Old Jul 10, 2012, 09:10 AM
electricrc68 is offline
Find More Posts by electricrc68
The Sweet Aroma of Fuel
electricrc68's Avatar
United States, PA, Downingtown
Joined May 2011
Oh nice! Thanks! Also, how did you mount the motor to the plane as a pusher?
electricrc68 is offline Find More Posts by electricrc68
Old Jul 10, 2012, 09:31 AM
balsa or carbon is online now
Find More Posts by balsa or carbon
Hot glue held together by foam
balsa or carbon's Avatar
United States, OR, Portland
Joined Aug 2010
That motor comes with a stick mount . Attach an appropriate size stick 3 or 4 inches long into the stick mount , then hot glue and tape it to the plane with the prop ON the motor so the prop will be straight and centered in the slot . The numbers/writing on the prop should face the front of the plane , then check for the correct turning direction , If it's going the wrong direction , just switch any two of the three wires going from the ESC to the motor .
balsa or carbon is online now Find More Posts by balsa or carbon
Old Jul 10, 2012, 09:53 AM
Joined May 2011
Oh okay thanks. Just one question...sorry; what is a stick mount?
Old Jul 10, 2012, 11:11 AM
aventhu is online now
Find More Posts by aventhu
Indianapolis, In
Joined Jan 2010
These
http://www.headsuprc.com/servlet/the...ck-with/Detail
aventhu is online now Find More Posts by aventhu
Old Jul 10, 2012, 11:49 AM
Joined May 2011
Oh okay thanks.
Old Jul 10, 2012, 12:53 PM
Joined Aug 2010
The type of stick mount that motor from Hobbypartz comes with has a heat sink ( the part with the cooling fins sticking out ) that clamps on to the motor , and another square hole that clamps on to a stick , which is then attached to the plane . If you look at the video on that ( Hobbypartz ) page , you'll see a close-up of the motor/mount/stick etc.
http://www.hobbypartz.com/60p-dy-1006.html
Old Jul 10, 2012, 12:57 PM
Joined May 2011
Ah okay thanks.
Old Jul 10, 2012, 05:15 PM
Joined May 2011
Oh cool thanks! Is that how you had them mounted on your DTD?
Old Jul 10, 2012, 07:25 PM
Joined Aug 2010
Yes . Works great for smaller , slower planes that have smaller control surfaces .
Old Jul 10, 2012, 10:18 PM
Joined May 2011
Okay cool thanks!
Old Jul 10, 2012, 10:35 PM
Joined May 2011
Hey one more question. How did you get elevons to work on this plane? Im new to even elevons, so im not sure if you have to use a special y harness, or program the radio?
Old Jul 11, 2012, 12:34 AM
Joined Aug 2010
What kind of radio do you have ?
Old Jul 11, 2012, 08:44 AM
Joined May 2011
I have the spektrum DX7s.
Old Jul 11, 2012, 09:04 AM
Joined Aug 2010
That radio will do elevon mixing . Let me know when you're ready to set it up and I'll walk you through it .
Discussion black vs white dollar tree foam unbroken23 Foamies (Scratchbuilt) 11 Jul 23, 2012 12:04 PM
Discussion Bulk Readi-Board (Dollar Tree foamboard) shipped directly to you? ExperimentalAir Foamies (Scratchbuilt) 15 Feb 05, 2012 01:38 PM
Yippee! Dollar Tree: We Finally Got One Here!!!! NEW222 Foamies (Scratchbuilt) 36 Dec 20, 2011 01:47 PM
Discussion Has anyone used this foam from the Dollar Tree? bagofbones11 Foamies (Scratchbuilt) 6 Nov 29, 2011 05:04 PM
Discussion Bulk Readi-Board (Dollar Tree foamboard) shipped directly to you? ExperimentalAir Foamies (Scratchbuilt) 4 Oct 28, 2011 11:41 AM
