Old Sep 27, 2003, 08:15 PM
larryfl1 is offline
Find More Posts by larryfl1
Fl
Joined Apr 2003
Gary,
I will be curious what mr schulze has to say about this.
Alot of us have his chargers......Hopefully it was a freak mishap........Too bad it was in that machine it was flying beautiful..
Well tonight i ran to get an extinguisher for my room where i charge and also for my car... I am not taking any chances...
I only posted the photos for everyone to realize that playing with lipos does pose certain risks and to take precautions.... the purpose was not for everyone to second guess what was done right or wrong.........As we all know gary has been using these batteries for a while and knows what he is doing... this was a freak mishap.
So hopefully we all learn from something like this to be carefull,things do happen..
Larry
larryfl1 is offline Find More Posts by larryfl1
Old Sep 27, 2003, 08:42 PM
hoppy is offline
Find More Posts by hoppy
Space Coast USA
hoppy's Avatar
Space Coast
Joined Oct 2000
Let's start over. Thank you for posting those pictures. Some (many) modelers still are saying that LiPo's are no more dangerous than any other chemistry and reporting these incidents will hopefully cause other modelers to be more careful with how they handle these cells. Did all the cells burn or just one. There have been some discussions on whether a burning cell would cause the others to ignite. Maybe this accident can throw some light on that subject, it's just too bad it happened but maybe some useful info will come out of it.
hoppy
hoppy is offline Find More Posts by hoppy
Old Sep 27, 2003, 09:05 PM
GWRIGHT is offline
Find More Posts by GWRIGHT
Product Manager at Hobbico
GWRIGHT's Avatar
United States
Joined May 2000
I had the charger set for 10 cells and it was 10S4P that was in the plane. I looked at the charger and it was at 39+ volts (not 40, forget what decimal), still at 8 amps (8200mah pack) and I went out to fly my sp400 pylon plane (also flying on lithiums, so it goes for a while on the 3S 2100mah pack). I only flew it 9+ minutes and landed. As I was removing the wing to unplug, my friend Mike Weiss yelled at me, and when I looked over, there was a very tall plume of thick black smoke, and 2 to 3 foot high flames, and he was pulling what was left of the plane away from his trailer by the tail (from about the rear of the canopy back is intact, but that's all that's left). He flies turbines, so he keeps a fire extinguisher in the trailer, which he used. It didn't do anything to the fire. Dave Elias got his extinguisher from his car, and it took quite a bit of spraying with the dry power type extinguisher to get the flames out. Complete loss along with the charger, which was sitting on the cowl of the plane while charging. I should not have been charging them in the plane, but as stated earlier, it's complacency from doing that many times in other planes over the last year. Secondly, I should have more closely monitored the charger, voltage and current,.. with the voltage approaching max. I've charged lithiums now hundreds of times, and that charger has worked flawlessly, so I guess I've become too "trusting". When I do the same thing over and over and over hundreds of times, I simply don't expect it to be any different on the next iteration. Wwhen hoppy asks about how many cells burnt, all of them, along with the plane.
GWRIGHT is offline Find More Posts by GWRIGHT
Site Sponsor
Latest blog entry: blog
Old Sep 27, 2003, 09:20 PM
Morphisnb is offline
Find More Posts by Morphisnb
GBZealous
Morphisnb's Avatar
Western Mass
Joined Jul 2002
I just got My 636 in yesterday......I would be interested in Garys' thoughts on NOT choosing another Shulze.....getting a Stricly Lipo Charger AKA the Astroflight?
Noah
Morphisnb is offline Find More Posts by Morphisnb
Old Sep 27, 2003, 09:23 PM
GMRO is offline
Find More Posts by GMRO
Russellton, PA
Joined Oct 2002
I've only had my 636 w/8.06 software for about 1.5 weeks now. So far it's working super. I only have a max of 6S4P @ 8200 MAH which I've only hit at 6.5 amps.
I had no idea this charger would pump 8 amps in a 10S4P pack.
SORRY AGAIN GARY!
That's a rough one to stomach...
__________
Best regards,
Ron Osinski
aka - GMRO
GMRO is offline Find More Posts by GMRO
Old Sep 27, 2003, 09:50 PM
Dave Hederich is offline
Find More Posts by Dave Hederich
Walled Lake, MI, USA
Joined Feb 2000
Gary, my take on your last message is that the charger really didn't "burn out." From your description, it sounds as if you're saying that something in the total charger-pack system failed. In other words, either the charger malfunctioned and caused the pack to fail, or the pack failed due to its own problem unrelated to the charger. As best I can tell, you have no way of knowing whether the charger or the cells was the source of the problem. The only thing you know is that the cells failed and burned down your aircraft. Is that about right?
This is a critical data point. Think about the implications here: A fire extinguisher owned by a turbine flyer would not put out a LiPo fire. Either the turbine flyer has an inadequate fire extinguisher, or LiPo fires are pretty darned nasty, and to be avoided by any reasonable means.
Dave Hederich is offline Find More Posts by Dave Hederich
Old Sep 27, 2003, 10:05 PM
GBZealous
Morphisnb's Avatar
Western Mass
Joined Jul 2002
There are 4 types of Fire extinguishers
http://www.hanford.gov/fire/safety/extingrs.htm#fetypes
Old Sep 28, 2003, 12:00 AM
Daren is online now
Find More Posts by Daren
Daren's Avatar
Los Alamos, NM, USofA
Joined Nov 2000
I think before anyone jumps to any conclusions (not to say you are, Dave), we need more facts. Many of the turbine guys use the Indian Fire Pump type of extinguishers, which use plain water and are intended for grass fires.
This may be a case of simply the wrong type of extinguisher for this type of fire or it may have been improperly used.
Data, we need data.
Daren
Daren is online now Find More Posts by Daren
Old Sep 28, 2003, 01:06 AM
BEC is online now
BEC
Find More Posts by BEC
BEC
BEC's Avatar
Auburn, Washington USA
Joined Jan 2001
Interesting and scary. And truly sad to see this happen to a gorgeous and good flying airplane.
It will take rather more info to sort this one all the way out.
Schulze's documentation (as currently posted on is web site) says the 636 can "only" do 6.5A into 40V so if it was at 39V and still indicating 8A that indicates something was not right.
I echo the question about what the source power was. Even if the charger is 100% efficient in stepping up the voltage it would have to be drawing nearly 30A from a 12V source to put out that much current at 40V. That's a hefty power supply or a BIG deep cycle battery. I wonder, lacking any information, if the innards of the charger were somehow damaged/weakened by something other than a pure DC input - perhaps not even on this charge cycle. Schulze is rather strident in his documentation about how most power supplies and no battery chargers are suitable as sources.
As for the 8.06 software catching a cell count error...... I've just put 8.06 in my 330d and 636. The 330d is batting .500 in catching an intentional cell count error. I wouldn't depend on that function at all (the test was with two 3s packs and setting the charger to 4). I haven't tried the 636 yet to see if it's any better.
BEC is online now Find More Posts by BEC
Old Sep 28, 2003, 05:25 AM
GWRIGHT is offline
GWRIGHT's Avatar
United States
Joined May 2000
Bernard, supply is 115AH deep cycle marine battery.
Site Sponsor
Old Sep 28, 2003, 06:42 AM
RD Blakeslee is offline
Find More Posts by RD Blakeslee
Joined Jan 2002
"... It will take rather more info to sort this one all the way out..."
BEC, we may never know. Something like a partial gap in a connecting wire (hidden mfg. defect) causing high impedance won't be found. If not in this case, then another down the road.
Something Fred Marks said has stuck in my mind: "Safety is a matter of discipline". It's a pain, but "taking pains" limits the loss to the pack per se and, possibly, the charger.
Gary, I don't know you except for your participation on ezone, but I feel sorry for your loss.
- RD
RD Blakeslee is offline Find More Posts by RD Blakeslee
Old Sep 28, 2003, 06:55 AM
MattLarson29 is online now
Find More Posts by MattLarson29
Endangered User
MattLarson29's Avatar
United States, FL, Casselberry
Joined Jul 2002
On a related note, the extinguisher pictured is suitable only for class A fires. A turbine model has a whole lot of flammable liquids in it, and using water is an invitation to spread the fire. Since almost all flammable liquids float on water, they will just run off downhill, happily burning atop their cushion of water.
Those who are using these pressurized water extinguishers for turbine models should get rid of them immediately and get hold of CO2 or dry chemical extinguishers rated for the threat they actually face.
Similarly, multi-class extinguishers would seem to be indicated for LiPoly fires, especially where there may be proximity to a 120 volt power supply. Spraying water on energized electrical equipment is not a good plan.
Matt
MattLarson29 is online now Find More Posts by MattLarson29
Old Sep 28, 2003, 07:04 AM
luc is offline
luc
Find More Posts by luc
luc
I plant balsa sticks too
luc's Avatar
France
Joined Feb 2000
My feeling is the following: charging close to 40V at 8A gives a lot of watts, a lot of heat. I would not charge at that level, because that's too much heat generation.
Presently with my SC2, even if it can charge at 4A*2, I prefer to avoid overheating and stay at much lower amps, even if it takes more time. I prefer to have an extra battery pack and give a low charge: better for the charger and certainly not bad for the packs.
luc is offline Find More Posts by luc
Old Sep 28, 2003, 07:39 AM
Joined Feb 2000
Yes, Daren, I also would like to have more information on that first charger. As I said, it may have been an inadequate charger for a turbine owner to have, or LiPo fires may be unusually stubborn. Note that the second dry powder extinguisher took "quite a bit of spraying" to put out the fire.
Gary, sorry if it seems as if we're grilling you here. It's just that the details of what happened in your experience could save others in the future. Do you have any way of knowing what type of extinguisher the first one was? It sounds as if that's a type for LiPo users to avoid.
Old Sep 28, 2003, 07:44 AM
Endangered User
Joined Jul 2002
Dave:
Don't get too hung up on the "quite a bit of spraying". Dry chemical extingushers work by smothering the fire. You have to get sufficient agent on the material involved in the fire to cut off the supply of oxygen. This can take a bit of effort.
You also have to be careful if the material involved has the capacity to retain a lot of heat, because removing the layer of agent can allow the fire to re-kindle.
Matt
LiPo Fire Pictures ken_keeler Batteries and Chargers 135 Oct 12, 2006 11:45 AM
Another LiPo fire.. davensocal Batteries and Chargers 98 Apr 20, 2004 11:42 AM
Another Lipo Fire -- Etech cells Pat Daily Batteries and Chargers 39 Mar 15, 2004 07:41 PM
Lipo fire........cell imbalance? AussieParkflyer Batteries and Chargers 28 Feb 01, 2004 08:00 PM
LiPo Fire Extinguisher Patrick in WI Batteries and Chargers 5 Jan 12, 2004 10:34 PM
