Old Nov 21, 2011, 10:01 PM
AJWoods is online now
Find More Posts by AJWoods
Aircraft Designer Guy
AJWoods's Avatar
United States, CA, Santa Clara
Joined Jul 2005
SAAB Viggen
I got one of the Sky Angel 35mm BAE Hawks a couple of weeks ago. Took half a dozen flights or so to figure it out and get if flying consistently, then it met a chain-link fence
I've been messing around for a while on the laser cutter, trying to get panel line effects with minimal labor, so I drew up a SAAB Viggen as a test airframe. The foam is painted first, the panel lines are etched on one cutting pass on the laser, then the part outlines are cut. I've tried a bunch of different weathering techniques to add more contrast to the etches, but plain white still looks nice, particularly with some back light.
The jet with all the Hawk electronics and a 350 2 cell comes in at 65g, putting out a hair more than 70g thrust on a fresh pack. There is about 4x the wing area of the hawk, so hand launches should be a non event. Hope to try flying it tomorrow.
-Adam
AJWoods is online now Find More Posts by AJWoods
Latest blog entry: F-Zero Hovercraft
Old Nov 22, 2011, 08:25 AM
ksqm is online now
Find More Posts by ksqm
United States, VA, Hampton
Joined Mar 2009
MIT KID,
Your Viggen is really nice. You should have no problems with this flying. High alpha should be awesome. Please post a vid.
Ksqm
ksqm is online now Find More Posts by ksqm
Old Nov 24, 2011, 11:59 AM
AJWoods's Avatar
Joined Jul 2005
Got it flying this morning. Trimming took a while as I think the canard may be at a slight positive incidence. Flies awesome and lands at a crawl. I'll see if I can get somebody to shoot some video before the turkey comas set in
-Adam
Old Nov 25, 2011, 10:09 AM
AJWoods's Avatar
Joined Jul 2005
35mm Micro Viggen (1 min 13 sec)
Old Nov 25, 2011, 08:04 PM
ksqm is online now
Joined Mar 2009
MIT Kid,
Nice vid. What are the specs on your Viggen. Looks to be about 13"-14" WS. Looks like a nice plane for a 25mm/27mm EDF unit I have.
Ksqm
Old Nov 25, 2011, 08:31 PM
AJWoods's Avatar
Joined Jul 2005
Thanks. It's just a hair under 14" span. The painted airframe without electronics was right around 28g. It flies with authority on the stock sky angel 2s setup, I'd imagine something on 3s would be very fun.
-Adam
Old Nov 26, 2011, 01:16 AM
NitroCharged is offline
Find More Posts by NitroCharged
Team30 Micro EDF
NitroCharged's Avatar
Adelaide, Australia
Joined Apr 2004
Wow! what a floater.
That unbalanced fan was torture to listen to though.... LOL
NitroCharged is offline Find More Posts by NitroCharged
Old Nov 26, 2011, 08:16 AM
AJWoods's Avatar
Joined Jul 2005
haha yeah. It sounded much better when it was in the hawk. I think without the support of the foam the shroud is resonating. When I first set it up, you could see the shroud hit a mode right around mid throttle. I worked on balancing the rotor, but it's still not right. When I try 3s, I'll pull the shroud out and wrap a layer of depron around it to try to move that frequency up along with balancing the 3 blade rotor better.
-Adam
Old Apr 04, 2014, 12:59 PM
Kudos2u is offline
Find More Posts by Kudos2u
Joined Apr 2014
Hi Adam!
Do you have the plans on the web for the mini viggen?
I would love to build one for my self.
/Jason
Kudos2u is offline Find More Posts by Kudos2u
Old Apr 04, 2014, 02:30 PM
CoolerByTheLake is offline
Find More Posts by CoolerByTheLake
Do it Right, the first time!
CoolerByTheLake's Avatar
United States, MN, Hermantown
Joined Dec 2008
If you want to do a 50mm one, the plans are here:
http://www.rcgroups.com/forums/showthread.php?t=2004558
CoolerByTheLake is offline Find More Posts by CoolerByTheLake
Old Apr 04, 2014, 02:36 PM
Kudos2u is offline
Joined Apr 2014
:-) Thanks, but I all ready got that one on the workbench.
/Jason
Old Apr 05, 2014, 07:19 PM
AJWoods's Avatar
Joined Jul 2005
Never got around to posting plans for this one, because of all the engraving, but I might be able to put up a simplified version. It's based directly off a stock 3-view, so there's not much more to it than the outline.
-A
SAAB VIGGEN KITS or PLANS Sluf7 Fuel Jet Talk 14 Jan 04, 2012 10:30 AM
Saab Viggen 37 Sluf7 Electric Ducted Fan Jet Talk 11 Oct 20, 2008 08:45 AM
Saab J-37 Viggen FoxBAT138 Electric Ducted Fan Jet Talk 42 Nov 30, 2005 11:10 PM
SAAB JAS Gripen & JA 37 Viggen Built up from Plans anywhere Sluf7 Electric Ducted Fan Jet Talk 2 Jun 25, 2004 07:11 AM
Scorpio saab viggen and fantex andrea Electric Ducted Fan Jet Talk 44 Nov 04, 2003 12:55 PM
