Old Nov 20, 2011, 10:54 AM
carthagenj is offline
Find More Posts by carthagenj
United States, FL, Bradenton
Joined Jul 2008
Optic 6 Sport 2.4 and Optima 6
I have an Optic 6 Sport 2.4 TX with 3 Optima 6 RXs. I recently sent in the Optima 6 RXs to Hitec in CA for a free upgrade as mentioned in the recent service bulletin. I was able to rebind all upgraded RXs to the TX but that was when the strangeness started. Now I am not able to set the throttle range on any of my three Escs (1 Gaui 22A and 2 Exceed RC Proton 30A all of which are Brand New). Also none of them arm but each broadcast a "throttle stick is not in the bottom position" Alert (short beeps about .25 secs apart). They were tested each with a variety of LiPo packs (Sky LiPo 800mah 20c, Hyperion 950mah 25c. Both fully charged ). I'm thinking that the Optima 6 RX firmware upgrade requires a corresponding upgrade on the Optima Sport 6 TX. Can anyone suggest what I should do next?
carthagenj is offline Find More Posts by carthagenj
Old Nov 20, 2011, 12:38 PM
A.T. is offline
Find More Posts by A.T.
Joined Aug 2002
Did you reduce the throttle trim to below 50% or extend EPA to 125 either direction, prior to resetting the ESC?
This is required on all computerised TX so as to permit correct operation of ESC, please refer to:
EPA, ATV, Dual Rates & Expo Differences & Caution + ESC BEC Set Up
Transceivers updated, what about the Optic Sport?
An opportune time to also check your TX for current firmware.
Hitec Optic 6 & Optic Sport - Manuals, Tutorial, FAQ & Comparison Charts
Alan T.
Alan's Hobby, Model & RC FAQ Web Links (quick search = Ctrl+F)
A.T. is offline Find More Posts by A.T.
Old Nov 20, 2011, 03:11 PM
Joined Jul 2008
Huh? ATV only affects cyclic servos on channels 1,2 and 6, not throttle which in my case is channel 3. No?
Old Nov 20, 2011, 03:19 PM
A.T. is offline
Joined Aug 2002
ATV does not apply in all cases. That information page covers the many many repeated questions relating to ESC setting, ATV & EPA problems experienced with all brands and types of transmitters.
Relative extract from information provided =
Throttle Setting for Electronic Speed Controllers:
Many ESC will not arm unless the throttle trim on a computerised TX is lowered to say 15 -20% or EPA adjusted almost to maximum because, in simple terms, the maximum servo travel displayed on a computer TX is about 80% of that of a non computerised TX to provide for the trim and sub trim adjustments.
NB: Never set up an ESC with trim at absolute minimum or EPA at maximum because some ESC will lock out if overheated or other cause and can only be reprogrammed/reset by starting with a lower than previously set value. During the subsequent reset process the minimum trim must be increased back to say 20% to provide a margin for future resets. (e.g. Graupner Pico Mos series).
Hitec Optic 6 & Optic Sport - Manuals, Tutorial, FAQ & Comparison Charts - includes firmware upgrade details.
Alan T.
Old Nov 23, 2011, 12:48 PM
slopegod is online now
Find More Posts by slopegod
Say it with a Venom
slopegod's Avatar
Grimsby
Joined Jan 2007
The link for full house sailplane does not seem to work could you fix please AT.
http://www.rcgroups.com/forums/showp...72&postcount=6
slopegod is online now Find More Posts by slopegod
Old Nov 23, 2011, 01:27 PM
A.T. is offline
Joined Aug 2002
Originally Posted by slopegod View Post
The link for full house sailplane does not seem to work could you fix please AT. http://www.rcgroups.com/forums/showp...72&postcount=6
Copy of 'Sailplane Talk' article is also available:
Full house with an Optic 6, with tips on RES by original author, Post #5.
Alan T.
Old Nov 23, 2011, 02:34 PM
Say it with a Venom
slopegod's Avatar
Grimsby
Joined Jan 2007
Thanks AT for your fast responce.
Sold Hitec Optic 6 Sport 2.4 radio $80 JoeR Aircraft - General - Radio Equipment (FS/W) 16 Jan 12, 2012 08:25 PM
Discussion Optic 6 - Spectra 2.4 - Optima 6 - Jitter on Ch5 Gordks Hitec/Multiplex USA 3 Sep 03, 2011 11:49 AM
Sold NIB Hitec Optic 6 2.4 GHz w/ 2 Optima 7 receivers - $150 rud-elev Aircraft - General - Radio Equipment (FS/W) 5 May 21, 2011 02:55 PM
Sold NIB Hitec Optic 6 2.4 GHz with 2 Optima 7 receivers - $175 shipped!! rud-elev Aircraft - General - Radio Equipment (FS/W) 2 May 10, 2011 08:57 PM
Help! hitec optic 6 2.4 vs optic 6 sport 2.4 shanet1975 Radios 13 Nov 29, 2010 03:06 AM
