Old Nov 24, 2011, 06:37 PM
FlyBoysRc is offline
Find More Posts by FlyBoysRc
United States, FL, Port Orange
Joined Jul 2011
How to strip plank a fuselage
Ive been attempting to plank my at6 fuselage with 1/16 inch balsa and everything has been fine but i have no idea how to fill the gaps or how to stip plank period for the most part. I have been just cutting 3/8 planks and glueing 1 on one side than 1 on the other. Now gaps are starting to form and compound curves are not easy any advice would be very much appreciated
FlyBoysRc is offline Find More Posts by FlyBoysRc
Old Nov 25, 2011, 12:30 AM
Herman Munster is offline
Find More Posts by Herman Munster
Herman Munster's Avatar
United States, Mt, Libby
Joined Nov 2007
To help form the balsa around curves try wetting the balsa with water. it will help it conform easier without breaking. If the gaps aren't too big you can fill them with lightweight spackle.
Herman Munster is offline Find More Posts by Herman Munster
Old Nov 25, 2011, 02:45 AM
trumps is offline
Find More Posts by trumps
What's 3D?
trumps's Avatar
Australia, WA, Ellenbrook
Joined Feb 2008
Yup, water/windex to help conform the planks,
When stripping your planks do so at a slight angle
So that they are slightly keystoned when looking
End on, this helps minimise the gaps as they follow
The curvature of the fuse. Planking does take time
Due to the fact that every plank must be custom
Formed to suit it's position. Red Devil filler is what I
Use for any minor gaps remaining, it I very very light
in weight and sands very well.
Enjoy
Craig
trumps is offline Find More Posts by trumps
Old Nov 25, 2011, 08:19 AM
Joined Jul 2011
how do i strip the planks at an angle is there a way to do it on the stripper
Old Jan 10, 2012, 01:02 PM
Wolpertinger is offline
Find More Posts by Wolpertinger
Formerly "vonJaerschky"
Wolpertinger's Avatar
Canada, BC, Comox
Joined Nov 2003
Sorry I'm a bit late with this, but there is a good how-to article here.
Wolpertinger is offline Find More Posts by Wolpertinger
Old Jan 10, 2012, 03:46 PM
Joined Jul 2011
thank you so much vonJaerschky that article cleared everything up
Discussion PSA ... How to field strip your glock ... logan5 Life, The Universe, and Politics 16 Nov 08, 2011 02:07 AM
Discussion Any ideas how to make UM landing strip or runway? ScorpioPilot Micro Ready-to-Fly 56 Oct 07, 2011 01:04 PM
Discussion How do you cap a rib with a carbon fiber strip? How much strength does it add? Accu157 Thermal 93 May 07, 2011 12:27 PM
Discussion How to find COG on a Plank Yablonsky Slope 23 Apr 28, 2011 03:02 AM
Discussion how to strip a 46 size 2 stroke mr fabulous Engines 6 Apr 27, 2011 12:41 PM
