This thread is privately moderated by snoshoe62, who may elect to delete unwanted replies.
Old Nov 24, 2011, 10:59 PM
snoshoe62 is offline
Find More Posts by snoshoe62
Trader Rating: 177
Boycot Crappy CC Controllers
snoshoe62's Avatar
United States, MI, Port Huron
Joined Jun 2006
Trader Rating: 177
Sold
42% 1.5 Amp Ignition Regulator for Gas Engines
Allows you to use your CDI/Electronic ignition with LI-PO, LI-ION and 5 Cell NiMh/NiCad Packs. Plugs in between battery switch/kill switch and the ignition unit. Suitable for DA/DL/DLE ignitions and most other brands that are limited to 6 Volt inputs. $15.00
• Voltage Input : 7.0 to 15.0 Volts D.C
• 2 ~ 3 Cell Li-poly/Li-Ion Cells / 5 Cell Nicad & NiMh
• Output 5.0V @ up to 1.5 Amps Max Load
•Made in U.S.A.
NOTE: This is for accessory items (ie Ignitions, Gyros etc) only, it is not intended for multi servo applications of any type
** Also have the 42% Opto Gas Engine Kill Switch available in another post**
snoshoe62 is offline Find More Posts by snoshoe62
Old Nov 24, 2011, 11:47 PM
krxprt is online now
Find More Posts by krxprt
Trader Rating: 286
krxprt's Avatar
United States, MI, Davisburg
Joined May 2010
Trader Rating: 286
krxprt is online now Find More Posts by krxprt
Latest blog entry: 42% Raven
Old Nov 25, 2011, 06:57 AM
Trader Rating: 177
snoshoe62's Avatar
Joined Jun 2006
Trader Rating: 177
Originally Posted by krxprt View Post
ooops, sorry, 15.00 shipped, only used 4 flights
Old Nov 26, 2011, 11:34 AM
ocrcdude is offline
Find More Posts by ocrcdude
Trader Rating: 46
It's only a toy!!
ocrcdude's Avatar
United States, CA, Orange
Joined Feb 2010
Trader Rating: 46
regulator
So can this also be use for receivers?
ocrcdude is offline Find More Posts by ocrcdude
Old Nov 26, 2011, 04:40 PM
Trader Rating: 177
snoshoe62's Avatar
Joined Jun 2006
Trader Rating: 177
I am not sure but i dont think so. If your running any kind of servos you will draw more then 1.5 amps. This regulator was designed for gas ignition systems.
Question New to gas engines,what type of battery for ignition grasschopper Fuel Plane Talk 16 Aug 06, 2014 07:28 AM
Discussion Wiring diagram for old Ignition engines dankar04 Engines 4 Oct 18, 2011 10:03 PM
Sold US Engines NIB 41cc (2.5 cu in) gas engine. REDUCED !! puplover Aircraft - Fuel - Engines and Accessories (FS/W) 0 Oct 15, 2011 01:41 PM
Sold RCG 26cc Gas engine w/ CD-Ignition 2.6HP/1.95kw kenkey Aircraft - Fuel - Engines and Accessories (FS/W) 4 Jun 20, 2011 02:28 PM
For Sale OS BGX-1 engines 1 glow,1 gas ignition aerowoof Aircraft - Fuel - Engines and Accessories (FS/W) 0 Mar 06, 2011 10:25 AM
