Old Nov 22, 2011, 08:47 PM
jahel is offline
Find More Posts by jahel
United States, FL, Clearwater
Joined Jun 2011
Build Log
12.25'' Bandit 25mm EDF
Hi,finally started my official micro edf jet,after few planes this was what convinced me,build from scaled down and modified plans by Jetset44.
build materials;
- 1/16 balsa
- 1mm depron
- 1mm carbon rod
my weight goal is between 45 to 55g w/o batt
setup;
EDF- 25mm edf 1015 HK inrunner (with cooling holes)
ESC- 10A (low timing)
RX- HK orange (lightened to 1.7g)
SERVOS- HK 1.7g
BATT- under test...
jahel is offline Find More Posts by jahel
Old Nov 22, 2011, 08:50 PM
nomad68 is offline
Find More Posts by nomad68
nomad68's Avatar
United States, CO, Craig
Joined Nov 2007
jahel looks good will be watching this one
nomad68 is offline Find More Posts by nomad68
Old Nov 22, 2011, 08:53 PM
jahel is offline
Joined Jun 2011
more pictures
Old Nov 22, 2011, 09:02 PM
jahel is offline
Joined Jun 2011
custom motor heatsink..???? will be affected the thrust? test coming soon
Old Nov 22, 2011, 09:41 PM
jahel is offline
Joined Jun 2011
Thanks!
Old Nov 23, 2011, 06:18 AM
jahel is offline
Joined Jun 2011
Pics...
Old Nov 23, 2011, 11:52 AM
jahel is offline
Joined Jun 2011
I am anticipating about 45g to 55g w/o batt .and its 40.5g!!!
Old Nov 23, 2011, 02:05 PM
0011000011001 is offline
Find More Posts by 0011000011001
byte me!
0011000011001's Avatar
Joined Aug 2008
IMO that heatsink is way too big,it will most definitely affect the amount of thrust.Even if youre using 3s on that motor you wouldnt REALLY need the heatsink, just very good throttle management.
The jet looks awesome! very nice job
0011000011001 is offline Find More Posts by 0011000011001
Old Nov 23, 2011, 02:18 PM
jahel is offline
Joined Jun 2011
I do few thrust tests..(with and without) have about 4g lost...
Old Nov 23, 2011, 04:09 PM
hanzie is offline
Find More Posts by hanzie
Fear me, I'm a space-duck.
hanzie's Avatar
Joined Nov 2011
what is the weight of the heatsink? does the motor get hot when at full throttle whithout it? if not, it is not really neccesairy. then you can save the weight and the loss of thrust by not using the heatsink.
hanzie is offline Find More Posts by hanzie
Old Nov 23, 2011, 04:36 PM
jahel is offline
Joined Jun 2011
The heatsink weight about 2g..
Edf static thrust 52g with heatsink
Old Nov 23, 2011, 06:08 PM
Slaanesh is offline
Find More Posts by Slaanesh
Not enough hours in the day
Slaanesh's Avatar
Melbourne
Joined Feb 2009
Looks nice!
I assume you are running it on 3S then?
Slaanesh is offline Find More Posts by Slaanesh
Old Nov 23, 2011, 08:52 PM
jahel is offline
Joined Jun 2011
Originally Posted by Slaanesh View Post
Looks nice!
For now Thunder Power 250mAh 3s
Old Nov 24, 2011, 08:14 PM
silasgroats is offline
Find More Posts by silasgroats
silasgroats's Avatar
Joined Aug 2011
looking great jahel !!
Just in case you didnt know
the rounded inlet lip needs to be where the air go's in at the front
and not on the fan itself ,you want a smooth transition all the way
to the fan from the start of the duct .
good luck
dan
silasgroats is offline Find More Posts by silasgroats
Old Nov 24, 2011, 08:38 PM
jahel is offline
Joined Jun 2011
I think in this... 3s
Discussion 3 channel 1/48 scale MiG 15 with 25mm EDF! Joe Malinchak Micro EDF Jets and Power Systems 5 Nov 30, 2011 07:13 AM
For Sale BVM Bandit EDF Pandissix Aircraft - Electric - Jets (FS/W) 0 Oct 24, 2011 01:47 PM
How much prep before winding GB 25mm 12 pole Stator? OmegaDot Power Systems 13 Mar 14, 2005 01:33 PM
How many turns?for 12 pole,25mm motor Sentella Power Systems 5 Nov 23, 2004 05:29 PM
How many turns for a 12 pole cd rom 25mm motor? Sentella Power Systems 1 Nov 20, 2004 05:00 PM
