Old Nov 17, 2011, 03:28 PM
jim walton is offline
Find More Posts by jim walton
United States, GA, Columbus
Joined Dec 2008
Rounded Edge Planking Strips
Hello,
I am trying to find Rounded Edge Planking Strips. This is the type used in old Berkeley and Sig kits. Does anyone know where they might be avaliable? These were great for planking.
Thanks.
Jim Walton
Columbus, Ga.
jim walton is offline Find More Posts by jim walton
Old Nov 18, 2011, 05:22 PM
gwinhh is offline
Find More Posts by gwinhh
Beaumont tx
Balsa USA maybe, but no bets. regular shape strips aren't so bad if you taper them before fitting.
howell
gwinhh is offline Find More Posts by gwinhh
Old Nov 18, 2011, 10:49 PM
gcb is offline
gcb
Find More Posts by gcb
gcb
Joined Sep 2008
I don't believe those have been made for 20-30 years. They were 1/8" thick and had a concave round on one side and convex on the other if I remember correctly. They were not very cost effective and frankly you can get a better fit by tapering strips cut from a sheet.
My GUESS is that the only way to get them is to find someone with a stash of them. Good luck.
George
gcb is offline Find More Posts by gcb
Old Nov 19, 2011, 12:16 PM
Joined Dec 2008
Thanks both of you for your replies. I doubt if we will ever see them again.
Jim
Old Nov 19, 2011, 12:35 PM
Joined Dec 2008
Hi guys, here is a thread I just received on Brotherhood of the Ring site. The technique shown will work. This is a great help.
Jim
http://raysmodels.ca/Technical%20Tip...g%20article.do...
Old Nov 19, 2011, 01:16 PM
BLACK HAWK MOD is offline
Find More Posts by BLACK HAWK MOD
Joined Aug 2009
We make one kit with a planked fuselage and we wanted to make more but everyone is afraid to do planking. It does not need to be water tight, you can leave gaps up 3/16" wide and after you cover it with silkspan no one will know. If people are afraid to plank then a lot of good designs are wasted.
Larry
Black Hawk Models
BLACK HAWK MOD is offline Find More Posts by BLACK HAWK MOD
Old Nov 26, 2011, 09:56 AM
65stang is offline
Find More Posts by 65stang
65stang's Avatar
Arizona
Joined Jan 2006
Larry
Black Hawk Models
Larry,
If you did have gaps, wouldn't you just fill them in with a light weight filler?
Adam
65stang is offline Find More Posts by 65stang
Old Nov 26, 2011, 05:46 PM
Clancy Arnold is offline
Find More Posts by Clancy Arnold
I am 5' 8" the Taube is 7' 4"
Clancy Arnold's Avatar
USA, IN, Indianapolis
Back in 1983 when I built my CL Scale P-38 I planked the booms with 3/16 inch wide strips and the center pod with 1/8 inch wide strips of 1/8 inch thick balsa. After the glue dried I first rough sanded them to a reasonable contour. next I mixed two part epoxy and using old playing cards squeegeed the epoxy into the cracks. When the epoxy cured it was as if the planking was molded in a single piece. I cut the landing Gear doors out and hinged then back on. Go to the March 1986 Model Aviation, page 75 to see the results.
Clancy
Clancy Arnold is offline Find More Posts by Clancy Arnold
Old Dec 01, 2011, 12:39 PM
stuntflyr is offline
Find More Posts by stuntflyr
stuntflyr's Avatar
United States, AZ, Tucson
Joined Jun 2010
I planked this with 1/8th...
...cut them myself from sheet with an Xacto.
stuntflyr is offline Find More Posts by stuntflyr
Old Dec 09, 2011, 09:33 AM
65stang is offline
65stang's Avatar
Arizona
Joined Jan 2006
Nice Tigercat....what model kit is it?
Old Dec 10, 2011, 12:12 AM
stuntflyr's Avatar
Joined Jun 2010
Paul Plecan plans from 1950. I built it in '07 and rushed the finish. I'll probably refinish it in silver as the XP-65.
Chris...
Discussion Performance - Rounded or square leading edges on flat plate airfoils batbear Modeling Science 9 Mar 21, 2011 03:29 PM
Discussion wing leading edge rounded? zeedre Foamies (Scratchbuilt) 13 Oct 27, 2010 04:26 AM
Discussion Rounded leading edge EnzoFalconi Indoor Pattern/F3P 5 Sep 23, 2009 03:06 AM
Discussion Strip planking or insert planking? Jacques Flambeau Scale Kit/Scratch Built 5 Jun 14, 2007 04:09 PM
Question Who sells aileron stock with rounded leading edge? iter The Builders Workshop 3 Jun 30, 2006 03:37 PM
