This thread is privately moderated by dome78, who may elect to delete unwanted replies.
Old Nov 23, 2011, 01:14 AM
dome78 is offline
Find More Posts by dome78
United States, CA, Mountain View
Joined Jul 2004
Data
Multiplex Fun Cub
My Fun Cub configuration
NTM Prop Drive Series 35-36A 910Kv / 350W
12 x 6e APC = 330W on 3s
40 amp plush controller
Spektrum AR6110e -> later upgraded to Orange 9CH with additional UBEC 5A
2 Hitec 81MG for elevator/rudder
4 HXT900 for flaps and ailerons
and some lights
DX7 mixing
mixing flaperons to flaps:
Gear -> Aileron -0/+40 on flap2
Gear -> Gear 0/-80 on flap2
Mixing flaps to as ailerons:
Aile -> Aux2, +20/+20 on flap0
Aile -> Flap, -20/0 on flap0
dual ailerons:
aile -> gear, +100/+100
dual flaps:
flap -> aux2, +100/+100
Elevator flap mixing:
Flap 20% deployed -> elevator 18 down
Flap 100% (90 deg) -> elevator 40 down
dome78 is offline Find More Posts by dome78
Old Feb 24, 2012, 11:32 PM
dome78 is offline
Joined Jul 2004
Went back to the AR6110e. The Orange 9ch RX seems very prone to brownouts even with 5A UBEC. Had brownouts about every 5th flight.
Old May 05, 2012, 03:26 PM
dome78 is offline
Joined Jul 2004
Upgraded motor to a Scorpion 3014-830. 50 W more power with about the same weight and prop.
Old Aug 11, 2012, 12:42 AM
tobermei is offline
Find More Posts by tobermei
Mt Tamborine, Queensland, Australia
Joined May 2008
What size battery do you use? What flight times do you get with it?
tobermei is offline Find More Posts by tobermei
Old Aug 11, 2012, 01:06 AM
dome78 is offline
Joined Jul 2004
I normally fly a good selection of 1000(45C)/1300(45C)/1600(35-50C)/1800(30-40C)/2200(25-50C) mAh 3s. The 1000 mAh really is pushing it and voltage drops despite the high C rating. I only use that one for no wind conditions and keep the throttle low. For my setup I think the sweet spot is between the 1800 and 2200 depending on the wind conditions.
I guess I get 8 -15 minutes out of them. I do usually mixed flying of acrobatics, occasional hover and slow and low (expect on the 1000-1300s)
Old Aug 11, 2012, 01:16 AM
tobermei is offline
Joined May 2008
Old Feb 24, 2013, 02:08 AM
dome78 is offline
Joined Jul 2004
So I went to another motor an thought I share my experience with now three different motors on 1000+ flights with my FunCub.
Started off with a Turnigy D3536 910 kV
On a 12x6 APCe on 3S fresh pack 330 Watts wot. Goes vertical, somewhat slow out of a hover. Motor + prop weight approx 140g
Needed more oomph for 3D: Went to a Scorpion SII 3014-830 kV
On a 13x6.5 APCe on 3S fresh pack 370 Watts wot. Goes vertical quite well, pushes nicely out of a hover. Somewhat lacks end speed but tons of torque with minimal takeoff roll. Motor + Prop weight 175g
For slightly more end speed finally just went to a Turnigy D3536 1000 kV
On a 12x6 APCe on 3S fresh pack 350 Watts wot. Similar to the Scorpion. Higher end speed and slightly better vertical with ever so slightly increased takeoff distance. Motor + Prop weight 140g.
My personal preference is the 3536 1000 kV balancing thrust, speed and weight.
Sold for sale multiplex fun cub rtf 150 shipped lazyvida Aircraft - Electric - Airplanes (FS/W) 11 Nov 19, 2011 08:04 AM
Sold Multiplex fun cub $120.00 obo JDsF16 Aircraft - Electric - Airplanes (FS/W) 0 Oct 16, 2011 12:01 PM
For Sale Multiplex Fun Cub Dunedinflyer Aircraft - Electric - Airplanes (FS/W) 5 Sep 23, 2011 03:21 PM
Sold Multiplex Float Set Fun CubEasy Cub DuaneV Aircraft - Electric - Airplanes (FS/W) 1 Sep 21, 2011 09:31 PM
Sold Multiplex Fun Cub ARF, $75.00 shipped porcia83 Aircraft - Electric - Airplanes (FS/W) 4 Sep 13, 2011 05:55 PM
