Old Sep 29, 2003, 11:25 AM
MattLarson29 is online now
Find More Posts by MattLarson29
Endangered User
MattLarson29's Avatar
United States, FL, Casselberry
Joined Jul 2002
Originally posted by msweiss
I can't believe how much press this has gotten in such a short time. This is Mike Weiss, the friend that got to the fire first. I wanted to comment on the fire extinguisher discussion. My fire extinguisher is perfectly suited for kerosine fires, but did almost nothing to put out the Li-Poly's. I definitely plan to keep a more appropriate extinguisher handy in the future!
Mike:
It might help to know what type of extinguisher and the size that were involved.
Matt
MattLarson29 is online now Find More Posts by MattLarson29
Old Sep 29, 2003, 12:31 PM
LJE4357 is offline
Find More Posts by LJE4357
Closed Account
Joined Jun 2002
Charger failure
it sounds like the charger failed in an open control loop condition. That would be what explains the higher current (8 amps)
LJE4357 is offline Find More Posts by LJE4357
Old Sep 29, 2003, 12:48 PM
luc is offline
luc
Find More Posts by luc
luc
I plant balsa sticks too
luc's Avatar
France
Joined Feb 2000
Yep, and the current draw was above the limit mentioned by the manufacturer (275W), so it took fire....
conclusion (for me): better not be close to the limit on a charger
luc is offline Find More Posts by luc
Old Sep 29, 2003, 03:16 PM
Ade is offline
Ade
Find More Posts by Ade
Ade
Instructor
Ade's Avatar
Bournemouth UK
Joined Aug 2002
Ok there could be 2 causes I see here...
first is a battery failure of some sort, heat built up, afaik they run away when they get to a certain temperature. Once it hit this temperature doesn't matter what you do they are going to burn.
the second is a charger failure charges pack too much heat builds up same thing happens.
So what can we do? What about a thermister/thermocouple that is part of a pack. This would get connected to the charger and esc. So when the pack gets to X temperature a louder buzzer goes off on the charger, charger quits charge and you know to move the battery to somewhere safe.
Similar thing goes for in the air except that the power output gets reduced to 50%.
Leasons I learned from this;
remove pack from model,
use reasonable lenght charge leads to pack from charger.
place in the open away from flamable things.
Ade
Ade is offline Find More Posts by Ade
Old Sep 29, 2003, 04:27 PM
Morphisnb is offline
Find More Posts by Morphisnb
GBZealous
Morphisnb's Avatar
Western Mass
Joined Jul 2002
Jim,
Do you have pictures of how you tapped your cells?
<--- needs good visuals.
Noah
Morphisnb is offline Find More Posts by Morphisnb
Old Sep 29, 2003, 04:45 PM
jnowell is offline
Find More Posts by jnowell
jnowell's Avatar
United States, FL, St Petersburg
Joined Sep 2000
I'm so glad this didn't turn into another "run away from the evil LiPoly's" thread. I use Lipoly's for almost everything, and have never had one catch fire, I use a Hobbico MK-II Pro ($50) charger also. This charger cuts off at 4.1 volts per cell, fine by me in light of recent events.
The one thing I think should be noted is this; LiPolys can FLY when they burn. I was standing 15 feet from a van with a 4S3P TP pack charging in the back. The pack went up and shot out of the van like a rocket, landing at my feet! It was a real eye opener for me to say the least. I still have all of my Kokams, E-Tecs, and TP's, but I treat them with a little more respect now
There were 3 confirmed LiPoly fires at NEAT this year, one in a RoadKill B-17 in a motel room I think (airplane, pack, and charger all burned). He had the charger set to 3 cells on a two cell pack, this was no amateur either, just a simple oversight. Another pack had been in a crash, with no physical damage noted, but went up in the airplane on the next charge. The other landed at my feet as detailed above.
After seeing them burn first hand, used by guys like Gary who KNOW what they are doing, I'm a little more cautious with mine, and you should be as well.
Was that a whole 2 cents worth, or do I get change?
Jason
jnowell is offline Find More Posts by jnowell
Old Sep 29, 2003, 05:01 PM
kmashima is offline
Find More Posts by kmashima
kmashima's Avatar
San Jose, California, United States
Joined Feb 2002
Gary
really sorry about your loss. That was also one of my favorite planes.
People have made a lot of good suggestions. I would like to add 2:
1. Charge the packs separately. I'm sure that was two - 5s4p packs not one 10s4p. It reduces the cell imbalance problem a bit and probably makes it easier for the charger to sense the voltage properly. 2 Astro Lithium chargers are cheaper than one big Orbit or Schulze 8mp charger.
2. Use a fan on the system. My Orbit gets pretty warm. The small Schulze 330 gets HOT. And if it's a hot day, things only get worse. Semiconductors will fail in high heat at some point.
-- Kyle
kmashima is offline Find More Posts by kmashima
Old Sep 29, 2003, 08:15 PM
RD Blakeslee is offline
Find More Posts by RD Blakeslee
Joined Jan 2002
"...He had the charger set to 3 cells on a two cell pack, this was no amateur either, just a simple oversight..."
I'd like to see a lipoly- dedicated, 4-port charger, each port set permanently at single cell voltage, amperage variable up to 10 amps or so.
Packs set up to charge individual cells and/or parallel arrays, discharged in series.
- RD
RD Blakeslee is offline Find More Posts by RD Blakeslee
Old Sep 29, 2003, 08:16 PM
Dave Hederich is offline
Find More Posts by Dave Hederich
Walled Lake, MI, USA
Joined Feb 2000
>> Since this technology is new, most of the people who are using Lithium cells are not really aware of the risks like we are with the other things that are dangerous that we use every day and have been for years.
Very true. That's why it's important to get the word out. I hope we will soon be seeing articles in the various flight magazines. But it's impossible to reach everyone.
Sam, just wondering if clay kitty litter would work as well as sand? You can buy it in any crocery story fairly cheap. Interesting, isn't it, that the highest technology cells may be best extinguished with the lowest tech method.
Dave Hederich is offline Find More Posts by Dave Hederich
Old Sep 29, 2003, 09:50 PM
Jim13704 is offline
Find More Posts by Jim13704
Montrose, CO
Joined Jul 2003
Originally posted by Jim McPherson
As a side note: A simple precaution to solve the cell imbalance problem is to have taps on each cell. Every LiPo pack I build has small very thin gauge wire attached to specific points in the pack. These wires have very small insulated connectors on the end that allows me to charge each cell individually. Every month or so I charge each cell to 4.2 volts exactly regaurdless of what its voltage is. I think this method will solve alot of problems. That's not to say this fire was due to imbalance, it may not have been. But it certainly appears that way.
-Jim
I agree that taps are an important and practical precaution. To the best of my knowledge, however, very few commerical suppliers include taps in their packs. Radical RC is the only supplier of Lipo packs that includes taps that I know of. Would seem that the other vendors are, in effect, contributing to the problem by not doing so. Should not there be some type of industry standard for commerically-provided packs that would at least make it practical for users to routinely check for pack imbalance? Would welcome comments from any lipo pack vendors on this point.
Jim13704 is offline Find More Posts by Jim13704
Old Sep 29, 2003, 10:01 PM
Jim McPherson is offline
Find More Posts by Jim McPherson
Just an average RC'er
Jim McPherson's Avatar
Laurel, Maryland USA
Joined Aug 2000
Noah: I don't have any pictures right now but I'll get some. That's really the subject for another thread. I'll start one when I get some pics of the very very simple taps.
-Jim
Jim McPherson is offline Find More Posts by Jim McPherson
Old Sep 30, 2003, 04:46 AM
Azarr is offline
Find More Posts by Azarr
RIP Azarr - "Old age is not for sissies"
Azarr's Avatar
Dayton Intl, Ohio, United States
Joined Jan 2000
Unfortunately at NEAT I didn't have time to talk to Fred Marks, but I understand that he was suggesting that the LiPoly's be charged in a pyrex type container or on a slab with a small tripod and a bag of sand suspended over it. If the pack catches on fire, it burns through the bag and dumps the sand.
Something to think about.
Azarr
www.ecubedrc.com
Azarr is offline Find More Posts by Azarr
Old Sep 30, 2003, 08:17 AM
Megowcoupe is offline
Find More Posts by Megowcoupe
Balsa Flies Better!
Stamford, CT
Joined Oct 2000
Dave
I don't remember what they use in kitty litter, but I doubt it will burn. Just about any type of inorganic dirt should work fine.
It'd be nice if we could get somebody with a slightly dead pack to overcharge it, with a bucket of sand handy and a video cam, just to give a demo on how to put out these fires- or a mfg.
Sam
Megowcoupe is offline Find More Posts by Megowcoupe
Old Sep 30, 2003, 08:24 AM
Magne is offline
Find More Posts by Magne
Moss, Norway
Joined Jul 2003
Hello.
I have been reading this thread with great interest, because I have just started to use Li-poly batteries. (So far I have only got a couple of 3S1P E-tec 1200's, but with more and bigger things to come.) I have been charging inside the house, with the batteries laying on a fireproof surface (glass chopping board)
I just fitted a smoke alarm in my workshop, have always been in the house while charging, but must admit to not always being in the actual room all the time.
Never thought about the charger itself though, that has been sitting on the wooden desktop.
Anyway, basically there are three components that are required for any type of fire:
Fuel, heat, oxygen. Remove any one of these, and there will not be a fire. (Principle behind CO2/foam extinguishers/sand is to remove oxygen, water based extinguishers remove heat.)
In the UK, where I lived some years ago (I now live in Norway) it is quite common to have a "fire blanket" in the kitchen, to extinguish fires in chip-pans. Simply place the blanket over the burning chip-pan, and the fire will go out due to lack of oxygen.
Can not this principle simply be used in our case, by wrapping the entire battery pack in a fire blanket before charging? (The blanket can be the size of a regular hand towel.)
I do not know enough about the topic, but is anything leaking out of the batteries during combustion?
My 1200 E-Tecs do not get hot during charging, so hopefully this is not a problem?
Alternatively an air tight box (with terminal conections?) could be used, as suggested by Azarr in post No. 72. Any fire would quickly die out. This is of course provided that oxygen is not released from the battery itself during combustion. (Who guessed that I am not a chemist. ;-)
Of course, it is best not to have a fire in the first place.
Magne
Magne is offline Find More Posts by Magne
Old Sep 30, 2003, 08:37 AM
Balsa Flies Better!
Stamford, CT
Joined Oct 2000
I'll stick with my recommendation of sand over a fire blanket.
1) Fire blankets work well on burning liquids since they cut out O2 well and can conform to the surface.
2) I don't know what fire blankets are made of, but I'd be worried that the battery fire can chew threw it.
3) The blanket will not conform well to the shape of a lithium cell, especially in an airplane. (sand conforms very well.) This means that the battery will continue to burn. Clearly- burning batteries can generate forces similar to exploding fireworks. Putting out the fire quickly minimizes the chance for this force to propel a burning battery someplace else.
We're all guessing here- including me. When is a mfg going to step up to the plate and run some controlled experiments?
Sam
LiPo Fire Pictures ken_keeler Batteries and Chargers 135 Oct 12, 2006 11:45 AM
Another LiPo fire.. davensocal Batteries and Chargers 98 Apr 20, 2004 11:42 AM
Another Lipo Fire -- Etech cells Pat Daily Batteries and Chargers 39 Mar 15, 2004 07:41 PM
Lipo fire........cell imbalance? AussieParkflyer Batteries and Chargers 28 Feb 01, 2004 08:00 PM
LiPo Fire Extinguisher Patrick in WI Batteries and Chargers 5 Jan 12, 2004 10:34 PM
