your hulls. please email me at patrick@compositeyacht.biz
Patrick Edwards
compositeyacht is offline Find More Posts by compositeyacht
Old Feb 21, 2012, 02:08 PM
Dr Sails is offline
Find More Posts by Dr Sails
Joined Feb 2012
Sail project
Dear Elliot,
I am an engineering student from Barcelona. I am doing a project about building a sail boat with a rigid wing sail, and I will be thankful if you could help me answering the following questions.
- Which materials have you used to build the strucure of he wing sail?
- Which wing sail perfil have you used?
-How have you build the structure?
-Could you explain us the mecanism to move the wing sail?
Thank you for your time and I am looking forward to hearing from you,
Dr SAILS
Dr Sails is offline Find More Posts by Dr Sails
Old Feb 22, 2012, 08:19 AM
Dan Elliott
Joined Jul 2011
Check out my thread on this website. Boats; Sailboats; Wingsail Catamaran. In this thread I have plans and photos of the Wingsail construction. If you e-mail me at; delliott@1220.com I can send you a AutoCad model. Happy to help. Hope to hear from you soon.
Discussion Pitcheron wing camber control mr_editor Slope 4 May 31, 2011 01:51 PM
Optic 6 camber control Trace Lewis Hitec/Multiplex USA 4 Jan 17, 2005 12:29 PM
Setting up full-span camber control on Sky Sergio w/Eclipse 7 radio jshelton Electric Sailplanes 16 Apr 20, 2004 08:32 PM
Yippee! new airfoils, camber control Mike Waters Hand Launch 24 Jul 12, 2003 06:50 PM
