Old Nov 26, 2011, 09:08 PM
Bare is offline
Find More Posts by Bare
Canada
Joined Nov 2000
looks darn good so far, despite humble origins.
I've an Aerographics Me 163 @16+" span that is tempting me to retrofit a wee BL motor. (if not built an Aerographics yer missing something, decent quality printwood And the parts actually fit.. perfectly. Nice Kits ..seriously recommended )
I figure if yours flies well, then my 163 is gonna see air time whether it wants to or not :-)
Bare is offline Find More Posts by Bare
Old Nov 27, 2011, 12:59 AM
Onna Vakkation is offline
Find More Posts by Onna Vakkation
United States, PA, Grove City
Joined Jan 2011
Originally Posted by glewis View Post
Thanks Dave,,, I think....
Seeing where the CG is on your 190 is a big help. I might have to use a bigger battery if the model proves to be tail heavy.
BTW, welcome to rc groups! Glad you finally joined in the party.
Glenn
If not bigger, maybe the location may be a bit unorthodox, such as breaking up a 2 cell and having the cells right inside the cowl, on either side of the motor. Hopefully not, but it was the point I was at, with light sheeted version. The larger one does well with the batt against the firewall though, which should hopefully scale in the same fashion for your lighter tailed version.
The aileron torque rod setup looks good. I've certainly gotten my money's worth out of small aluminum tubing.
Bill
Onna Vakkation is offline Find More Posts by Onna Vakkation
Old Nov 27, 2011, 01:55 AM
gupi is offline
Find More Posts by gupi
Balsa Lover
gupi's Avatar
Vienna, Austria
Joined Jul 2010
Very nice work on that ailerons! I like the hinge you did, unfortunately i can't use the same technique on my Scout i'm converting.
gupi is offline Find More Posts by gupi
Old Nov 27, 2011, 01:06 PM
glewis is online now
Find More Posts by glewis
Or current resident
glewis's Avatar
USA, FL, Tampa
Joined Jul 2002
Bill, I plan on mounting the battery in the cowl below the motor like I did on the Hellcat. The Hellcat still needed a few grams of clay packed into the front of the cowl to bring the cg forward.
Gupi, thanks man, the aileron setup has evolved over the span of many models.
The heat shrink tube pivot works great and is easy to make.
Glenn
glewis is online now Find More Posts by glewis
Old Nov 27, 2011, 01:35 PM
ausf is offline
Find More Posts by ausf
ausf's Avatar
United States, NY, CENTRAL VLY
Joined May 2011
That heat shrink pivot is ingenious. I spent way too much time adjusting a metal pivot for flaps on a UM P-51, that little gem would have been so much easier.
Do you find the aluminum tube more effective than just music wire?
ausf is offline Find More Posts by ausf
Old Nov 27, 2011, 02:14 PM
Or current resident
glewis's Avatar
USA, FL, Tampa
Joined Jul 2002
I can't take credit for the heat shrink idea, I snagged it from somewhere.
It is a whole lot easier to set up than my original method of bending the ends of the torque rod levers into a loop. A plastic bushing was glued into the loop to prevent metal to metal contact.
The aluminum tube is much stiffer in torsion than wire of the same weight.
Old Nov 27, 2011, 02:43 PM
Or current resident
glewis's Avatar
USA, FL, Tampa
Joined Jul 2002
Motor mount
The motor mount rails are cut from 1/4" square. Holes are drilled in the rails for the gearbox pins to fit into.
The prop shaft was removed from the gearbox and a piece of wire slid into the bushings acting as an extended shaft to help with alignment.
A hole the size of the wire is drilled in the firewall a little left and up from the exact center.
Now the mount rails are stuck onto the gearbox pins and the extended wire alignment shaft is inserted into the hole in the firewall.
Next the rails are angled to give down and right thrust and glued to the firewall with enough offset so the prop shaft is centered in the cowl opening.
A couple of gussets are added to tie it all together.
Glenn
Old Nov 27, 2011, 09:16 PM
Or current resident
glewis's Avatar
USA, FL, Tampa
Joined Jul 2002
Tail feathers
Pretty standard stuff here.
The horizontal stab was narrowed to a more scale appearance.
Vertical stab is made up using a laminated outline. The form was cut from scrap Dollar Tree foam. The outline is laminated using 4 strips of 1/16 x 1/32".
Old Nov 28, 2011, 08:56 PM
Or current resident
glewis's Avatar
USA, FL, Tampa
Joined Jul 2002
Almost ready for covering.
Old Nov 28, 2011, 09:53 PM
danrc is offline
Find More Posts by danrc
danrc's Avatar
Rockford Illinois
wow! you're fast!
danrc is offline Find More Posts by danrc
Old Nov 29, 2011, 05:26 AM
LenBFP is offline
Find More Posts by LenBFP
It's a Great Day to Fly
LenBFP's Avatar
Melbourne Beach, Florida
Joined Jan 2002
Lookin fine Glenn.
LenBFP is offline Find More Posts by LenBFP
Old Nov 29, 2011, 11:58 AM
3d astronaut is offline
Find More Posts by 3d astronaut
3d astronaut's Avatar
United States, MI, Kalamazoo
Joined Sep 2011
oh dont mind me just subscribing/admiring
3d astronaut is offline Find More Posts by 3d astronaut
Old Nov 29, 2011, 08:02 PM
Or current resident
glewis's Avatar
USA, FL, Tampa
Joined Jul 2002
Started covering. Kit tissue attached with thinned white glue brushed on.
The tissue is water shrunk then given two coats of dope. I've found two coats is the minimum for moisture resistance.
Glenn
Old Nov 29, 2011, 08:09 PM
Or current resident
glewis's Avatar
USA, FL, Tampa
Joined Jul 2002
Missed responding to your post Bare.
A micro 163? That will be cool!
I'll check out aerographics, thanks for the tip.
Glenn
Old Nov 29, 2011, 08:32 PM
daddyrabbit1954 is offline
Find More Posts by daddyrabbit1954
A posse ad esse
United States, FL, Tampa
Joined Feb 2011
Glenn
Man, this thing sure is purdy. Can't say I have ever seen a cleaner, neater ultra micro build than this one.
Quick question about thinned white glue for tacking down the tissue: will the bond be affected by later coats of lacquer or dope?
Craig
daddyrabbit1954 is offline Find More Posts by daddyrabbit1954
Discussion Guillows 406 FW-190 Options jace314 Scale Kit/Scratch Built 9 Jun 25, 2011 07:59 PM
For Sale Guillows Fw 190, Zero kits NIB $25 ea. sgonzo Aircraft - Electric - Airplanes (FS/W) 1 Jun 20, 2011 10:32 PM
Help! FW-190 Guillow's Conversion (kit 502) QasimZ. Scale Kit/Scratch Built 2 Mar 07, 2011 08:25 AM
Guillows FW-190 17" Conversion mlbco Scale Kit/Scratch Built 23 Dec 05, 2003 09:11 AM
Doing a Guillows FW-190 Conversion and... mars Scale Kit/Scratch Built 50 Apr 04, 2002 05:28 PM
