Old Nov 22, 2011, 05:27 PM
fmkit is offline
Find More Posts by fmkit
fast
fmkit's Avatar
ISRAEL
Joined Aug 2007
New Product
U-link uhf lrs
new LRS has been tested /flown tens of hours and now I'm about to order production quality boards. Still have time to change looks and functions if asked.
Because many FPVers today use autopilots andflight controller boards that expect PPM input I've made small board that has single connector to input or output PPM. When power applied the circuit checks the connector for incoming PPM, if signal detected TX function assumed till next power cycle.
If no PPM then board try to init. Wii Nunchuck if found then it is TX again.
If no nunchuck present RX function starts and PPM input becomes output. There are no switches or PC connection, automatic mode selection , to set frequencies and program repeater function connect Nunchuck and input series of clicks using "C" button the same way as some of you programmed RF beacons.
The system works best without PPM - nunchuck is polled 270times per second and as many packets transmitted with frequency hopping each packet.
Telemetry transmitted 4Hz, channels res.1/512, module powered by 1S Li-Po, current drawn 120mA.
With the system 2 pilots can control one plane even if miles apart, the RX can track both remotes and give other pilot priority if 1st pilot has stick centered. You can hand 2nd remote to anyone to fly your plane and overtake control any moment with your controller.
Final board may look a bit different, those can't wait PM me, I have about 20 prototypes that work excellent, you only need to solder 4 wires your own nunchuck connector or use servo plug to input /output PPM and power to fly the boards, $60/each, two identical boards make link.
Telemetry receiver is a standalone module with 2X16 character LCD. I 'll picture it later.
Available modules 400-470, 800-900 and 900-930MHz.
fmkit is offline Find More Posts by fmkit
Old Nov 22, 2011, 06:06 PM
emadine is offline
Find More Posts by emadine
Joined Sep 2011
Can I know what is the range ?
emadine is offline Find More Posts by emadine
Old Nov 22, 2011, 06:12 PM
fmkit is offline
fast
fmkit's Avatar
ISRAEL
Joined Aug 2007
depends on how high you locate repeater ,
with 3 repeaters in line you can break distance world record
using only 0.1W per repeater
Old Nov 22, 2011, 06:42 PM
emadine is offline
Joined Sep 2011
With just two board, one on quad and one in hand. What is the est range.
Old Nov 22, 2011, 06:55 PM
fmkit is offline
fast
fmkit's Avatar
ISRAEL
Joined Aug 2007
I fly with the module built into nunchuck so wire antenna is normally hanging just 3ft above ground and get 1km 100% packets received and and it starts to degrade at about 1.5km. Similar results getting Flytron, 2 other russian designed systems using the same RFM22B modules. My system is easiest to use and has functionality not seen in other systems, most responsive(lowest latency) of them all and can work w/ nunchuck and multiple repeaters.
Old Nov 22, 2011, 06:58 PM
chatch15117 is offline
Find More Posts by chatch15117
United States, FL, Maitland
Joined Apr 2011
this looks great. subbed.
chatch15117 is offline Find More Posts by chatch15117
Reply With Quote  (Disabled)
Old Nov 22, 2011, 07:10 PM
mark hitchman is offline
Find More Posts by mark hitchman
Zephyr 66" Blunt
mark hitchman's Avatar
New Zealand
Joined Sep 2009
If you fly with the nun chuck, is it possible to alter servo throws or do you do that mechanically on the plane?
Mark
mark hitchman is offline Find More Posts by mark hitchman
Old Nov 22, 2011, 07:18 PM
emadine is offline
Joined Sep 2011
Hello fmkit thanks for ur reply. One last qns. A single board can act as a repeater or need two board connect together to form TX/RX set?
Old Nov 23, 2011, 05:39 AM
fmkit is offline
fast
fmkit's Avatar
ISRAEL
Joined Aug 2007
Mark
yes, nunchuck itself can only config. frequencies and accelerometers zero.
rest of setting done in RX and throws set mechanically.
this way nunchucks easily swapped.
emadine, each board is rx and tx, repeater is simplest function that require no connections other than 1S Li-Po. Just one board makes repeater. It is waiting for packet and transmitting received packet immidiately on the same frequency packet was received cause nunchuck change frequency every packet making room for repeater.
Old Nov 25, 2011, 05:05 PM
FpvKiwi is offline
Find More Posts by FpvKiwi
Up up and away!
FpvKiwi's Avatar
Sweden
Joined Oct 2010
This is a cool product!
The repeater function is innovative but probably not something most people will use. Anyway imagine putting a repeater on another plane halfway.
Just like OpenLRS, using the term "LRS" gives wrong expectations: You need an amplifier or repeater for U-link to be long-range. I would like to know more about options for amplifier without going to extremes like 7 watts.
Would it be possible to place a repeater nearby with amplification to achieve moderate long range? That could help against a 0.5W signal close to the ground station disturbing the video reception.
What about Rx RSSI?
If you don't mind me asking, how big capacitor did you judge necessary in the aircraft to protect against voltage dips? Do you think tantal is ok?
The nunchuck is polled with 270hz but the Rx can't output PPM this fast, right? Do you have an alternative way of controlling the servos?
I think U-link would go well together with Channel Wizard that can decode PPM to servo signals. Throws, neutral and reversing are adjustable for each servo. The "Eight" version decodes 8 channels. "Mini" decodes 4 channels and has I2C for future features. (Maybe updating channels faster than PPM can?)
Both devices can be daisy-chained to decode different channels in different parts of the plane.
It can also act as PPM encoder (for DIY'ers) to feed the transmitting U-link.
FpvKiwi is offline Find More Posts by FpvKiwi
Old Nov 25, 2011, 06:08 PM
fmkit is offline
fast
fmkit's Avatar
ISRAEL
Joined Aug 2007
Just like OpenLRS, using the term "LRS" gives wrong expectations: You need an amplifier or repeater for U-link to be long-range.......
I'm sure no other LRS can compete low power nunchuck working with 2-3 repeaters. I'm advanced class HAM used repeaters from the day I got callsign 20 years ago ,
sure, repeater can be placed at any distance
What about Rx RSSI?
wristwatch-like telemetry module outputs RSSI, packets received, voltage, amps, time, stick position, master/slave status and alarms.
Cypress chips and RFM22B can operate down to 2.4v supply, normally I combine UBEC and BEC voltages with diodes so flight-controller functional while ESC plugged or not. 22uF cap.is enough.
I have 3 types of flight-controllers that have been in use for 2 months and completly tested. They interface nunchucks only, because normal remotes don't have enough channels to control gyros, cruise, lights and fireworks igniters, multi-presets pan/tilt, multimaster,power LEDs.
PPM is slow and limited to few channels, I'm not using PPM at all
Look here about using nunchuck with the flight controller
There are more key combinations that I don't remember myself, the nunchuck can transmit packets as well PPM to use UHF walkie-talkies as RX.
Here some old pictures, tomorrow I make better pics.
1st version of telemetry module:
1st version RX:
diy fun:
Old Nov 25, 2011, 06:55 PM
CrashMeUp is offline
Find More Posts by CrashMeUp
Crashomatic
CrashMeUp's Avatar
United States, CA, SF
Joined May 2010
need supply of RXs on your paypal page ;D
isee you're going to produce quite a few, thats cool
CrashMeUp is offline Find More Posts by CrashMeUp
Old Nov 28, 2011, 12:45 PM
FpvKiwi is offline
Up up and away!
FpvKiwi's Avatar
Sweden
Joined Oct 2010
Thanks for your reply, fmkit.
If you want to spread the system, PPM is good since it's in common use. The relative lack of speed doesn't matter for everyone. Certainly only a few channels benefit from high update rate.
Have you published any info about your flight controllers? I can't find any. Is it the pic "1st version RX"? But that looks integrated with the radio module.
Old Jan 07, 2012, 11:48 AM
LukeZ is offline
Find More Posts by LukeZ
LukeZ's Avatar
Joined May 2001
I agree that PPM is not the best transmit scheme but at the same time many people probably do not want to learn to fly with Nunchuck controller if they are very comfortable with standard radio transmitter.
Would there be some way to wire at least the four stick potentiometers from a regular TX directly to Nunchuck board, bypassing pots in the Nunchuck controller somehow?
Or do you have any other thoughts about integrating this system with a standard RC transmitter? I think the idea is brilliant and well executed, I just don't want to fly with a Nunchuck.
Luke
LukeZ is offline Find More Posts by LukeZ
Old Feb 21, 2012, 09:59 PM
Crashomatic
CrashMeUp's Avatar
Joined May 2010
Hey Peter,
I was wondering, now that the page is up: what advantages do you get with the 423mhz SAW filter (video interferences?), and is it low or high pass?
I'm actually going to get one once you reply to that :P
also, you should make a price rx+tx :P
Thanks!
Sold Dragon Link UHF LRS Brand New rclab1 FPV Equipment (FS/W) 2 Oct 19, 2011 06:58 PM
Sold [VDS]LRS thomas scherrer UHF + 2 receivers long range LTS49 FPV Equipment (FS/W) 8 Jul 22, 2011 03:55 PM
Question UHF LRS Pro Antenna Question CageHound FPV Talk 4 Apr 04, 2010 09:47 AM
Discussion For Sale: Spektrum DX7 for use with UHF/LRS jeff1068 FPV Talk 0 Mar 31, 2010 07:24 PM
Discussion Scherrer UHF LRS x Futaba 12FG/R6014FS Cr_Conrado FPV Talk 2 Dec 20, 2009 07:35 AM
