Old Sep 12, 2012, 09:31 PM
sdbruder is offline
Find More Posts by sdbruder
sdbruder's Avatar
Brasil, PR, Curitiba
Joined Oct 2009
version 1.7
  • new bootstrap (from twitter) and small layout tweaks.
  • you can now change languages without loosing your wing.
  • deeplink is now language agnostic, following a deeplink for a wing can use a diferent language from the original.
  • some code re-arrangement.
PS: If you see a warning about Internet Explorer when you are using ANOTHER browser, just reload the page, will go away, I promise. (Its the same error of the version 1.6 with the wing load.
sdbruder is offline Find More Posts by sdbruder
Old Sep 13, 2012, 05:37 PM
Soyrico is offline
Find More Posts by Soyrico
Soyrico's Avatar
United States, CA, Hollister
Joined Jan 2006
Wish list:
Calculate wing twist percentage relative to calculator values\results but I suppose the type of airfoil would be imperative???.
Soyrico is offline Find More Posts by Soyrico
Old Sep 14, 2012, 08:55 AM
sdbruder is offline
sdbruder's Avatar
Joined Oct 2009
Originally Posted by Soyrico View Post
Wish list:
This is not feasible with the information we have on the calculator.
But a library of Wing designs is!
Old Sep 14, 2012, 12:41 PM
critx is offline
Find More Posts by critx
Cluj-Napoca
Joined May 2007
Aspect ratio
Hello,
For the wish list:
May be it would worth adding a field with aspect ratio for the wing calculated?
critx is offline Find More Posts by critx
Old Sep 14, 2012, 03:49 PM
sdbruder is offline
sdbruder's Avatar
Joined Oct 2009
Originally Posted by critx View Post
Hello,
For the wish list:
Easily doable, but for what purpose? You design wings 'looking' for the aspect ratio?
I was thinking about getting Stall velocity calculated, but that depends on weight, wing area, Cl_Max (Max lift coefficient of the airfoil) and air pressure (altitude), but we can assume sea level for that.
Old Sep 16, 2012, 01:52 AM
sdbruder is offline
sdbruder's Avatar
Joined Oct 2009
the big-big-big update is coming, library of wings!
Internal reorganization to use multiple pages already done,
login (using facebook and twitter) already implemented.
So now 'only' the library itself is missing.
Old Sep 24, 2012, 07:21 PM
sdbruder is offline
sdbruder's Avatar
Joined Oct 2009
Follow up:
We already have a table of wings server-side and already can save a wing (with the upload of canvas image too) and already retrieve wings from the database, now Im 'teaching' the calculator the notion of unsaved, saved and already saved but modified.
Nothing fancy to screenshot this time, only the tabs /Design/ Your Wings / Library:
Old Sep 25, 2012, 12:20 PM
Stuart A is offline
Find More Posts by Stuart A
You know nothing....
Stuart A's Avatar
Joined Sep 2011
Originally Posted by sdbruder View Post
Some months without touching wingcgcalc now.
Any wish list for the wingcgcalc?
This is a really useful piece of work,many thanks.
You asked for a wish list- well here's one for you!Variable geometry
A fixed centre panel,with the same outer panel moved in 5* increments from zero to 50*
have fun
Best regards Stuart
Stuart A is offline Find More Posts by Stuart A
Old Sep 25, 2012, 01:53 PM
sdbruder is offline
sdbruder's Avatar
Joined Oct 2009
have fun
Best regards Stuart
Im trying to understand, you want variable geometry in the calculator? How?
Old Sep 30, 2012, 11:07 AM
Stuart A is offline
Stuart A's Avatar
Joined Sep 2011
Bit of a tongue in cheek request.I've been playing about with a variable sweep chuck wing,just to see if the concept is viable.Wingspan @15*sweep 150mm.It has a centre section,the wing panels hinged to this and manually moved to each sweep position.To find the centre of gravity at each sweep position I fixed the wing on the bench,measured the root and tip chords at each sweep position and put them into your calculator.I only used 15,27.5 and 40* for the flight trials,but plotted each position from 5-45*,to see if the change was linear(it was)It was whilst doing this that the idea of the calculator handling variable sweep came to mind.
As I said,not a serious request,thought the idea might interest you.
Regards Stuart
Discussion Clean Sweep - a 48" sportster with a swept forward wing! tim hooper Sport Planes 120 Nov 25, 2015 11:14 AM
Discussion canard w/ sweep forward wing for 6400 phil alvirez Scratchbuilt Indoor and Micro Models 31 Oct 08, 2011 04:05 AM
Question Tapered wing tip sweep- forward or back advantages/disadvantages??? Pauliwog Thermal 21 Jul 26, 2011 10:24 AM
Help! Scale ships with multiple wing panels erichj Scale Sailplanes 12 Mar 19, 2008 03:52 AM
Discussion CG calc for wing with multiple sweep angles rosco Modeling Science 13 Jan 09, 2008 04:35 PM
