Old Sep 28, 2003, 09:05 AM
Dave Hederich is offline
Find More Posts by Dave Hederich
Walled Lake, MI, USA
Joined Feb 2000
Matt, I don't think we should get hung up on any single part of the issue. But I do think that every part of the issue should be fully understood by as many people as possible. I suspect that there are probably many people here who've never owned a fire extinguisher, let alone used one. If it takes a lot of spraying to put out a fire, this is just another piece of data that everyone needs to fully comprehend.
Dave Hederich is offline Find More Posts by Dave Hederich
Old Sep 28, 2003, 09:12 AM
MattLarson29 is offline
Find More Posts by MattLarson29
Endangered User
MattLarson29's Avatar
United States, FL, Casselberry
Joined Jul 2002
A good rule of thumb for a Dry Chemical extinguisher is this: Once you spray it at all, it has to be recharged, so you might as well use it all.
Matt
MattLarson29 is offline Find More Posts by MattLarson29
Old Sep 28, 2003, 09:57 AM
Kevin Murray is offline
Find More Posts by Kevin Murray
Kevin Murray's Avatar
USA, NC, Greenville
Joined Dec 1999
Sorry to read this sad story. I too Am glad no one was hurt.
It would be a benifit to us all if the actual cause could be found.
Is the 626 rated for 320 watts output ?
Sorry for your loss Gary.
Kevin Murray is offline Find More Posts by Kevin Murray
Old Sep 28, 2003, 10:06 AM
luc is offline
luc
Find More Posts by luc
luc
I plant balsa sticks too
luc's Avatar
France
Joined Feb 2000
according to Schulze site, the max output is 275W...which comforts me in my previous email: stay far from the limit and you will be safe(r).
luc is offline Find More Posts by luc
Old Sep 28, 2003, 10:56 AM
USA, NC, Greenville
Joined Dec 1999
I'm supprised the maximum output wattage is not software linited on the Schulze charger. It is on my old Orbit Pro. You can select 8 amps into a 32 cell pack but it won't give it to you and it won't fry trying.
Old Sep 28, 2003, 12:07 PM
Daren is offline
Find More Posts by Daren
Daren's Avatar
Los Alamos, NM, USofA
Joined Nov 2000
Originally posted by MattLarson29
On a related note, the extinguisher pictured is suitable only for class A fires. A turbine model has a whole lot of flammable liquids in it, and using water is an invitation to spread the fire. Since almost all flammable liquids float on water, they will just run off downhill, happily burning atop their cushion of water.
Matt,
The Indian Fire Pump is kept on hand to put out the reciprocal fire that the crashed turbine may cause; grass and brush, not the kerosene fuel or lubricating oil.
Daren
Daren is offline Find More Posts by Daren
Old Sep 28, 2003, 03:11 PM
m4tm is offline
Find More Posts by m4tm
Little Bo's Lab
m4tm's Avatar
Dayton, Ohio
Joined Apr 2002
Class D Fire Extinguisher
See this site about metal fires...
http://www.ilpi.com/safety/extinguishers.html
You may need a Class D extinguisher???
m4tm is offline Find More Posts by m4tm
Old Sep 28, 2003, 03:27 PM
Heather is offline
Find More Posts by Heather
Hastings, Hawkes Bay, New Zealand (Aotearoa)
Joined Feb 2000
If the charger failed due to overloading of it DC-DC step up convertor I would expect the output voltage to drop, not go even higher.
Heather
Heather is offline Find More Posts by Heather
Old Sep 28, 2003, 03:36 PM
Mikey-flies is offline
Find More Posts by Mikey-flies
Alberta, Canada
Joined Sep 2001
How long ago was the balance of the pack checked? It seems to me that a 10S pack has a LOT of imbalance possibilities. Even with the charger set right it would still cause a fire if the cells were out of balance very much and 10S means it could be a big overvoltage on one of the cells.
The fact that the first started towards the end of the charging cycle really indicates to me that one or more of the cells was overcharged at the end probably due to cell imbalance in the pack but that will likely be impossible to determine.
Mikey-flies is offline Find More Posts by Mikey-flies
Old Sep 28, 2003, 03:52 PM
AIR MOVER is offline
Find More Posts by AIR MOVER
Master of the Wind
AIR MOVER's Avatar
TEXAS
Joined Jun 2001
I know those with lipo cells enjoy the benifits..of them and are trying to make it safe to use them.. the cells are pushed harder in chargeing and in usage then what they should be.. Now if these cells crap out on you while your child is near by gets flamed and burned or dies or the dog gets it.... and the loss of your home .. and then the wife leaves ya .. was it worth useing them.. ? who thinks lipo's are worth it? who puts faith in the hands of your chargeing and useage and the quality of the charger and lith cells? The bigger these cells are the bigger the bang .. the farther the flames shoot out .... you get the picture.. shame but these cells have caused more trouble in the last few years then nicads or nmh cells did when they first come out..
AIR MOVER is offline Find More Posts by AIR MOVER
Old Sep 28, 2003, 03:57 PM
USA, NC, Greenville
Joined Dec 1999
I may re-think the Astro Flight dedicated LiPO charger and just spring for a lab grade CV/CC power supply. LiPo's are here to stay.
Old Sep 28, 2003, 06:40 PM
BEC is offline
BEC
Find More Posts by BEC
BEC
BEC's Avatar
Auburn, Washington USA
Joined Jan 2001
Bernard, supply is 115AH deep cycle marine battery.
Thanks, Gary. If that is your usual supply for the charger, that pretty much removes the line of thought I was wondering about.
"... It will take rather more info to sort this one all the way out..."
BEC, we may never know.
Agreed. After all, we don't have the resources of the NTSB or anyone like that.
I'm not an EE - but that sounds logical. I suppose it would depend on what the un-regulated output of the step-up converter is - what you get if there's no software control of it.
This sounds plausible as well..... though I've never had a pack this large and when I've checked my packs they've all been in balance within 0.01V on each cell.
In fact I just checked my two most-used packs (two 3s ETec 1200s) and they are, as I expected, within 0.01V cell to cell.
This may or may not be true. One thing for sure - we all know about these incidents much more quickly than we could have in the early days of NiCds and Eflight, and there are many more of us flying electric than then (20-25 years ago). And there's no denying that once a lithium battery goes up the result is more dangerous. I have seen NiCd caused destroyed models and grass fires from either overcharging and short circuits. But NiCds don't just keep burning.....
edit: added results of checking two ETec packs Sunday evening.
BEC is offline Find More Posts by BEC
Old Sep 28, 2003, 07:07 PM
GWRIGHT is offline
Find More Posts by GWRIGHT
Product Manager at Hobbico
GWRIGHT's Avatar
United States
Joined May 2000
I'd like to make one more post in this thread to hopefully gain a postive from this experience for the e-flight community. I'll never really know what happened,..if it was charger, battery pack,..etc. since everything is literally "toasted". Something we do know is that there is the POTENTIAL for real danger. What I'll freely admit I did wrong, and it was my own stupidity due to complacency,.. is that I left a lipo pack charging, basically unattended, and went out to the flight line to fly something else during the charge cycle, so there was a 10 minute or more lapse in monitoring the charge. Contributing factor was leaving the pack in the plane while charging. When I charge at home, it's in the garage and only while I'm out there to monitor. I'm guilty of becoming too "comfortable" with the technology and I didn't give it the same attention while at the field. That was very stupid of me. I hate that it cost me an aircraft, charger, pack, power system,..etc. worth a few thousand dollars,.. but the lesson I've learned is to NEVER leave lipo's charging unnattended. If I'd been watching them every couple minutes I'd have surely seen a puffed cell before the fire. I can only count my blessings that the damage was a model airplane, and not a person. If there can be any positive from this, let it be the shared knowledge regarding unnatended charging. Please, don't become as complacent (stupid)as I was.
GWRIGHT is offline Find More Posts by GWRIGHT
Site Sponsor
Old Sep 28, 2003, 07:22 PM
Master of the Wind
AIR MOVER's Avatar
TEXAS
Joined Jun 2001
well said GWRIGHT!
Old Sep 28, 2003, 07:24 PM
Herb is offline
Find More Posts by Herb
Lithium Member
Herb's Avatar
Irvine, Calif USA
Joined Feb 1999
Originally posted by GWRIGHT
... Something we do know is that there is the POTENTIAL for real danger. ...
Thanks for stressing this point.
Herb is offline Find More Posts by Herb
LiPo Fire Pictures ken_keeler Batteries and Chargers 135 Oct 12, 2006 12:45 PM
Another LiPo fire.. davensocal Batteries and Chargers 98 Apr 20, 2004 12:42 PM
Another Lipo Fire -- Etech cells Pat Daily Batteries and Chargers 39 Mar 15, 2004 08:41 PM
Lipo fire........cell imbalance? AussieParkflyer Batteries and Chargers 28 Feb 01, 2004 09:00 PM
LiPo Fire Extinguisher Patrick in WI Batteries and Chargers 5 Jan 12, 2004 11:34 PM
