Old Dec 13, 2012, 07:13 PM
ParkScaleModels
zbrubaker's Avatar
United States, PA, Loganville
Joined Feb 2002
It's now up on the site:
http://www.parkscalemodels.com/shop/item.aspx?itemid=79
zbrubaker is offline Find More Posts by zbrubaker
Old Dec 14, 2012, 02:22 AM
Build a Model!
United States, CT
Joined Aug 2003
BTW, the 32 ounce weight Zeke lists should be very doable. I think Mike's prototype was right at 30 ounces with a 2100mAh pack. During testing I also flew it with packs as small as 1250 without CG issues.
Thayer is offline Find More Posts by Thayer
Old Dec 14, 2012, 05:05 AM
Airplane crasher
CapMike's Avatar
USA, CT, Shelton
We concure with Thayer and the 32 ounce would be the upper weight with retractable landing gear.
The prototype was built with some very heavy hard wood. I also ended up using some MonoKote on the prototype.
CapMike is offline Find More Posts by CapMike
Old Dec 14, 2012, 09:16 AM
Wanted for breaking OHM's law
Dennis Sumner's Avatar
United States, MI
Joined Sep 2002
Santa ordered one for me this morning....
I guess I've been a good boy.
Denny
Dennis Sumner is offline Find More Posts by Dennis Sumner
Old Dec 14, 2012, 10:57 AM
Airplane crasher
CapMike's Avatar
USA, CT, Shelton
Denny
thank you for your order Denny. I know you will enjoy it as much as we have
Old Dec 14, 2012, 06:55 PM
United States, MI
Joined Sep 2002
Originally Posted by zbrubaker View Post
Hi Zeke,
I ordered one this morning and no rush but the assembly instructions link is not working. I probably don't need instructions until Santa delivers mine.....
Denny
Old Dec 14, 2012, 07:17 PM
Airplane crasher
CapMike's Avatar
USA, CT, Shelton
Hi Zeke,
Denny
Denny the instructions manual should be online next week. We have most of it completed and just have a few more things to complete. Are you going to do the landing gear option?
Old Dec 15, 2012, 06:41 AM
United States, MI
Joined Sep 2002
Mike,
I am not sure if I will go with the landing gear or not. I saw the pictures earlier in the thread. I guess I would like to have the gear as most my flying is from grass. What size servos did you use, 9gr ?
What kind if watt/pound numbers are you seeing with the 450 with 890kv? I am looking at a couple of 450 motors from Heads up, one is. 880kv and the other is 1100kv. I am kinda leaning towards the 110kv. With. 9x6 they are saying 18a which would give about 188 watts.
I am not in a hurry as I have another project on the bench right now.
Denny
Old Dec 15, 2012, 08:57 AM
Airplane crasher
CapMike's Avatar
USA, CT, Shelton
Mike,
Denny
Denny
I used some 9g servo's I salvaged from a foamy china kit as this was the prototype. For the LG if you do retractable your going to need something like the Hextronic MG-14 found here http://www.hobbyking.com/hobbyking/s...idProduct=8303
As far as the prototype we were flying on I think 176 watts. I believe the 1100kv that your looking at should be just fine.
Old Dec 16, 2012, 02:20 AM
Build a Model!
United States, CT
Joined Aug 2003
I measured the power at under 150 watts, actually. 1100Kv will be great as long as it can also handle the 15-20 amps.
Old Dec 16, 2012, 07:56 AM
United States, MI
Joined Sep 2002
Hi Thayer,
I am looking at a couple of 450 motors from Heads Up RC and both are rated at 20-22 amps.
I have a Polaris that flies great but always like the look of scale or sport scale models. I had planned in building Ken Willard's Drake but the Kingfisher fills the need nicely (plus it's all laser cut),
Nice talking with you on RC Groups, we met last year at the Toledo Show.
Denny
Old Dec 16, 2012, 01:48 PM
Build a Model!
United States, CT
Joined Aug 2003
Denny,
Those should be more than fine. I've wanted to do another large Drake for quite a while and to make it look a little more like a scale model. Have long considered retracts for it as well. Would be nice to be able to taxi out on the beach.
Thayer
Old Dec 17, 2012, 10:14 AM
Always Ready!
warhead_71's Avatar
Chicago, IL
Joined Dec 2006
http://www.rcgroups.com/forums/showp...&postcount=138
^ Here's how I envisioned adding landing gear for a Drake. It's not very aerodynamic, but it get the wheels up out of the water for taxiing. There would need to be some stop-blocks that take the load off the servo when the wheels are deployed.
Oops - original thread is here:
http://www.rcgroups.com/forums/showt...00#post8507202
warhead_71 is offline Find More Posts by warhead_71
Old Dec 17, 2012, 10:26 AM
Airplane crasher
CapMike's Avatar
USA, CT, Shelton
In a few posts back you can see how we had designed for the Gear to function. It will need rubber wire grommets to seal the tube in the fuse. A torque tube transfers from one side to the other. With the use of 1/2A steering blocks it would make it easier to plug gear in, tighten the set screws and go. In the down position there will need to be a stop block that it comes against to take impact off of the servo. I need to finish with the prototype work on the other gear in order to show how it can be done.
Old Dec 17, 2012, 12:14 PM
Build a Model!
United States, CT
Joined Aug 2003
Warhead,
Interesting to see our 5 year old discussion come round again. I agree, it should be pretty easy to do. I've seen Mike's design up close and that looks viable as well.
Sold Vintage Champion Models Anderson Kingfisher! spitfire1999 Aircraft - Fuel - Airplanes (FS/W) 1 Aug 12, 2011 11:44 AM
Anderson Kingfisher AUSELECTRIC Waterplanes 14 Dec 22, 2009 04:21 AM
Spruce Goose and Anderson Kingfisher Videos Martin Lagerstedt Waterplanes 3 Nov 05, 2007 04:02 AM
Anderson Kingfisher stickerman Waterplanes 5 Feb 14, 2005 09:44 PM
Einar Johnsson SAAB VIGGEN 1/8th and 1/9th scale Sluf7 Electric Ducted Fan Jet Talk 1 Jul 12, 2004 05:38 AM
