Old Nov 17, 2011, 06:29 PM
JPMacG is offline
Find More Posts by JPMacG
United States, PA, Warminster
Joined Dec 2006
Servo signal to DC converter
I'm looking for a device to convert the servo signal (digital or analog) from a receiver to a proportional DC level. That is, the more I move the stick the higher the DC level.
I'm suspect that such a gadget already exists. Does anyone know?
JPMacG is offline Find More Posts by JPMacG
Old Nov 17, 2011, 07:20 PM
db_sonic is offline
Find More Posts by db_sonic
Joined Feb 2010
A 1 bit DAC is basically what you want, which is effectively a low pass filter. Similar to the way power supplies convert the AC output of a bridge rectifier to DC signal with a small amout of ripple.
db_sonic is offline Find More Posts by db_sonic
Old Nov 17, 2011, 07:21 PM
Mel Duval is offline
Find More Posts by Mel Duval
Missileer Extraordinaire
Mel Duval's Avatar
Joined Jun 2001
http://www.bpesolutions.com/bpemanuals/dmxtoanalog1.pdf
Mel Duval is offline Find More Posts by Mel Duval
Old Nov 17, 2011, 07:44 PM
AndyKunz is offline
Find More Posts by AndyKunz
AndyKunz's Avatar
Illinois
Joined Sep 2001
A brushed motor ESC will do that with a little filtering on the output.
Andy
AndyKunz is offline Find More Posts by AndyKunz
Site Sponsor
Old Nov 18, 2011, 02:43 PM
shoutchen is offline
Find More Posts by shoutchen
mudville
Joined Nov 2002
take a look at the input circuitry on this esc.
http://www.stenulson.net/rcflight/sc7.htm
SteveH
shoutchen is offline Find More Posts by shoutchen
Old Nov 18, 2011, 09:11 PM
JPMacG is offline
Joined Dec 2006
Excellent information. Thank you everyone!!!
Old Nov 19, 2011, 02:51 AM
Taurus Flyer is offline
Find More Posts by Taurus Flyer
I bail out, anywhere, anytime
Taurus Flyer's Avatar
The Netherlands, OV, Almelo
Joined Nov 2010
JPMacG
The principle as shown in the circuit diagram of the motor controler isn't the only one, Advatage is, it is the simpliest, but disadvantage is, little bit a-linear and slow. It's based on the charge and discharge (tau) curves of a capacitor (C2 in that circuit). and mean voltage level.
I do disign an build my own circuits and if I want fast response and ultra linear relationship (as for measured values) I use a priciple of a closed loop just like a servo.
Such a closed loop system translates the inlput pulse length in a voltage level of capacitor to compare with the feedback voltage of a position feedback potentiometer of a servo with the use of a "one shot". If there is a difference, the voltage is changed by charging or discharging.
It's faster than the first method shown in the circuit of the motor controller.
Fastest system and less components than second method is a sample and hold circuit, not used by me, but action is.
The pulse length is used to charge a capacitor (by a current source) and the value is hold until a new value is known of the next pulse, and exchanged, vastest system of all.
I think you can find examples on the WWW if you realy need speed or linearity
Cees
Taurus Flyer is offline Find More Posts by Taurus Flyer
Help! Is throttle signal same as servo signal???????? vineet_p Power Systems 22 Nov 20, 2014 02:29 AM
Mini-HowTo DIY Servo Signal (PWM) to PPM Converter rich smith DIY Electronics 179 Dec 05, 2012 12:40 PM
Discussion PWM to servo signal converter mjsas DIY Electronics 6 Mar 12, 2010 07:18 AM
Discussion Actuator drive signal to servo signal converter? jingjingjing Scratchbuilt Indoor and Micro Models 11 Oct 05, 2009 08:50 PM
Discussion how to convert PWM servo signal to DC voltage sahilkit DIY Electronics 15 Oct 05, 2008 09:23 PM
