This thread is privately moderated by FairlyFaded, who may elect to delete unwanted replies.
Old Nov 24, 2011, 03:22 PM
FairlyFaded is offline
Find More Posts by FairlyFaded
Trader Rating: 26
Registered Snoozer
FairlyFaded's Avatar
Palo alto CA
Trader Rating: 26
For Sale
Rohacell 31/51 for sale CHEAP, wing skins, tail cores
For sale are sheets of Rohacell 31 and 51 cut to useful sizes for DLG wings and tails as well as other high performance molded airplanes.
Rohacell is the strongest foam per pound commercially available. It is used in nearly every molded competition wing, and for good reason. Until now it has been very difficult to get (the only US source charges a 300% mark-up...). But enough pitch, we all know this stuff is frickin' sweet
Here are the prices for the sizes currently available
Rohacell 51 @ 833 X 350 X 1 mm 15.00 USD
Rohacell 51 @ 833 X 200 X 1 mm 7.00 USD
Rohacell 51 @ 833 X 350 X 1.5 mm 16.00 USD
Rohacell 51 @ 833 X 200 X 1.5 mm 7.50 USD
Rohacell 31 @ 833 X 350 X 1 mm 12.50 USD
Rohacell 31 @ 833 X 200 X 1 mm 6.00 USD
Rohacell 31 @ 833 X 350 X 8 mm 35.00 USD
Rohacell 31 @ 833 X 200 X 8 mm 18.00 USD
The large sheets were sized such that the top and bottom skin for a 60" dlg could be nested into one sheet with little wasted material. So for a 60" dlg wing two large sheets will be required.
The sheets are cut with CNC bandsaw which holds impressive tolerances. Still, cutting 1mm thick sheets with a band-saw is tricky. The 1mm Rohacell 31 sheets are all very close to 1mm (+/- roughly .1mm). The 1mm Rohacell 51 generally lies above 1mm, ranging from ~1mm to 1.27mm.
Two shipping options are available:
Shipping option A: Foam will be packed flat between sheets of Luan plywood and 3/4" EPS foam. $19 flat for shipping option A
Shipping option B: Foam will be rolled into a 6" x 6" by 14" box. The foam will exhibit a slight curl when unpacked. $10 flat for shipping option B.
Questions can be emailed to Norciavelo@gmail.com or through RC groups.
-Michael
FairlyFaded is offline Find More Posts by FairlyFaded
Idea Rohacell 31 IGF Glider Wings mattcst Free Flight 23 Jan 11, 2012 04:09 PM
For Sale Rohacell foam 31 and 51! Wing skins! Tail cores! FairlyFaded Aircraft - Sailplanes (FS/W) 0 Oct 20, 2011 05:47 PM
Link Rohacell for sale in US FairlyFaded Composites Fabrication 15 Jul 02, 2011 03:51 AM
For Sale Rohacell 31/51 wing skins, tail cores! FairlyFaded Aircraft - Sailplanes (FS/W) 3 Jun 23, 2011 08:17 AM
Question Adhesive for bonding balsa wing skins to foam cores Rogo Hand Launch 2 May 05, 2008 10:28 PM
