Old Jun 02, 2012, 02:00 PM
sdbruder is offline
Find More Posts by sdbruder
sdbruder's Avatar
Brasil, PR, Curitiba
Joined Oct 2009
A sneak peak of what is coming:
sdbruder is offline Find More Posts by sdbruder
Old Jun 02, 2012, 02:03 PM
sdbruder is offline
sdbruder's Avatar
Joined Oct 2009
Originally Posted by cleansurf2 View Post
Awesome work sdbruder.
Your last post was going to be a suggestion, so excellent.
Any chance of making the sweep switch-able between angle (degrees) and mm ?
P.S. I tried several multi panel CG calcs a couple of months ago. Your's gave me the most accurate CG (which was confirmed with flight test CG tuning).
Wait for the next version, sweep in (mm,inches) or angle, per panel.
And keep sharing these wings designs.
http://wingcgcalc.bruder.com.br/
Old Jun 03, 2012, 02:13 AM
sdbruder is offline
sdbruder's Avatar
Joined Oct 2009
With the angle support, one more thing, measurement in the canvas:
EDIT And more to come:
EDIT2: evernote appears to have unreliable img servers (IMHO), going back to skitch:
Old Jun 06, 2012, 07:19 PM
Siliconserf is offline
Find More Posts by Siliconserf
Silicon Valley
Joined May 2010
And the ability to print the canvas along with calculation results. (Really nice job on this, by the way. Thanks for putting in the effort.)
Siliconserf is offline Find More Posts by Siliconserf
Old Jun 07, 2012, 02:12 AM
sdbruder is offline
sdbruder's Avatar
Joined Oct 2009
You sir are reading my mind:
Old Jun 12, 2012, 06:49 AM
sdbruder is offline
sdbruder's Avatar
Joined Oct 2009
V1.5 with measurement in the canvas And save as image png. http://wingcgcalc.bruder.com.br/
Old Aug 24, 2012, 11:45 AM
sdbruder is offline
sdbruder's Avatar
Joined Oct 2009
Any Wish list item?
Some months without touching wingcgcalc now.
Any wish list for the wingcgcalc?
Old Aug 25, 2012, 04:35 AM
chop stiX is offline
Find More Posts by chop stiX
how'd I do that....oh
chop stiX's Avatar
South Africa, GP, Pretoria
Joined May 2011
this is awsome.but how accurate is it with KFM airfoils?
chop stiX is offline Find More Posts by chop stiX
Old Aug 28, 2012, 10:41 PM
sdbruder is offline
sdbruder's Avatar
Joined Oct 2009
The MAC calculation is airfoil agnostic, it is based on the format of the whole wing, not the airfoil.
That said, the percentage ahead of MAC that we use as CG is airfoil-dependant (and parametrizable in my calculator), so you can adjust.
I have no personal experience with KFM airfoils, so anyone with more experience with KFM can jump in.
Old Aug 29, 2012, 12:02 AM
chop stiX's Avatar
Joined May 2011
KFM does definitely have an influence on the CG.hence me asking.though I'm sure it can be done correctly.i've used this calculator for quite some time now,before I knew about the thread
Old Sep 07, 2012, 03:01 PM
sdbruder is offline
sdbruder's Avatar
Joined Oct 2009
I need some help from you 'imperial' guys.
What are the common unit used to express wing loading if you are measuring your wing in inches? oz / inē ?
We metric people (the sane ones :-) ) use g/dmē.
Yes, Im adding wing load calculation to http://wingcgcalc.bruder.com.br/, it's too easy to not add.
EDIT: BZZZt, wrong, you imperial guys in airmodel wing load calcs normally uses ounces per square foot, oz/ft2.
Old Sep 07, 2012, 04:40 PM
sdbruder is offline
sdbruder's Avatar
Joined Oct 2009
v1.6 http://wingcgcalc.bruder.com.br/
ok guys, some minor corrections (ajax timeout, translations, etc) and one minor but useful feature: wing load calculation.
If the wing load field is not been calculated with the weight correctly filled, reload the page to force-download wingcgload.js (ctrl-R, cmd-R, whatever force-reloads your browser). I'll have a fix for that in the next version.
Old Sep 09, 2012, 03:09 PM
critx is offline
Find More Posts by critx
Cluj-Napoca
Joined May 2007
wing loading not calculated
I am not an active member on this forum but here I've found there is a trace of the CG calculator versions.
I am using Win 7 64bit and Chrome. If I enter a value in the Weight field the Wing Load field remains empty.
Is there something I am missing or do wrong?
Thanks for the wanderfull tool you have created!
Cristi,
critx is offline Find More Posts by critx
Old Sep 09, 2012, 03:16 PM
critx is offline
Cluj-Napoca
Joined May 2007
Ok. Now it works!
Old Sep 09, 2012, 10:51 PM
sdbruder is offline
sdbruder's Avatar
Joined Oct 2009
Originally Posted by coanda View Post
Ok. Now it works!
Your browser reloaded the correct javascript file now. The problem is know and the fix is simple, the new version will do it.
Discussion Clean Sweep - a 48" sportster with a swept forward wing! tim hooper Sport Planes 120 Nov 25, 2015 11:14 AM
Discussion canard w/ sweep forward wing for 6400 phil alvirez Scratchbuilt Indoor and Micro Models 31 Oct 08, 2011 04:05 AM
Question Tapered wing tip sweep- forward or back advantages/disadvantages??? Pauliwog Thermal 21 Jul 26, 2011 10:24 AM
Help! Scale ships with multiple wing panels erichj Scale Sailplanes 12 Mar 19, 2008 03:52 AM
Discussion CG calc for wing with multiple sweep angles rosco Modeling Science 13 Jan 09, 2008 04:35 PM
