Old Nov 23, 2011, 05:20 PM
wopachop is offline
Find More Posts by wopachop
Joined Apr 2007
How small can i make CA hinges?
I have never used those little guys before. I bought a sheet from Great Planes. At the hobby shop i noticed the pre-cut CA hinges were huge. Way bigger than I imagined using. Memory guesses they were 3/4" wide.
This application is just a stryker elevon. But the elevons are 6mm depron. I cut a bevel in the elevon and used blenderm. But im not happy with the travel. I apply the tape with the elevon down but it still is a little sloppy for my taste. I need 4 hands to get it really tight.
So im gonna use CA hinges. Plan to epoxy them in to keep them flexy. Open to opinions on that.
Goal is to be super duper light weight. How small of hinge can i get away with? Maybe just use more of them? Since depron is flexible i thought having more hinges would stiffin it up.
wopachop is offline Find More Posts by wopachop
Old Nov 23, 2011, 07:56 PM
Wilfor is online now
Find More Posts by Wilfor
RC Adddict
Wilfor's Avatar
Canada, BC, Williams Lake
Joined Jan 2010
Sparks hinges on his toon planes are just between 1/8 to 3/16 " wide . 4 per side on around a 30" span http://www.rcgroups.com/forums/showp...5&postcount=30
Wilfor is online now Find More Posts by Wilfor
Old Nov 23, 2011, 08:16 PM
wopachop is offline
Joined Apr 2007
Super Cool!!!! Many questions got answered as i read.
Sparks huh.....he a sparky? I was for a bit. Commercial electrician.
Can you link the full thread or is it obvious how to see it? Im not sure how.
Old Nov 23, 2011, 08:23 PM
RC Adddict
Wilfor's Avatar
Joined Jan 2010
just click in the upper RH corner where it says Build Log : Cartoon Spitfire
Old Nov 23, 2011, 08:24 PM
poweredlawndart is offline
Find More Posts by poweredlawndart
Joined Aug 2004
Click on the upper right hand corner "return to thread" will take you where you want to go!
Listen to Wilfor...he be more smarter:!!!!!!!!!
poweredlawndart is offline Find More Posts by poweredlawndart
Last edited by poweredlawndart; Nov 23, 2011 at 08:46 PM. Reason: need to learn to read......
Old Nov 24, 2011, 08:36 AM
wopachop is offline
Joined Apr 2007
Ah thanks i will check it out.
Still like to hear from others if anyone wants to share their experiences with CA hinges.
How much penetration do they need?
Discussion Ca hinges , help gazzazh Beginner Training Area (Fuel) 11 Nov 03, 2011 12:52 PM
Discussion Ca hinges flylower Electric Plane Talk 23 Sep 29, 2011 10:17 AM
Discussion How well do EZ hinges work with foam safe CA bjaffee Slope 8 Aug 21, 2011 09:55 AM
Question Semi-profile HELLCAT: How can I make plans? greenseaships Foamies (Scratchbuilt) 24 Apr 14, 2011 01:06 AM
Discussion make your own "CA" type hinges? ave Slope 6 Feb 24, 2006 12:31 AM
