This thread is privately moderated by ShokWaveRider, who may elect to delete unwanted replies.
Old Nov 23, 2011, 01:36 PM
ShokWaveRider is offline
Find More Posts by ShokWaveRider
Trader Rating: 124
IMP Concepts 3D Printing
St. Augustine, Florida
Joined Sep 2006
Trader Rating: 124
Sold
Micro 3 Pin, .100" (2.54mm) ESC to Brushless Motor Connectors (Male & Female)
I just received these today. We use them on ESCs up to 10amp for an ultra light installation. Simply remove the stock wires and install the female to the ESC and the Male to the motor. They can easily be flipped to get the correct direction of rotation.
They are .100 of an inch Pitch (2.54mm) total Width is 8mm (Approx), they are rated at 4 amps per pin and have been tested way over 15amps with no issues, they do not even warm up. The more common 2mm Pitch equivalents do noy support these higher current requirements for micros with motors such as the 1811-2000kv (Motor Not included)
The Male is Gold Plated throughout and the Female has Gold Friction Inserts.
They are 3 pin friction fit connectors. Some ESCs come with the Female but the Male is quite difficult to get hold of.
I have included example photos of an installation on a HobbyKing 10amp ESC (ESCs Not included ) Because of the staggered connections wires were used. However, on small 5amp and 6amp ESCs like the HobbyKing Plush-6 or XP-7A they can be soldered directly to the PCB.
1 - Male 3pin Friction Fit connectors SOLD
1 - Female 3 Pin Friction Fit Connectors SOLD
Shipping CONUS will be $2.15 for 1 or more.
More on the way.
ShokWaveRider is offline Find More Posts by ShokWaveRider
Sold Micro 3 Pin, .100" (2.54mm) ESC to Brushless Motor Connectors (Male & Female) ShokWaveRider Aircraft - Electric - Multirotor (FS/W) 0 Nov 23, 2011 01:26 PM
Found Wanted: XT type Deans connectors, male and female. danford1 Aircraft - Electric - Power Systems (FS/W) 0 Aug 26, 2011 10:56 PM
Found 3 Tamiya Male Connectors, 1 Tamiya Female or 2 Female Deans Ultra Plugs Bohh33 Aircraft - Electric - Batteries & Chargers (FS/W) 2 Jan 10, 2008 09:13 PM
Sold New 6mm Gold Bullet Connectors $6 per pair(2 Female & 2 Male) Shipped xwingnut Aircraft - Electric - Power Systems (FS/W) 2 Sep 16, 2007 09:31 AM
jeti esc,female or male connectors? pancho Power Systems 2 Nov 26, 2005 05:06 PM
