Old Nov 22, 2011, 02:50 PM
balsa or carbon is offline
Find More Posts by balsa or carbon
Hot glue held together by foam
balsa or carbon's Avatar
United States, OR, Portland
Joined Aug 2010
Cool
Simple DTD ( Dollar Tree Delta )
Built this in about an hour using one sheet of dollar tree foam (paper removed ) . Very lightweight so it can fly slow - but will scoot if you want it too . Literally 5 triangles and 2 rectangles , a little hot glue , some tape and three carbon rods .
DTD ( Dollar Tree Delta ) $1.00 airframe (2 min 50 sec)
balsa or carbon is offline Find More Posts by balsa or carbon
Old Nov 23, 2011, 05:26 AM
gpw is online now
gpw
Find More Posts by gpw
gpw
“There’s no place like Foam”
gpw's Avatar
United States, LA, New Orleans
Joined Jul 2002
NICE !!! Great FUN !!!
gpw is online now Find More Posts by gpw
Old Nov 26, 2011, 09:05 AM
eboggs59 is offline
Find More Posts by eboggs59
Arkansas
Joined Dec 2004
Could you please post the generals (plans and power plant) on your delta. I am considering doing something similar to this myself.
eboggs59 is offline Find More Posts by eboggs59
Old Nov 27, 2011, 09:00 PM
Joined Aug 2010
generals for DTD
Here are the plans - from 1 sheet Dollar Tree foam - KF airfoil on top of wing. Two carbon rods taped to leading edges and one across span in front of elevons. Best guess CG to start with , then adjusted as needed for good flight by moving battery forward or back. The motor/ESC is a Blue Monster/20amp from Lazertoyz, servos are a couple of 9g I had laying around. 8x6 GWS prop.
Old Nov 28, 2011, 11:25 AM
eboggs59 is offline
Arkansas
Joined Dec 2004
Balsa or Carbon's DTD - Extracted Plans
Balsa or Carbon,
I really like the simplicity of your airplane. I went over the photo with the dimensions on it, took the data, and laid it out in my CADS program. I started with a stock 20" x 30" sheet and scaled in all the dimensions the best I could. I think you will find them very close to what you have actually built. The attached photo is extracted from the CADS program to show the dimensions I came up with, mounting positions for the CF rod and rudders, and the cut lines for each of the pieces. If you will please look it over and see if it looks correct to you. If I need to make changes, just let me know.
Old Nov 28, 2011, 12:44 PM
foamflyer is offline
Find More Posts by foamflyer
Trapped in California
foamflyer's Avatar
United States, CA, Arcadia
Joined Nov 2003
That's a great design, thanks for sharing that! I've never tried it as a puller, but have done some pushers.
They fly very, very well.
foamflyer is offline Find More Posts by foamflyer
Old Nov 29, 2011, 09:51 AM
Joined Aug 2010
Wow!
Balsa or Carbon,
Thanks for doing that! The only thing I would change is make the elevons at least 1 1/2" , which is what I have. I made the plane for a friend to learn to fly with ailerons ( elevons ) , so I wanted to keep the roll very mild - but 1" might be too mild .
Old Nov 29, 2011, 12:18 PM
eboggs59 is offline
Arkansas
Joined Dec 2004
DTD with larger Elevons
Elevons have been enlarged to 1 1/2".
I think what I like seeing the most about this design is that the cut out of the part is so simple.
I have also included drawing for a larger 24" x 36" version for the Blu FFF buffs.
Old Dec 18, 2011, 08:19 PM
eboggs59 is offline
Arkansas
Joined Dec 2004
The battery you used on this, how many cells, and what MAH?
Old Dec 19, 2011, 03:37 PM
Joined Aug 2010
I use different batteries , 2-3 cell , 350-800 mah . The 3 cell gives you a little more power than the 2 cell , the lighter 350 mah lets you fly slower than the heavier 800 mah.
Old Dec 24, 2011, 10:29 AM
Joined Aug 2010
Prop in slot pusher
I converted the DTD to a prop in slot pusher to give the motor a little more protection - flies just as good! And here is a picture of the landing gear - simple , light , works well.
Old Apr 08, 2012, 09:59 PM
eboggs59 is offline
Arkansas
Joined Dec 2004
My DTD, and it flies like it is on rails.
I finally got all the pieces in that I needed to build the DTD, and it flies great. I used a Hobby King 24gram motor, 1700 Kv (HXM2730-1700), a GWS 8x4 prop, and a Zippy 3s 1000 battery. I am using a CG that is 9" from the tip of the foam structure of the delta. It is equipped with 1.5" wide elevons. I only used fiberglass strapping tape to stiffen up the structure.
DTD Video 1 04_08_12.wmv (6 min 41 sec)
Old Jul 08, 2012, 09:29 PM
electricrc68 is offline
Find More Posts by electricrc68
The Sweet Aroma of Fuel
electricrc68's Avatar
United States, PA, Downingtown
Joined May 2011
Nevermind....i got it.
electricrc68 is offline Find More Posts by electricrc68
Old Jul 09, 2012, 04:23 PM
Joined May 2011
I have the airframe built up but am not sure what electronics to use? Are there any you would recommend? I cant find the motor/esc you listed.
Old Jul 09, 2012, 11:04 PM
Joined Aug 2010
Here is a great combo that includes motor , ESC and three servos for $24.66
http://www.hobbypartz.com/60p-dy-1006.html
Discussion black vs white dollar tree foam unbroken23 Foamies (Scratchbuilt) 11 Jul 23, 2012 12:04 PM
Discussion Bulk Readi-Board (Dollar Tree foamboard) shipped directly to you? ExperimentalAir Foamies (Scratchbuilt) 15 Feb 05, 2012 01:38 PM
Yippee! Dollar Tree: We Finally Got One Here!!!! NEW222 Foamies (Scratchbuilt) 36 Dec 20, 2011 01:47 PM
Discussion Has anyone used this foam from the Dollar Tree? bagofbones11 Foamies (Scratchbuilt) 6 Nov 29, 2011 05:04 PM
Discussion Bulk Readi-Board (Dollar Tree foamboard) shipped directly to you? ExperimentalAir Foamies (Scratchbuilt) 4 Oct 28, 2011 11:41 AM
