Old Jul 05, 2001, 06:15 PM
Giddy up!
Sal C's Avatar
Woodridge, Illinois
Joined May 2000
Looking for wheels & wire to handle grass ROG & landings
Does anybody have a good recommendation of wheels (specific make & size) and what size wire for LG for a plane to ROG & land off of grass? I see the glow guys do it all the time, I understand they have heavy planes & the power to handle it.
My latest T-52 should be heavy enough and powered pretty well, 53 ozs w/MEC Turbo 10+. I'm currently using Dave Brown Lectra Lite wheels with 1/8" music wire but it gets stuck in the grass.
Sal C is offline Find More Posts by Sal C
Old Jul 05, 2001, 06:35 PM
Dauntae's Avatar
New Bedford, Ma. USA
Joined May 2001
I don't have a T-52 but I did come accross this page about installing landing gear on the T-52. http://www.jkaerotech.com/T52Lgear.htm Hope this helps.
Keep em hummin.
Dauntae
[This message has been edited by Dauntae (edited 07-05-2001).]
Dauntae is offline Find More Posts by Dauntae
Old Jul 05, 2001, 06:54 PM
BEC
BEC's Avatar
Auburn, Washington USA
Joined Jan 2001
I see Dauntae pointed to the posting the JKA guys did of the pictures I sent them of the gear on my T-52. Note that it's geared 480 powered (APC 9X6 Slowfly prop, though it's a 10X7 in the pictures) and weighes 32.5 ounces with 8X1400AE cells on board.
It ROGs from moderate grass fairly easily, will shoot touch and goes, but does sometimes flip over on landing - especially if I come in for a wheel landing rather than three-point it. The wheels, as shown, are 2.75 inch Dave Browns which I used to use on my wife's Goldberg Mirage 550 for grass operations. I need a fair amount of rudder/tailwheel steering to get the short-coupled T-46 (clipped 52) going straight on takeoff until it gets rolling fast enough for the tail to come up.
At your weight 3/32 wire (as I used) won't work. The nose down attitude I see your tricycle geared version in some of the pics you've pointed to in other posts is a problem. What appears to be very marginal prop clearance won't help. OTOH you have gobs more power available than I do. If yours were a taildragger I'd expect it to practically jump into the air.
My favorite grass field wheels are Trexlers as they let you float over the grass rather than plow through it. You'd need 3 #8s for your plane (have to buy two pair).
I have a question for you: how did you widen the fuselage enough to get that T-10 on there?
[This message has been edited by BCawley (edited 07-05-2001).]
BEC is offline Find More Posts by BEC
Old Jul 05, 2001, 08:07 PM
Giddy up!
Sal C's Avatar
Woodridge, Illinois
Joined May 2000
Thanks for the replies guys.
Ken @ JKA emailed me back pointing to your gear mounting method Bernard (I sent them pics of my T-52). I must say that's a great idea. I really like the tail wheel setup.
I was thinking of extending the gear longer and maybe going with a 10" prop rather than 11".
I didn't widen the fuse, the Turbo 10 fits very snug in there. It actually bends the doublers out a wee bit but it's not a problem. My nose wheel wire bent back a bit after my last landing try in grass. I'm going to make it steerable too.
Old Jul 06, 2001, 09:33 AM
I'm disoriented!
ChrisD's Avatar
Mt. Laurel, NJ, USA
Joined Aug 2000
Sal,
I used regular aluminum landing gear for my T-52, and it works great. It's bolted with blind nuts to a plywood plate that's epoxied to the balsa doublers, and foam.
The wheels are Dave Brown lite foam at 2", but could be larger. 3" might work.
I think you have enough power, and the added 2 ozs should make no difference. My local hobby store had some lite, thin gear for small glow planes. $12 or so. Forget the wire gear - too light for this application.
Chris
ChrisD is offline Find More Posts by ChrisD
Old Jul 06, 2001, 10:12 AM
Bill Glover's Avatar
Bracknell, Berks, UK
Joined Nov 2000
I've used piano wire undercarriages on models up to 15 lbs, how heavy is a T-52
Bill Glover is offline Find More Posts by Bill Glover
Old Jul 06, 2001, 10:35 AM
Giddy up!
Sal C's Avatar
Woodridge, Illinois
Joined May 2000
My T-52 is 53 ozs.
Chris, can you ROG from grass?
Old Jul 06, 2001, 10:37 AM
I'm disoriented!
ChrisD's Avatar
Mt. Laurel, NJ, USA
Joined Aug 2000
Sal,
It can, but I haven't, as I don't want to put 4 servos on the ESC by hooking up the rudder.
I've tested it, and it goes, no problem.
Bill - I don't think Sal wants to use 3/8" rebar!
[This message has been edited by ChrisD (edited 07-06-2001).]
Old Jul 06, 2001, 11:07 AM
Joined Nov 2000
I've never used anything bigger than 6 SWG myself (0.192", 4.877 mm)
But (back on-topic!) my Twin Star weighs 54 ozs, the noseleg is 12 SWG (0.104", 2.641 mm) and the main gear is 10 SWG (0.128", 3.251 mm). That will ROG from shortish grass and do T&Gs quite happily. Wheels are 2.25" mains and 2" nose.
Side view: http://uk.y42.photos.yahoo.com/bc/bi...+4.jpg&.src=ph
Underside view: http://uk.y42.photos.yahoo.com/bc/bi...+1.jpg&.src=ph
(can't figure out how to do imbedded images from Yahoo like I used to be able to do from Photopoint!)
Old Jul 06, 2001, 11:51 AM
aka: A.Roger Wilfong
gnofliwr's Avatar
Novi, Michigan, United States
Joined Jan 2001
Bill,
Try this, in Netscape, do a "view image" and copy the location (in IE get the properties of the picture to get the location) and paste it into an "img src=" tag.
- Roger
[This message has been edited by gnofliwr (edited 07-06-2001).]
gnofliwr is offline Find More Posts by gnofliwr
Old Jul 09, 2001, 07:44 AM
Joined Nov 2000
Originally posted by gnofliwr:
Bill,
Roger, that's what I used to do from Photopoint ... but it doesn't work from Yahoo (just like I don't see your imbedded image above).
Old Jul 09, 2001, 05:01 PM
Dauntae's Avatar
Joined May 2001
Bill,
- Roger
easyer way in netscape would be just to "save image as" onto the desktop and veiw it that way.
Dauntae
Old Jul 09, 2001, 05:17 PM
Giddy up!
Sal C's Avatar
Woodridge, Illinois
Joined May 2000
I put regular Lite Flite wheels on today (upped to 2 1/2") and I'm going to try ROG'ing from the grass. They cut very short at the field and it's been hotter than heck for the past couple of days, really scorched the grass. The ground should be nice & hard too. I also lengthened the nose gear a bit & now I about 1 1/2" of clearance with an 11x7 MAS.
If these don't work then I'm going to try Bernard's recommendation of Trexler's.
Discussion Looking for magnet wire wevets Power Systems 7 Dec 29, 2005 03:45 PM
Looking for two wire charts. bkahuna Power Systems 5 Oct 17, 2005 11:42 AM
Looking for Glow Wire ideas fbw4 Electric Plane Talk 7 Mar 18, 2004 12:09 PM
Help, looking for hot wire wing jig plans? Cubby Boy Foamies (Kits) 4 Jun 26, 2003 01:21 PM
Question Looking for 3s LiPoly to handle 20 Amps Pre made RCGuyAlan Batteries and Chargers 7 Jun 03, 2003 09:22 PM
