Old Dec 31, 2011, 05:26 PM
corsair nut is online now
Find More Posts by corsair nut
fly like an EAGLE ;)
corsair nut's Avatar
tehachapi, CA
Joined Jan 2006
sweet fuzz! join the club!
http://www.rcgroups.com/forums/showt...8#post20282898
corsair nut is online now Find More Posts by corsair nut
Old Dec 31, 2011, 07:06 PM
TPfingston is online now
Find More Posts by TPfingston
Retired and Lovin' it!
TPfingston's Avatar
United States, KY, Sturgis
Joined Jul 2007
The little F-5 looks neat Fuzz. I'll be watching for it.
Tony
TPfingston is online now Find More Posts by TPfingston
Old Dec 31, 2011, 08:01 PM
Boogie_ is offline
Find More Posts by Boogie_
killed another thread
Boogie_'s Avatar
Lake Charles, Louisiana
Joined Jun 2009
F-5 fever must be in the air.
One of my posse came by the shop Friday with some plans for a big F-5. I think he's doing twin 90's.
RoV tiger stripe camo would be cool Fuzz.
J
Boogie_ is offline Find More Posts by Boogie_
Old Dec 31, 2011, 08:05 PM
tehachapi, CA
Joined Jan 2006
or a 12ft t38......
Old Jan 01, 2012, 07:46 AM
St. Martin is offline
Find More Posts by St. Martin
Big gov never Works
St. Martin's Avatar
Skunk Water, Rhode Island
Joined Jul 2002
Yea, I have been following the bohemoth T-38. To fit (2) 70mm fans: the exaust is 18mm now, x 3=54mm(doable). That gives a 72" LOA and a 39" WS. Or,I could use two 66mm, in the same size. I have a set of Eflite retracts. But probably too small for our field. I will most likely keep it bungee launch and real lite. Then I could get away with two 525W systems with (2)5s 1800's and 4W motors. 27A each.
About 10 yrs ago, they must have had a F5 squadron in Mass. I was fishing on a pond in norther RI, when two flew overhead. I could barely see them. They were around 5 thousand, and blended perfectly. What sticks in my mind, was how smooth and strait they flew. Seconds later, two more flew over at half the altitude. I did not know they were there, until they passed. This was shortly after 9-11. And there were many such sights, in the following weeks. Mostly F-16's.
I found a treasure trove of old kits, at a hobby shop in Poughkeepsie NY. Jemco, Easy built, Todays Hobbies, Some Sterling. Low prices too.
Fuzz
St. Martin is offline Find More Posts by St. Martin
Old Jan 01, 2012, 09:55 AM
tehachapi, CA
Joined Jan 2006
fuzz thats the exact same size as the twin 70 mm f5 i did! mine was 5.25 lbs with twin 450 w 70 mm setups...made from depron
Old Jan 01, 2012, 05:13 PM
Big gov never Works
St. Martin's Avatar
Joined Jul 2002
Hey Brent, I just remembered, I owe you an A-4 canopy. Sorry. I'll get it to you.
Yes..6' is a good size Jet. Probably the biggest since my IC days and Byrons.
Fuzz
Old Jan 01, 2012, 06:28 PM
AIR SALLY is online now
Find More Posts by AIR SALLY
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
sounds big but its just long and skinny
AIR SALLY is online now Find More Posts by AIR SALLY
Old Jan 07, 2012, 08:47 PM
Boogie_ is offline
Boogie_'s Avatar
Joined Jun 2009
Making progress on the Coug.
All the glassing is done and I started cutting out the gear doors. I did learn one thing, I suck at cutting out gear doors.
They're gonna work fine but the gaps are much bigger than I was shooting for.
Inboard doors still need to be glued to the hinges.
Old Jan 08, 2012, 07:30 AM
Big gov never Works
St. Martin's Avatar
Joined Jul 2002
You'll do better next time, Julian. It's like anything else..the more you do it, the better you'll get. Nobody will notice these things, when it in the air and retracted.
Fuzz
Old Jan 09, 2012, 06:29 PM
Kevin Cox is offline
Find More Posts by Kevin Cox
EDF Jet Jam 2016, June 16-19
Kevin Cox's Avatar
St. Louis Intl, Missouri, United States
Joined Jan 1997
Looks good to me!!
Kevin Cox is offline Find More Posts by Kevin Cox
Old Jan 10, 2012, 05:08 PM
Boogie_ is offline
Boogie_'s Avatar
Joined Jun 2009
Thanks for that guys.
The past few days I've been studying gear doors on various builds. Almost all are thin FG doors. I should have (and may still) made some out of some heavy cloth instead of glassing mine inside and out. The thicker the door, the harder it is to get it past the edge of the fuse when it swings open.
But like Fuzz said I'll be the only one who notices.
Anyhoo, woke up kinda bummed this morning after watching LSU get it's ass kicked last nite.
But! got to the shop and installed the fan and did a test run up.
Spun the ARC 48-1.5 to 1212 watts @ 64A on 5s. Really happy with those numbers.
Duct work didn't flex a bit, solid as a rock.
And my earlier weight check was way off.
While I had the fan in, I taped in all the servos, landing gear and hardware and put it on the scale. AUW is 4.5 lbs.
Only thing missing there is the pilot, canopy & paint.
And I still haven't even sanded the raw glass/resin yet. That will probably negate the weight of the paint.
Earlier I had weighed all the components separately and must have made a mistake adding it all up. Finally an error that breaks my way.
Should have the maiden before the month is out...
J
Old Jan 11, 2012, 04:01 AM
Big gov never Works
St. Martin's Avatar
Joined Jul 2002
Those are good numbers for that power combo, Julian. I get from 1075(minifan), 1150(het) 1210(WM400) on a 5s 35c 3000. The nice thing is the low amps to get that number.
Fuzz
Old Jan 11, 2012, 12:01 PM
Lmeano_from_MO is offline
Find More Posts by Lmeano_from_MO
Fast Jets for Fast times
Lmeano_from_MO's Avatar
St. Peters MO.
Joined Nov 2007
J,
The gear door look great and a little extra room never hurts. I am close to looking into the same on the tiger and ordered every hinge available for HK, I think it totaled about 10 bucks for a life time supply. Are you using servos to actuate them or fishing line and spring hinge? I would like to see more detailed shots of what you’re thinking if possible.
Lmeano_from_MO is offline Find More Posts by Lmeano_from_MO
Old Jan 11, 2012, 06:41 PM
Boogie_ is offline
Boogie_'s Avatar
Joined Jun 2009
That's what surprised me. I'm pullin' that much in my F-100 on 4s makin' 700-800w.
I think it's the short, straight shot ducting.
I'm putting a servo on each door and using this gear door sequencer.
It's really cool (& cheap). And for $3 bucks a servo, rigging up springs and pull strings seems like a lot of work.
The sequencer is almost a must on my Coug though, 'cause the inboard main gear doors are taller than the LG and have to close before it can land.
These are the hinges I used. Along with these horns to attach the push rod.
Like you I also ordered these too. But they are huge. Too big for my plane.
I'm prepping for painting now but I'll get some shots of my set up as soon as I can.
In the mean time, look through some of the pics 90mm composite jet build threads in the ARF EDF section. I picked up a bunch of ideas there.
J
For Sale HET F-18 Balsa not Foam 3DTRYER Aircraft - Electric - Jets (FS/W) 7 Jan 02, 2012 10:10 AM
Build Log F-9F Cougar 70mm (the fun way) Boogie_ Electric Ducted Fan Jet Talk 18 Nov 18, 2011 08:34 PM
Question What size motor foam AgCAt scratch build! RedTwilight Foamies (Scratchbuilt) 1 Oct 18, 2011 11:17 PM
Help! Scratch Swift S1 Foam/Balsa. (Image Resize Swift) Ugly Duckling Foamies (Scratchbuilt) 40 Oct 05, 2011 02:21 PM
Build Log F-9F Panther/Cougar build logs Mk.I (70mm) Willmsy Electric Ducted Fan Jet Talk 26 Mar 11, 2009 12:23 PM
