Old Nov 20, 2011, 04:40 PM
p901P901 is online now
Find More Posts by p901P901
p901P901's Avatar
United States, CA, Lancaster
Joined Jan 2009
Me p-11111
Has anyone built one of these or have information about it. I see someone has built a few of these with turbines
P 1111 (6 min 28 sec)
My plans is to use a 120mm EDf with 10 cell. The EDF will be much like Knife Liddle's http://www.rcgroups.com/forums/showt...5#post19924039. So far will use the EH 1.59.0 airfoil. Used this one before on another scratch built which worked out great with about 2 degrees washout. Wing span is going to be 75" , fuselage 60".
p901P901 is online now Find More Posts by p901P901
Old Nov 20, 2011, 05:46 PM
Onna Vakkation is offline
Find More Posts by Onna Vakkation
United States, PA, Grove City
Joined Jan 2011
There's a number of these Luft '46 planes that need to be modeled.
I built the Flitzer, which has similar intakes, and still needed a cheater for ample power with an EDF55 fan at around 28" span or so. If I did it again, I would not be surprised if a well powered 50mm Microfan would perform as well, without the cheater. These Luft '46 jets don't give us much intake for large fan sizes, as I had to cheat on my FW225 also. At your size, built reasonably light, one of these powerful 70mm setups producing nearly 3lbs should perform well.
It is good to have an airfoil section that has worked well for you, like your EH section. The planes below, as well as several others all have GWS ME109 replacement wings. They seem to perform even better when swept, than when straight.
Bill
Onna Vakkation is offline Find More Posts by Onna Vakkation
Old Nov 21, 2011, 10:33 AM
Erik v. Schaik is offline
Find More Posts by Erik v. Schaik
My project: FAIREY DELTA 1
Erik v. Schaik's Avatar
Uden Volkel, Netherlands
Joined Dec 2003
FYI:
http://www.made-in-china.com/showroo...PZ-15091-.html
This is the Jepe retracts up to 4kg. Not suitable for your project ( I will use them in my Miniwave project)
Think twice if you want to build high swept deltas. I have a Horten13B which is very sensitive to elevator throws and it is very easy to bleed off speed in a curve and if not lucky, entering a spin. But as for all Luft'46 planes, they all need skilled pilots and like to be flown with care.
good luck on your project!
Erik
Erik v. Schaik is offline Find More Posts by Erik v. Schaik
Old Dec 07, 2011, 08:43 PM
PlumberJohn is offline
Find More Posts by PlumberJohn
John Green
USA, FL, St Petersburg
Joined Dec 2007
I built one scratch from that same three view for ICDF. It was an excellent flier. It had about a 50" wingspan as I recall. It was on 72mHz channel 44 and got shot down on final after about 55 flights. I've always meant to do another so much I have the three view on the wall above my building table to keep me reminded. It flew with a KB7.5 at first and was later upgraded to a Dynamax w/ OS91.
John
PlumberJohn is offline Find More Posts by PlumberJohn
Old Dec 13, 2011, 12:24 PM
heiner is offline
Find More Posts by heiner
Joined Jun 2007
@p901P901,
I am in contact with those jet pilots that built these Me-p.1111. They are from Germany, the 2 machines are built of wood, sorry no kits made so far. When I know more, I will let you know.
heiner
heiner is offline Find More Posts by heiner
Old Dec 15, 2011, 02:59 PM
p901P901's Avatar
Joined Jan 2009
Originally Posted by heiner View Post
@p901P901,
heiner
Old Jun 21, 2012, 03:49 AM
p901P901's Avatar
Joined Jan 2009
Still moving ahead
This project is slowly moving along. Formers are just about done and need to start assembly.
Old Jun 21, 2012, 04:25 PM
Stuart A is offline
Find More Posts by Stuart A
You know nothing....
Stuart A's Avatar
Joined Sep 2011
Nice subject.
Stuart
Stuart A is offline Find More Posts by Stuart A
Old Jun 28, 2012, 06:05 PM
p901P901's Avatar
Joined Jan 2009
Spent a few hours building
Just showing some progress. The fan is a 4 blade 120mm Haoye and motor T600-880.
Still have questions on installation of flight controls. Previous models similar to this, I tried using the inboard control surface as elevators and outboard as ailerons.
The elevators seemed sluggish in slow speed operation. I think it was because the root cord thickness was blocking some of the airstream across it. I did not try to increase the surface area of the elevator, instead I increased the aileron length to 75% span and made it into an elevon. This improved functions of the control surfaces. Elevon was set up 60% aileron and 40% elevator.
I sure would like comments from PlumberJohn and Erik v. Schaik on how they set up there planes.
Wing is going to be foam core MH-60 and a washout of 3 degrees.
Old Jun 28, 2012, 07:30 PM
Waltjg is offline
Find More Posts by Waltjg
Waltjg's Avatar
Crystal River Fl.
Joined Jul 2008
Really interesting, keep up the great build!! W
Waltjg is offline Find More Posts by Waltjg
Old Jun 29, 2012, 05:05 PM
John Green
Joined Dec 2007
I did mine with full span elevons. They had a few degrees of reflex in them and they were very effective. It flies like a sport plane this way and is much easier to setup.
John
Old Jul 10, 2012, 09:45 PM
p901P901's Avatar
Joined Jan 2009
The top is sheeted and ready for the bottom. I am thinking of using some Liquid Sheeting from WoW planes to give the foam a hard surface. I hear a lot of good things about this stuff but unsure about its shear strength. My intentions were to epoxy glass the surface with 2oz cloth. But may use 2oz cloth with Liquid Sheeting instead. Still experimenting.
The duct is 2 layers 6oz Soft Drape cloth.
Old Jul 11, 2012, 11:27 AM
Bare is offline
Find More Posts by Bare
Canada
Joined Nov 2000
Glass cloth with Minwax Polycrilic. (Water based Polyurethane)
After you sand the thing to final shape/finish
Bare is offline Find More Posts by Bare
Old Jul 11, 2012, 06:04 PM
Waltjg is offline
Waltjg's Avatar
Crystal River Fl.
Joined Jul 2008
Ask Falcon5 about the liquid sheeting, he purchased it from the manufacture directly and has used it. I don't think it is ment to be used with glass, but to take the place of it... Glass/wbp,,, Not near as Strong as glass and resin, and it is heavier than a properly done glass/resin job.... W
Old Jul 11, 2012, 07:43 PM
p901P901's Avatar
Joined Jan 2009
Thanks for you reply:
Most of my builds is with 2oz - 3.6 oz glass and PolyC or glass and epoxy resin. This build is more of a stress skin design. So I need sheer strength in some areas.
So it looks like I will use 3.6 or 5.6 oz plain weave cloth with 2oz cloth over it. Or try a sample of liquid skin to fill the weave instead of the 2oz cloth.
Discussion Me-P.1112 (a Luft46 project) heiner Scratchbuilt EDFs 5 Sep 09, 2011 09:33 PM
New Product New 20mm EPP WWII Series, ME-109 and P-51 2dogrc Electric Warbirds 0 Jun 08, 2011 12:36 PM
Sold Gws p-51 mustang and me-109 pulsery2k1 Aircraft - Electric - Airplanes (FS/W) 8 Apr 13, 2011 04:02 PM
Wanted CF UM Project: Sell me your UM Sukhoi and P-51 airframes, wings, etc! S.R.G. Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 1 Mar 06, 2011 09:33 AM
Help! FS: Miniblade, ME-109, P-51, P-40 (ie sucks to be me) McGrrr Aircraft - Sailplanes (FS/W) 21 Jun 19, 2005 04:34 PM
