This thread is privately moderated by GooberSB, who may elect to delete unwanted replies.
Old Nov 21, 2011, 05:44 PM
GooberSB is offline
Find More Posts by GooberSB
An Ordinary User
United States, VA, Fluvanna
Joined Jan 2011
Build Log
12" USAF UFO scratchbuild
I wanted to see how small I could go and make something I consider stable. I've tried wings down to 16" and found that they are very unpredicatble at that size (other than predictably fast and unstable).
So I decided to try a 12" version of gpw's UFO. Based on my experience with the 22" version I theorized that if the wing area was kept at slightly better than a HZ Champ and the same electronics were used I could create something that flies at about the speed of a Champ but have the stability of a disc. That's how the idea came about.
Here's the result
12" UFO (2 min 3 sec)
It weighs 55.5g and the wing loading is just under 2 oz / sq ft. My target weight was 60g so I was happy to be a little under that.
The details:
6mm FFF circle @ 12" diameter
3mm $Tree semi-circle @ 12" diameter
Champ/Vapor ESC/Rx brick
Champ motor/gearbox/prop
Champ/Vapor CF control rods
Flyzone Playmate landing gear
450mah 3.7v lipo
This build has boosted my confidence after a failed build this weekend. Now I'm working on a Sky Ray build by gpw, a 48" UFO, and a KFm-4ward wing by ombudsman.
The build that failed? A very unstable butterfly shape based off a cartoony butterfly clipart picture I liked.
SB
GooberSB is offline Find More Posts by GooberSB
Old Nov 21, 2011, 09:52 PM
strasbourge is offline
Find More Posts by strasbourge
strasbourge's Avatar
Wellington New Zealand
Joined Nov 2010
chicken was obviously used to things like this in your yard!
strasbourge is offline Find More Posts by strasbourge
Old Nov 22, 2011, 07:10 AM
GooberSB is offline
An Ordinary User
Joined Jan 2011
That's funny but true. I never thought they even noticed them but apparantly they have grown quite accustomed to noisy flying objects.
They usually stand around me when I'm flying in hope of being fed. That one was still waiting.
SB
Old Nov 24, 2011, 11:21 AM
Tsavah is offline
Find More Posts by Tsavah
Watt Waster
Tsavah's Avatar
Joined Oct 2010
Chickens and RC ...
Originally Posted by GooberSB View Post
That's funny but true. I never thought they even noticed them but apparantly they have grown quite accustomed to noisy flying objects. They usually stand around me when I'm flying in hope of being fed. That one was still waiting. SB
Yes, from my own experience it is amazing what they will "trust" is fine once they come to trust the feeder guy. Did you do a build thread on the little UFO? If you have, I would be interested in making a copy. Thanks
Tsavah is offline Find More Posts by Tsavah
Latest blog entry: Center of Gravity - Airplanes
Old Nov 24, 2011, 06:07 PM
GooberSB is offline
An Ordinary User
Joined Jan 2011
Tsavah, the original thread started by gpw is here
http://www.rcgroups.com/forums/showthread.php?t=553823
My description of this build is post # 2625
http://www.rcgroups.com/forums/showp...postcount=2625
There are several other size variations from my 12" to 48" or larger.
SB
Old Nov 24, 2011, 06:28 PM
Tsavah is offline
Watt Waster
Tsavah's Avatar
Joined Oct 2010
UFO Flyer Threads
http://www.rcgroups.com/forums/showthread.php?t=553823 My description of this build is post # 2625 http://www.rcgroups.com/forums/showp...postcount=2625 There are several other size variations from my 12" to 48" or larger. SB
Thanks. I am looking them over and liking what I see.
Old Nov 24, 2011, 08:39 PM
GooberSB is offline
An Ordinary User
Joined Jan 2011
Also, I wanted to say I'm flattered that you are interested in my 12" UFO. I greatly admire your work.
SB
Old Nov 24, 2011, 10:17 PM
Tsavah is offline
Watt Waster
Tsavah's Avatar
Joined Oct 2010
Thank You for Mutual Interesting Projects
Also, I wanted to say I'm flattered that you are interested in my 12" UFO. I greatly admire your work. SB
Thanks for the compliment. I tend to like a lot of projects others have done. When I see something interesting, I like to subscribe and try to keep up with any changes/modifications I might want to include when I do the same build.
JFYI - I am almost ready to post some pictures of a X-Zylo toy I made, which is a spinning ring flyer. I used a plastic peanut butter jar as the source material. It is too windy outside to test it further, but it flies across my small living room very well. I made the toy because it is a new shiny thing for me, and I am looking for ways to make thick plastic rings for other RC projects. I will post more information as a new blog entry soon.
Old Dec 08, 2011, 09:55 PM
GooberSB is offline
An Ordinary User
Joined Jan 2011
new pictures added
I added new pictures to post #1
Now I'm thinking of another possibility
14" or 16" ufo or heart shaped wing using the same electronics I used to build a brushless Champ. Video of that on my YouTube channel.
Should be able to keep it around 70g (the 12" version is 55.5g). With the larger wing area the wing loading would still be close to 2oz / sq ft and it would be a good indoor flier.
SB
Old Dec 08, 2011, 10:01 PM
Tsavah is offline
Watt Waster
Tsavah's Avatar
Joined Oct 2010
Youtube Link?
Now I'm thinking of another possibility 14" or 16" ufo or heart shaped wing using the same electronics I used to build a brushless Champ. Video of that on my YouTube channel. Should be able to keep it around 70g (the 12" version is 55.5g). With the larger wing area the wing loading would still be close to 2oz / sq ft and it would be a good indoor flier. SB
What a tease! How about a link to the Youtube channel? A bit hard to see much without the link. Actually I found your Youtube channel by using the "Watch on Youtube" option in the first video entry. I like your projects and video. Thanks.
Old Dec 08, 2011, 10:43 PM
GooberSB is offline
An Ordinary User
Joined Jan 2011
Hahaha
Sorry to tease, but I don't want it to be embedded here. It's an old video from the summer and not a good advertisement for my current abilities.
I've only been flying rc planes for 9 months but my progression can be mapped vividly by comparing videos in chronological order. My son who is now 7 yrs old flies better than me. No matter what I'm flying he can walk over and take the Tx and fly like he owns it. But, he can't create them. At least I'm better than him at something haha.
SB
Discussion USAF UFO...as simple as it gets gpw Foamies (Scratchbuilt) 2755 Sep 11, 2014 06:00 AM
Build Log 1:12 Scale Starcraft scratchbuild... Bandit240 Scale Boats 6 Nov 04, 2008 06:50 PM
Video 36" USAF UFO Video at NIGHT Liquidity Electric Plane Talk 13 Nov 05, 2007 09:06 AM
Video 36" USAF UFO video Liquidity Electric Plane Talk 0 Nov 03, 2007 09:44 AM
