Old Nov 14, 2003, 08:34 PM
Ben74 is offline
Find More Posts by Ben74
Ben74's Avatar
San Francisco, CA, USA
Joined Jun 2001
i see. thanks for the update, glen.
Ben74 is offline Find More Posts by Ben74
Old Nov 15, 2003, 06:12 AM
RD Blakeslee is offline
Find More Posts by RD Blakeslee
Joined Jan 2002
"... there would be no more adding new cells to old packs and what this would mean to me is that I could not send in a 4S4P for 'factory refurbishment' to restore it to the same functionality IF a cell was ruined..."
If you parallel charge, you don't need to discard a "pack" if one cell gets ruined. Just put a new cell in. Pack "balancing" is only an issue if you charge cells in series.
- RD
RD Blakeslee is offline Find More Posts by RD Blakeslee
Old Nov 15, 2003, 10:57 AM
gpeden is offline
Find More Posts by gpeden
-Flight enthusiast_
gpeden's Avatar
Lake Louise, AB, Canada
Joined Feb 2000
HI RD,
Perhaps things wil evolve that way, but can one do that with current "installed base", especially if the manufacturer will not repair them?
The original comments I heard, "these things are pretty durable, but if you do damage them in a crash you can send one in to Charlie for repair" has changed into a situation where one has to find a home for the orphans after paying a minor charge for the refurbishing. So for me, the concept of these cells being an investment that could be maintained in service for a long time is in question. With increased popularity, the market for "lesser packs" from the popular configurations would quickly flood and salvage prices drop. Your idea of parallel charging seems to be a good way to get long term service and return on the investment.
...and things won't stop evolving.....
Cheers!
Glen
gpeden is offline Find More Posts by gpeden
Old Nov 15, 2003, 02:30 PM
Joined Jan 2002
Hi, Glen,
Re the "installed base": I'm afraid we'll have to take our packs apart and rewire them. That's what's happening, in effect, to Charlie now.
I'm still using my Kokam 3270 Lipos I bought about a year ago, when they first came out.
Ever since the beginning, I have followed the strategy of buying and individually or parallel charging large enough LiPos that I didn't need to connect any in parallel for flying. They have been connected in series only for flying.
These original cells are still serving me well. I check the residual voltages from time to time, after flying. These voltages now vary by over .5 volts in some cases, which indicates the cells are now mismatched and some would be ruined (at least) if they were charged in series.
When Kokam's new 20C, 3.4 amp cells come online, larger emodels can easily adopt this strategy.
- RD
Old Nov 15, 2003, 04:55 PM
rpage53 is offline
Find More Posts by rpage53
Boffin
rpage53's Avatar
Victoria, BC, Canada
Joined Apr 2001
The cells deteriorate with use and the new cell will effectively be a higher capacity cell as well. Its generally risky to make packs up of unequal cells regardless of the charging method.
I think Thunder Power's approach of reducing the total cell count is the best, though sending a damaged pack through the mail gives me the frights.
Rick.
rpage53 is offline Find More Posts by rpage53
Old Nov 15, 2003, 05:24 PM
Joined Jan 2002
"The cells deteriorate with use and the new cell will effectively be a higher capacity cell as well. Its generally risky to make packs up of unequal cells regardless of the charging method."
Why risky?
If the cells are individually charged to 4.2 V or so, the worst that can happen (and does, with my cells) is that the lower capacity cells will discharge to a lower voltage than the higher ones. Where's the harm in that? I haven't had any problems with it, and I've done it over and over, for a long time.
- RD
LiPo Fire Pictures ken_keeler Batteries and Chargers 135 Oct 12, 2006 11:45 AM
Another LiPo fire.. davensocal Batteries and Chargers 98 Apr 20, 2004 11:42 AM
Another Lipo Fire -- Etech cells Pat Daily Batteries and Chargers 39 Mar 15, 2004 07:41 PM
Lipo fire........cell imbalance? AussieParkflyer Batteries and Chargers 28 Feb 01, 2004 08:00 PM
LiPo Fire Extinguisher Patrick in WI Batteries and Chargers 5 Jan 12, 2004 10:34 PM
