Old Jul 19, 2012, 11:48 PM
p901P901 is online now
Find More Posts by p901P901
p901P901's Avatar
United States, CA, Lancaster
Joined Jan 2009
Just trial fitting wings and tail. Foam for wings is 2lb EPS. Never used this stuff but these wings are strong. Wings will be removable with 1/2" joiner tube extending from the body and 10" long slip fit tubes into the wings (2ea per wing). Spars? Maybe just some 1" wide unidirectional 3.6 oz carbon tape.
Total wing area is 1221 sq inch and 527 sq inch for the body. Wing loading is 22 oz for wings only (15 oz with the body) if the projected RTF weight is 12lbs.So just epoxy/ glassing the wings with 3.6 oz cloth may be good enough.
Still allot of shaping, sanding and filling to go.
See Ya
p901P901 is online now Find More Posts by p901P901
Old Jul 20, 2012, 06:41 AM
Waltjg is offline
Find More Posts by Waltjg
Waltjg's Avatar
Crystal River Fl.
Joined Jul 2008
P, you referred to a 1/2" wing joiner tube in your last post, is this 2pieces one extending from each side into the wing or is it one piece going through the fuse and intake duct work? W
Waltjg is offline Find More Posts by Waltjg
Old Jul 20, 2012, 11:01 AM
p901P901's Avatar
Joined Jan 2009
Not going through the duct work. Its going into a horizontal 1/4" birch ply former that is capped with 2 ea 1/4" vertical birch ply over the stub.
Stub spars are 1/2" OD .063 wall aluminum 6061 T6. Receiver spars are 1/2" ID brass tube. I did not calculate the shear loading on the spar at the attachment point between the fuselage and wing. Its only a guess .
Suggestions for glassing is horizontal orientation for to and bias for the bottom 3.6 oz cloth.
Old Sep 02, 2012, 10:10 PM
p901P901's Avatar
Joined Jan 2009
Paint
Painted the top. Next is the bottom, intakes and flight controls.
Old Sep 03, 2012, 12:39 AM
corsair nut is offline
Find More Posts by corsair nut
fly like an EAGLE ;)
corsair nut's Avatar
tehachapi, CA
Joined Jan 2006
man thats looking sweet! done yet?? lol
corsair nut is offline Find More Posts by corsair nut
Old Sep 03, 2012, 01:09 AM
unclecrash is offline
Find More Posts by unclecrash
unclecrash's Avatar
white lake michigan
Cool project !
unclecrash is offline Find More Posts by unclecrash
Old Dec 19, 2012, 03:51 PM
p901P901's Avatar
Joined Jan 2009
Intended to use 10 cell (4c + 6c) 5000mA 40c batteries on this plane. But because of CG ended up with 2 sets. That is 10 cells at 10000mA. Plane came in at 10 lbs and with 6 lbs of batteries. Never intended to go with this setup. I still need to run the numbers to see what all this means. Wing loading is 30oz so it should be a easy flyer. May go 12cell 10000mA if its sluggish.
Old Dec 25, 2012, 06:24 PM
p901P901's Avatar
Joined Jan 2009
I added 2 lbs ballast to the nose and using 10 cells 5000mA batteries for the maiden flight. AUW will be 14 lbs. WOT amp draw is 85 amps on 10 cells.
This calculates:
For 5000mA batteries
C rating = 85000mA/5000mA = 17C
Flight time = 60/17C = 3.5 min
For 10000mA batteries
C rating = 85000mA/10000mA = 8.5C
Flight time = 60/8.5C = 7 min
After first flight will install retracts and graphics.
Old Dec 25, 2012, 06:37 PM
minimicrorc is online now
Find More Posts by minimicrorc
Joined Apr 2012
looks great
minimicrorc is online now Find More Posts by minimicrorc
Old Dec 26, 2012, 01:07 AM
Stuart A is offline
Find More Posts by Stuart A
You know nothing....
Stuart A's Avatar
Joined Sep 2011
Originally Posted by minimicrorc View Post
looks great
Like the man said.looking forward to flight pics.
Stuart
Stuart A is offline Find More Posts by Stuart A
Old Dec 26, 2012, 02:49 AM
p901P901's Avatar
Joined Jan 2009
Would like to video all my maiden flights. If only I had a head cam to take video then it would be that easy. Many maidens are just the spur of the moments, after many adjustments and when the moment feels right. So this one will be the same.
So many things to focus on while flying maidens.
Old Dec 26, 2012, 09:01 AM
unclecrash's Avatar
white lake michigan
Looking sweet P901, A couple questions what did you use for the spar receptical's. Brass ? Are they a snug fit ? I was thinking of getting the material the 3d arf's use. Can't remember the name ( brain fart.) As you know my 23 will need the reciever's put into the fuse as I dare not try to drill out the rib's any further. And give me a run down of how you go about aligning them. I was thinking on making a jig to drill the fuse, but I may just drill them and adjust as needed if they are off a bit in the fuse.
Old Dec 26, 2012, 10:58 AM
p901P901's Avatar
Joined Jan 2009
Hey crash:
Yes they are brass tubes from K&S. I do not remember the P/N but they are a tight fit on the aluminum tube, so some sanding the aluminum a few thousands is necessary.
The holes in the wing ribs where carefully jigged so brass tubes were perpendicular to each other. The aluminum tubes was then inserted into the brass tubes so alignment into the wood receptacles where perfect. There is some auguring of the wood in the formers to make a loose fit. Then the holes were filled with slow cure epoxy and microballons before the aluminum tubes where installed.
The wing is a tight fit and probably would never slide off but I drilled the front spar and used a piece of 2-56 rod to secure them.
Your 23 can be done in the reverse of this process. Aluminum tubes in the wing and brass receptacles in the formers.
Old Dec 26, 2012, 02:36 PM
unclecrash's Avatar
white lake michigan
OK thanks thats what I was wondering about having a bit of room in the holes for alignment. I will have to figure out the size of the brass, but can do that when I get the alumi for the spars I can take it up to the LHS and get the brass there. Thanks UC
Old Dec 26, 2012, 09:03 PM
LuvEvolution7 is offline
Find More Posts by LuvEvolution7
LuvEvolution7's Avatar
St.Catharines, Ontario
Joined Jan 2009
sweet job on this. it looks awesome.
LuvEvolution7 is offline Find More Posts by LuvEvolution7
Discussion Me-P.1112 (a Luft46 project) heiner Scratchbuilt EDFs 5 Sep 09, 2011 09:33 PM
New Product New 20mm EPP WWII Series, ME-109 and P-51 2dogrc Electric Warbirds 0 Jun 08, 2011 12:36 PM
Sold Gws p-51 mustang and me-109 pulsery2k1 Aircraft - Electric - Airplanes (FS/W) 8 Apr 13, 2011 04:02 PM
Wanted CF UM Project: Sell me your UM Sukhoi and P-51 airframes, wings, etc! S.R.G. Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 1 Mar 06, 2011 09:33 AM
Help! FS: Miniblade, ME-109, P-51, P-40 (ie sucks to be me) McGrrr Aircraft - Sailplanes (FS/W) 21 Jun 19, 2005 04:34 PM
