Old Nov 24, 2011, 02:04 PM
sdbruder is offline
Find More Posts by sdbruder
sdbruder's Avatar
Brasil, PR, Curitiba
Joined Oct 2009
wing CG calculator (with multiple panels & forward sweep)
Ive used the excelent work of z80 in http://www.rcgroups.com/forums/showthread.php?t=973140 in the past,
but the limitations of one single panel and no forward sweep made me look for multi-panel CG calcs, and Ive found only very old windows programs.
Accustomed to the online and direct use of z80's tool, Ive decided to make my own online CG calculator, with forward sweep and multiple panels.
Its a 1.0 version, only metric for now. If you can ignore the area number showed to you, use it with the unit that you are used to, only be consistent (if using inches, use only inches in all measures, etcetera).
http://wingcgcalc.bruder.com.br/
TODO
Translation in brazilian portuguese (my native language);
imperial / metric switch;
deep-link of wings designs;
sdbruder is offline Find More Posts by sdbruder
Old Nov 25, 2011, 03:05 AM
DT56 is offline
Find More Posts by DT56
Joined Aug 2005
Thanks for the calculator Sdbruder!
DT56 is offline Find More Posts by DT56
Old Nov 25, 2011, 07:10 AM
sdbruder is offline
sdbruder's Avatar
Joined Oct 2009
Ive just learned that my calculator is completely broken with Internet Explorer 9 (I've used Chrome and Safari within development).
Until I have time to fix, don't use it with any IE browser.
Old Nov 25, 2011, 01:18 PM
sdbruder is offline
sdbruder's Avatar
Joined Oct 2009
v1.1
- brazilian portuguese and english versions;
- metric (millimeters) and imperial (inches);
- a little less broken in Internet Explorer (without CANVAS support you cant visualize the wing with Internet Explorer, you only get the numeric result);
Old Nov 25, 2011, 09:18 PM
birdofplay is online now
Find More Posts by birdofplay
Retired CAD guy
birdofplay's Avatar
United States, IN, Indianapolis
Joined Dec 2005
For forwaRD SWEPT WINGS CALCS
TRY Swapping the Tip and root dimensions !!!
Just put to tip size where the root goes and vicesersa.
Thai still does not fix the multi panel issue but GiveIt try !
Bob
birdofplay is online now Find More Posts by birdofplay
Old Nov 26, 2011, 06:51 PM
sdbruder is offline
sdbruder's Avatar
Joined Oct 2009
Bob
No need for that, you can use negative sweep values.
Old Dec 02, 2011, 11:00 AM
sdbruder is offline
sdbruder's Avatar
Joined Oct 2009
Nem version, v1.2, uploaded in /beta/ ( http://wingcgcalc.bruder.com.br/beta/ )
* Added About and History in end of the page;
* Proper internationalization with gettext support. If you want wingcgcalc in your language and can contribute ith the translation, please contact me;
* Options moved to the start of the measures forms, a few users didnt found the CG % with it the end;
* Popups implemented with little helper texts for each entry.
Any sugestions to better write the little helper texts in the popups per-field, Im all ears.
Old Dec 07, 2011, 09:42 PM
sdbruder is offline
sdbruder's Avatar
Joined Oct 2009
v1.2 now in production, moved from http://wingcgcalc.bruder.com.br/beta/ to http://wingcgcalc.bruder.com.br/ . The old version is still in /old/.
Old Dec 07, 2011, 10:59 PM
Outback Joe is offline
Find More Posts by Outback Joe
September 2010
Outback Joe's Avatar
United States, OR, Lakeview
Joined Oct 2009
WOW, very nice work! Thanks for sharing this with us. Working on a new wing tonight and used it for the CG on it.
Can this get a sticky also?
Outback Joe is offline Find More Posts by Outback Joe
Old May 24, 2012, 12:16 AM
sdbruder is offline
sdbruder's Avatar
Joined Oct 2009
new version of http://wingcgcalc.bruder.com.br, now with deep linking with automatic url shortening. Lets share these Wing designs!
Old May 28, 2012, 04:52 PM
sdbruder is offline
sdbruder's Avatar
Joined Oct 2009
After deep linking of wing designs, Im now working to better show you wing, part of what is coming:
Old May 29, 2012, 06:07 AM
cleansurf2 is offline
Find More Posts by cleansurf2
cleansurf2's Avatar
Australia (Newcastle)
Joined Mar 2009
Awesome work sdbruder.
Your last post was going to be a suggestion, so excellent.
Any chance of making the sweep switch-able between angle (degrees) and mm ?
P.S. I tried several multi panel CG calcs a couple of months ago. Your's gave me the most accurate CG (which was confirmed with flight test CG tuning).
cleansurf2 is offline Find More Posts by cleansurf2
Old May 29, 2012, 01:46 PM
sdbruder is offline
sdbruder's Avatar
Joined Oct 2009
v1.4
  • BUGFIX: the MAC calculation for multi-panel was wrong, corrected thanks to LaercioLMB from e-voo.com.
  • New display code and html arrange in the page now shows the whole wing.
The error in multi-panel MAC calculation was simple but severe: I was using the 'local' coordinates of MAC for each panel (i.e., each panel has his own (0,0) point) when what I needed was the global coordinate of each MAC. More information about the topic, sources of formulas and so on (in brazilian portuguese) in http://www.e-voo.com/forum/viewtopic.php?t=133753
To compare, the wing pictured above is http://j.mp/KP81Au
QUICK TIP: And to the people that didn't 'get' the way that Ive made 2 panels with different chords in that wing, Ive used a intermediate panel with 0 span in the middle of the 2 panels.
Now with the correct multi panel MAC calculation:
Old May 29, 2012, 11:24 PM
gazza2003au is offline
Find More Posts by gazza2003au
gazza2003au's Avatar
Sydney, Australia
Joined Jul 2003
this is my last wing i built its made from 4 piece cores u just use the standard CofG calculator to work out the CofG
gazza2003au is offline Find More Posts by gazza2003au
Old May 30, 2012, 10:36 AM
Zoltan Scotland is offline
Find More Posts by Zoltan Scotland
Joined May 2012
Great job sdbruder!
Simple, and easy to use
Thank you!
Zoltan Scotland is offline Find More Posts by Zoltan Scotland
Discussion Clean Sweep - a 48" sportster with a swept forward wing! tim hooper Sport Planes 120 Nov 25, 2015 11:14 AM
Discussion canard w/ sweep forward wing for 6400 phil alvirez Scratchbuilt Indoor and Micro Models 31 Oct 08, 2011 04:05 AM
Question Tapered wing tip sweep- forward or back advantages/disadvantages??? Pauliwog Thermal 21 Jul 26, 2011 10:24 AM
Help! Scale ships with multiple wing panels erichj Scale Sailplanes 12 Mar 19, 2008 03:52 AM
Discussion CG calc for wing with multiple sweep angles rosco Modeling Science 13 Jan 09, 2008 04:35 PM
