Old Mar 02, 2012, 07:16 AM
GeneralSamUK is offline
Find More Posts by GeneralSamUK
United Kingdom, England, Rochdale
Joined Jan 2012
Quality - thanks mate.. think there's a nice(ish) afternoon hopefully on Saturday so will give it a go n see how it handles
GeneralSamUK is offline Find More Posts by GeneralSamUK
Old Mar 02, 2012, 07:23 AM
DaveyLC is offline
Find More Posts by DaveyLC
DaveyLC's Avatar
United Kingdom, England, Wokingham
Joined Sep 2011
With factory CG it needed a little touch of down elivator with a 2200 3s it needed just a touch of up
DaveyLC is offline Find More Posts by DaveyLC
Old Mar 02, 2012, 07:31 AM
Joined Jan 2012
Thanks for the tip - noticed it had a bit more tendancy to nose dive just by fitting a better propeller as well
Old Mar 24, 2012, 12:49 PM
Edu701 is offline
Find More Posts by Edu701
Brazil, RJ, Rio de Janeiro
Joined Mar 2012
Propeller for the Axion 139
Dear Davey,
I just bought an Axion 139 on my last trip to London to bring it to Brazil (2 weeks ago). I'm completely new to aeromodelism and as expected I already destroyed the 2 props after some crashes. So, I need to look for new props.
Can you tell me the specs of this props so I can search for replacements here in Rio de Janeiro. Do you have other suggestions about different types of props to put on this plane. I didnt change anything on the plane, so all components are the original ones.
Your assistance will be very much appreciated.
Cheers,
Eduardo
Edu701 is offline Find More Posts by Edu701
Old Mar 24, 2012, 06:15 PM
DaveyLC is offline
DaveyLC's Avatar
Joined Sep 2011
Its simpler to get a 2.3mm proper adaptor and maching props
Old Mar 25, 2012, 10:30 AM
Edu701 is offline
Joined Mar 2012
Exactly the info I was looking for. Thanks!
Could give an indication of the location you place the battery/ESC/Receipter. Im pretty sure that I screwed up when trying to locate the CG of the plane.
Regards,
Old Mar 25, 2012, 04:27 PM
DaveyLC is offline
DaveyLC's Avatar
Joined Sep 2011
I never bothered, I just put the battery up the front and didnt apply any down elevator its such a forgiving plane
Old May 04, 2012, 04:25 AM
Joined Jan 2012
Managed to blow my motor after a few good flights on 3s.. Any suggestions on a good inrunner that is cool with 3s??
Old May 04, 2012, 04:29 AM
DaveyLC is offline
DaveyLC's Avatar
Joined Sep 2011
the park 250 works nicely (this is what my mate uses), you just have to mount it on the outside ..
I ended up using one of the purple unbranded inrunners you find on ebay..
check out item 270966653455
And it survived quite well
Basically just find a low KV in runner wiht a 2.3mm shaft.
Old May 04, 2012, 04:30 AM
Joined Jan 2012
Cheers pal - lifesaver!!!
Old Jun 22, 2012, 04:35 AM
Bubba chunks is offline
Find More Posts by Bubba chunks
Joined Mar 2012
please can someone help you seem to know what you are on about i have a alpha 139 and it seems underpowered and would like it bit quicker so not flat out trying to get in the air all the time, could some one suggest a motor, esc, prop and am happy to use 3s 2200 battery as i have some that are 25c, i live in the uk so am happy with ebay or giant shark hope can help as love the plane or hobbyking just dont know what to order
Bubba chunks is offline Find More Posts by Bubba chunks
Old Jun 22, 2012, 12:22 PM
ulogix is offline
Find More Posts by ulogix
Birmingham (UK)
Joined Sep 2010
I used a 30A ESC from my WOT-4 Foamie and a 3S 2200 LiPo (Overlander 25C). Motor and prop are stock. It runs great and has plenty of power.
HOWEVER...
Don't launch it with full power - the stock setup has too much downthrust on a 3S and it will just dive into the ground. Best to launch at 1/2 throttle with a firm throw, then throttle up slowly.
ulogix is offline Find More Posts by ulogix
Old Jun 22, 2012, 04:54 PM
Joined Mar 2012
I have a spare 30amp esc and batt so will give it a go have you used this setup for long i was worried about the motor trying that but sounds good and a cheap option as i have parts also i found this on ebay 110897012405 or best to stick with other option
Old Jan 02, 2013, 11:52 AM
dav1dt88 is offline
Find More Posts by dav1dt88
Joined Jan 2013
Axion Alpha 139 esc problem?
Hi,
I have literally got this plane 2 weeks ago, due to high winds lately have only got to fly it twice. I went out earlier today being it was calm but for some reason the motor wouldnt power up. the rudder and elevator servos both work fine. Looking at it the esc w/bec has a red light that intermittently comes on (this should be on solid). Also occasionally when the light flashes on the motor sometimes powers up to full speed, or has really quick start-stops (twitching). Either this happens or nothing at all, with no motor beep. Just wondering whether anyone has any ideas as to what the problem may be before i travel back to the shop. I assume itll need replacing but hoping it doesnt as its only been flown twice.
Any help is much appreciated.
David
dav1dt88 is offline Find More Posts by dav1dt88
Old Jan 02, 2013, 01:15 PM
DaveyLC is offline
DaveyLC's Avatar
Joined Sep 2011
Is it a brushed or brushless model?
The brushed model suffers from ESC failures
Discussion Axion Alpha 139 - Any experience with 3s batteries? DaveyLC Foamies (Kits) 8 Nov 30, 2011 05:18 PM
Discussion My story so far Photo Elevate Hoverfly Technologies 6 Sep 08, 2011 01:21 PM
Discussion Gyro Stabilisation of my Easystar - so far so good! Chrisfly Aerial Photography 11 May 04, 2011 06:19 AM
Discussion My new build so far..... RC_Marine Electric Heli Talk 18 Apr 02, 2011 11:38 AM
Discussion Help review my wiring so far Transition FPV Talk 4 Jul 11, 2010 12:11 AM
