Old Aug 01, 2012, 10:59 AM
pkapps68 is offline
Find More Posts by pkapps68
pkapps68's Avatar
Canada, ON, Waterloo
Joined Jun 2012
Originally Posted by romandesign View Post
I'm in Oakville, western Toronto suburb. Where are you?
I live in Waterloo. Not too far away.
pkapps68 is offline Find More Posts by pkapps68
Old Aug 01, 2012, 11:09 AM
pkapps68 is offline
pkapps68's Avatar
Joined Jun 2012
I live in Waterloo.
Old Aug 01, 2012, 05:14 PM
LowSpeedStall is offline
Find More Posts by LowSpeedStall
United States, FL, Valrico
Joined Apr 2012
Real Flight AT-6 Flaps
Banana Hobby shipped my plane today so I will be joining the ever growing air force of AT-6 pilots. Looking forward to the build and of course the maiden flight.
Can someone comment on how the flaps affect the model AT-6. In RealFlight 6, the flaps increase the lift of the plane - the plane increases altitude from level flight with the application of full flaps. The exact opposite occurs with the P-51 Mustang in the sim - the plane noses down and loses altitude rapidly with full flaps. I would like to practice with an RF6 plane that mimics how my AT-6 is going to perform.
From what I've found on the web, flaps are really overkill for most small RC planes - there more for the novelty of scale flying than needed to slow the plane down for landing. Also, I can't figure out why everyone mentions a flare on landing. The AT-6 has conventional landing gear (two mains and a tail wheel). I certainly don't want to pitch the plane back onto the tail wheel by flaring the plane on touchdown. Now if it were a jet with tricycle gear I could see the need for a light flare. Am I missing something?
I hope to have RF6 landings figured out (flaps or not) before the maiden flight.
Please let me know about the reaction of the plane to flaps drop. Thanks.
LowSpeedStall is offline Find More Posts by LowSpeedStall
Old Aug 01, 2012, 07:54 PM
peterswolf is offline
Find More Posts by peterswolf
peterswolf's Avatar
United States, FL, Riverview
Joined Apr 2012
Originally Posted by pkapps68 View Post
Romandesign; Where abouts in Canada are you? It is nice to know I am not the only Canadian here. The advice this thread gives, has been great and I enjoy reading the goings on with other owners. I need a bit of help to start off. With the wind we have had up here I am a bit intimidated to wreck either of my planes.
I'm a Canadian too. I'm currently living in Florida for the last 5 years, but I was born, raised, lived and worked just east of Toronto. Thinking I might redo the markings on my AT6 to something a little more Canadian.
peterswolf is offline Find More Posts by peterswolf
Latest blog entry: http://www.peterswolf.com
Old Aug 01, 2012, 08:10 PM
TwistedGrin is online now
Find More Posts by TwistedGrin
Yes it was Abby Normal
Joined May 2012
LSS, I have experienced the BH AT-6 will indeed initially lift if flaps are engaged right before the landing, causing a balloon effect. Therefore - engage the flaps very early in the apprpoach and keep power on with a nose down attitude allowing the AT-6 to establish a steady rate of descent and settle down into a flat and level landing path...not a gliding path. Of course reduce the speed for the beginning of the landing path and hold steady as you fly it down...anotherwords keep power on all the way until the AT-6 is rolling on the runway and then cut back...
I am landing on a grass runway and have better landings without flaps.....as the grass really shuts the plane down as soon as the gear hits the grass. I crashed from a ballooning - induced by the flaps as I switched flaps on right about 10ft above the runway during a landing run, it rose, continued to slow down and then experienced the dreaded wing drop with no room or time to apply enough power and speed to recoverrat the top of the balloon. I have executed flaps now on landings just for the fun of it, but I have found that you still need to power on all the way down after establishing a very long landing approach run. Either way we have to establish that flat rate of decent in both configurations.....don't try to operate the flaps at the last minute...this is a no no...the plane will train you alright.
I have even flown the BH AT-6 for full round block passes with flaps fully engaged and brought it down. In my opinion flaps tend to mute elevator reaction some...as if it takes a greater amount of elevator to affect flight. On this note I have mixed in a little bid of down elevator with flaps at 100% to help me land with flaps engaged.
Again the best "Approach" is a pretty long landing set up, allow the plane to establish its own rate of decent and fly it in flat....no flare ups.
Cross winds are tricky but not as bad as trying to take off in cross winds. Take offs in cross winds is a fine touch of throttle and rudder...as too much throttle will enduce tork roll with not enough speed to prevent the wing tip stall. So landing in stiff cross winds is where the flaps can really help...use the rudder and keep the throttle steady. Again no flare....best landings are low and flat...if it balloons don't slam throttle off either ......fly it down again with throttle on ...or abort and go round again.
I am operating my AT-6 on a grass strip with at least enough battery time for a secondary landing pass...landing just as my timer is singing at the six minute mark....so I am landing at or near a 5Min30sec mark on the Genesis 55C 2500 LiPo with about 3.8v left on each cell. I am usually flying at about 80% with burst of full throttle, loops, rolls, figure eights, hammer heads and near Touch-N-Go's (hard to do TNG on grass ...even very short nap grass). Bear in mind I have upraded my motor to a HeadupRC Power Up 15 motor and a 60A ESC...so using up a little more battery than usual.
There is a great write up of landing the BH AT-6 R/C on this thread.... essentially I tried to practice that thread at the field...it works...will try to find the thread again and direct us to it.
My two cents and hope this helps.....
I am also simulating with Real Flight 6...which AT-6 are you simulating on?
TwistedGrin
TwistedGrin is online now Find More Posts by TwistedGrin
Old Aug 01, 2012, 08:12 PM
pkapps68 is offline
pkapps68's Avatar
Joined Jun 2012
This is my plan too. I have the Canadian emblems, but need to find the RCAF letters. I just maidened and crashed my Cessna. Time to rebuild. It has been very windy here, a I lost control of it. Oh well
Old Aug 01, 2012, 08:18 PM
Stelvio is offline
Find More Posts by Stelvio
Joined Aug 2012
Generally, on real aircraft putting down the flaps causes the nose to rise so you have to hold down elevator until you get your trim sorted out. On models, people with mix-capable TXers mix in some down elevator coupled with flap actuation to automatically compensate for this.
Whether you're landing a tri gear or tail dragger you still flair on the landing. The technique is to make your descending approach, round out and hold the plane level with the ground inches above it then, as the speed bleeds off and it wants to settle, ease back on the elevator stick (flair) so you gently touch down in a three point attitude. Same thing for a tri gear but you probably won't drag the tail.
Stelvio is offline Find More Posts by Stelvio
Old Aug 01, 2012, 08:25 PM
Stelvio is offline
Joined Aug 2012
Thanks Terry,
I first bound the RX with the throttle trim down and then again in neutral to no avail. Where is this little switch? I don't remember seeing anything movable on the sound card except for the volume control.
Old Aug 01, 2012, 08:37 PM
Stelvio is offline
Joined Aug 2012
Originally Posted by krazyman View Post
Try binding the RX with the throttle trim in the nuetral position. After binding and turn on TX and set the throttle trim down untill the motor noise quits. If that does not work move the little switch on the edge of the sound board in the other direction. Hope this works for you.
Terry
Thanks Terry,
Old Aug 01, 2012, 08:47 PM
Stelvio is offline
Joined Aug 2012
Me too...Sarnia, Guelph, Vancouver and now living in Perth, Western Australia.
Old Aug 01, 2012, 09:38 PM
GiusedtoBe is offline
Find More Posts by GiusedtoBe
GiusedtoBe's Avatar
Tennessee
Joined Apr 2009
AT-6 RIP
Flew 5 packs yesterday and was really enjoying this plane finally. Five flights and five greasers on grass with half flaps. Flight six was great until on approach with half flaps I approached a little shallower than i should have and had the brain fart idea to hit the full flap switch. When I did that it immediately stalled and dropped the wing like Twisted Grin mentioned. Of course it was in the only spot where my view was obstructed so I could not see it to recover and it crashed in a parking lot.
100% pilot error but I'm done with this one. That stall is nasty and unforgiving. One major rebuild is one thing but two after a dozen flights or so is more than I want to fool with. Good Luck to all and don't let my experience scare you. The plane is a good flyer just keep your approach steep and don't go from 1/2 to full flaps in level slow flight.
Regards
Alan
GiusedtoBe is offline Find More Posts by GiusedtoBe
Old Aug 01, 2012, 10:41 PM
krazyman is online now
Find More Posts by krazyman
krazyman's Avatar
United States, AZ, Camp Verde
Joined Jan 2007
Originally Posted by Stelvio View Post
Thanks Terry,
The switch is 2/3 of the way back from the heatsink on the bottom edge of the board on the left side looking at the board from the rear with the heatsink at the front. It is a very small switch. If you can turn the board over you will see it.
Terry
krazyman is online now Find More Posts by krazyman
Old Aug 02, 2012, 12:15 AM
sj3cub is offline
Find More Posts by sj3cub
North Carolina
Joined Sep 2003
Sir, Every airplane in the world flares right before touchdown, well they are supposed to anyway. Tailwheel or nosewheel has nothing to do with it. There has been many a landing gear ripped out because the pilot did not flare and just flew the aircraft into the ground. The only aircraft I can think of that actually don't flare, and are designed that way, and just "plop" down onto the deck are aircraft carrier based fighter jets. Even the Space Shuttle flares right before landing. Have you flown RC before?
sj3cub is offline Find More Posts by sj3cub
Old Aug 02, 2012, 01:50 AM
Stelvio is offline
Joined Aug 2012
Terry
Thanks a lot Terry. I'll pull it all apart again tonight and check it out. I'll be a happy camper if this solves my problem as I was just resigning to fly it as is with the sound on all the time.
Old Aug 02, 2012, 08:12 AM
Stelvio is offline
Joined Aug 2012
Terry
Well, I just pulled it all apart, found that micro switch and tried it in all three positions. In one position there is no sound, in the middle position it still fires up as soon as I plug in the battery. Same with the third position. I tried moving it just a hair at a time and even tried re-binding again but no luck. I guess it's just a bad sound module. Let's see if BH will pick up the ball on this. After paying a hefty $65 shipping to Australia I'm loath to pay any more return shipping charges. Thanks anyway Terry.
New Product Art-Tech 100 ClassF-86 Sabre R/C Model Jet FieldofDreamsFlyer Micro EDF Jets and Power Systems 31 Jan 02, 2012 09:58 PM
Discussion Art Tech Cessna 182 500 Class build issues angry_muppet Beginner Training Area (Aircraft-Electric) 4 Oct 12, 2011 01:30 PM
Discussion ART-TECH 400 Class Falcon CCPM 6-Channel 2.4GHz RC Helicopter LightLake Electric Heli Talk 3 Sep 17, 2011 10:41 AM
Discussion Art Tech Cessna 182 (500 Class) Tirral Batteries and Chargers 4 Jul 21, 2011 10:27 PM
Video RC Cessna 182 Super Class (Art-Tech 500 Class) painfullybrilliant Electric Plane Talk 0 Jan 28, 2011 12:35 PM
