Old Nov 18, 2011, 01:01 AM
teeforb is offline
Find More Posts by teeforb
Joined Nov 2011
What's the difference between meanwell SE and RSP PSU?
As the title says.
Thx
teeforb is offline Find More Posts by teeforb
Old Nov 18, 2011, 09:44 AM
mrforsyth is online now
Find More Posts by mrforsyth
So. Cal.
The biggest difference that you should be concerned with is power factor correction. SE lacks it. RSP has it. Most need it to prevent AC line shutdown due to overcurrent when charging at high power levels. SE will draw significantly greater current from your AC line than RSP at same DC output power.
Mark
mrforsyth is online now Find More Posts by mrforsyth
Old Nov 18, 2011, 10:03 AM
teeforb is offline
Joined Nov 2011
I see. That's why the RSP are more expensive. Hope I dont have issues using SE.
Old Nov 18, 2011, 10:08 AM
So. Cal.
As discussed yesterday, you might get away with it.
http://www.rcgroups.com/forums/showp...2&postcount=11
http://www.rcgroups.com/forums/showp...2&postcount=14
Only way to know for sure is to try.
Mark
Old Nov 18, 2011, 12:30 PM
teeforb is offline
Joined Nov 2011
Hey Mark,
Looking at Tims calculation, it seems it should be ok.
http://www.rcgroups.com/forums/showp...postcount=3402
i am using a 24v PSU and therefore, the max i can run the charger is about 816W. looking at tims calculations, i should be using the following amps
AC amps = (816 / .85) / 110v = 8.72A
im not sure how the PFC is factored into all this.
Mark
Old Nov 18, 2011, 12:42 PM
teeforb is offline
Joined Nov 2011
i just found this...
OUCH!
http://www.us.tdk-lambda.com/hp/pdfs...93008502rD.pdf
Model 500A 102A 152A 202A
Non PFC 0.65 0.65 0.65 N/A
Active PFC 0.98 0.98 0.98 0.98
IL = Pav / (VL×PF×Eff)
for my case....
IL = 960W / (110v * 0.65 * 0.9) = 13.5A
for a PSU with PFC
IL = 960W / (110v * 0.98 * 0.9) = 9.89A
all rough calculations..
Old Nov 18, 2011, 01:21 PM
So. Cal.
Correct. As discussed yesterday, power factor and power supply AC-DC conversion efficiency must be considered. At higher currents, AC line power losses and charger input lead power losses also become factors (which are not a part of the above equations).
.65 PF is a reasonable guess for a Meanwell SE series PS. .98 PF is about right for a decent power supply with PFC (my supplies measure .97-.98).
90% conversion efficiency is pretty generous for a power supply. Some might be 90% but I would use no higher than 80% unless empirical data exists that demonstrates 90% efficiency.
Using 80% conversion efficiency and .65 PF, you'll be bumping up against the limit of a 15A circuit if you're charging at ~820 watt output with a PL-6 when using a Meanwell SE-1000 as a power source.
Tim's calculations are obviously oversimplified and ignore power factor of the power supply. This can lead to all sorts of trouble.
Mark
Old Nov 18, 2011, 01:23 PM
teeforb is offline
Joined Nov 2011
Correct. As discussed yesterday, power factor and power supply AC-DC conversion efficiency must be considered. At higher currents, AC line voltage losses and charger input losses also become factors (which are not a part of the above equations).
.65 PF is a reasonable guess for a Meanwell SE series PS. .98 PF is about right for a PS with PFC (my supplies measure .97-.98).
Using 80% conversion efficiency and .65 PF, you'll be bumping up against the limit of a 15A circuit if you're charging at ~820 watt output with a PL-6.
Mark
so you thinking i should get a PFC unit? running 820W, what currents u think i'll be using from 110VAC?
Old Nov 18, 2011, 01:32 PM
So. Cal.
As detailed above, I suspect that you'll be close to 15A, which may be perfectly fine. Your circuit breaker will let you know if it's problematic.
You can always measure power factor and AC current draw as well if you're curious.
Mark
Old Nov 18, 2011, 01:47 PM
teeforb is offline
Joined Nov 2011
Mark
i just spoke to a guy from meanwell. Good customer service BTW! He told me the following for full load (actual testing)
SE 1000 (non-cpf) 16.4A
RSP 1000 (cpf) 10.5A
Geez! what a difference! I like a lot of elbow room. I may have just wasted $400..
Old Nov 18, 2011, 01:53 PM
So. Cal.
The SE-1000 numbers are reasonable.
I would challenge the RSP-1000 numbers however, as it's just not possible that it'll only draw 8.5A at full output of the power supply. To do such, the PS would have to have 100% conversion efficiency and line voltage would have to be very close to 120V. I'm betting that the 'real' number for current draw at full output would be somewhere between 10-11A, assuming 110VAC input.
Mark
Old Nov 18, 2011, 01:59 PM
teeforb is offline
Joined Nov 2011
Sorry, 10.5 at full
Old Nov 18, 2011, 02:02 PM
So. Cal.
10.5A is likely spot-on. I'll buy that.
Old Nov 18, 2011, 02:09 PM
teeforb is offline
Joined Nov 2011
what do u think about the rsp 2400 24v PSU?
Old Nov 18, 2011, 02:17 PM
So. Cal.
Like all Meanwell's, I'm sure that the RSP-2400 is a very nicely made supply and would serve you well for a very long time. Note that it requires 220VAC source. This would hamstring most of us.
As I build all of my own supplies, the probability that I would ever own a Meanwell is extremely remote.
Mark
Discussion Has anyone used meanwell RSP-1500-27 PSU? teeforb Batteries and Chargers 15 Nov 17, 2011 06:04 PM
Help! what's the difference between the FP-8uap & 8uap(s)? storm2313 Radios 12 Aug 03, 2011 07:31 PM
Discussion What's the difference between a CCPM and non-CCPM helicopter? Allan Gibbs Electric Heli Talk 8 Jun 22, 2011 03:06 AM
Discussion What's the difference between a cheap sim program and an expensive one Allan Gibbs Beginner Training Area (Heli-Electric) 18 Jun 07, 2011 07:02 AM
Discussion What's the difference between 5G6-1 and 5g6-1 SE? GetterDragun Coaxial Helicopters 6 Sep 29, 2008 02:12 PM
