Old Nov 17, 2011, 12:51 PM
sharkforce is offline
Find More Posts by sharkforce
fly the best
United States, CA, Tustin
Joined Apr 2010
Question
how does using a RF modem for video work
for a project that I am working on we are planning on using a 2.4 or 5.8 ghz modem for sending video to a ground station, but we dont know anything about the architecture of using rf modems. does anyone have experience with transmitting video digitally vs analog? how can we find the amount of bandwith required for video.
sharkforce is offline Find More Posts by sharkforce
Old Nov 18, 2011, 01:22 AM
radialmind is offline
Find More Posts by radialmind
Brazil, PE, Recife
Joined Apr 2011
Digital video transmission is easiest just using wifi. There are loads of projects for outdoor wifi transmissions (antennas, stations, boosters, etc.). Ubiquiti and Mikrotik come to mind. The bandwidth for wifi is 21-24 MHz depending on your band. Analog video typically uses around 23MHz, but only actually requires 17 Mhz. You can't achieve HD for analog, because it's completely full. The only improvements that can be made is to exchange color for luminance or make more use of the entire time window between vsyncs and after hsyncs. Digital (wifi) uses clever modulation techniques, which is why the information transfer is much, much higher.
WiFi is subject to issues over very long distance (>2-5km). ACK timeout windows need to be adapted for such long distances. So specialty outdoor wifi equipment becomes a necessity.
WiFi bitrates are not necessarily constant. If there are other stations around you, the station will typically reduce the bitrate to allow other stations to transfer information. So urban areas may give you much less actual bitrates than 'middle-of-nowhere' setups. Other questions that may be relevant are here:
http://www.wlanantennas.com/faq.php
MJPEG digital requires high bitrates that I don't think fit into a 54 Mbps wifi link (typical). But H.264 does, as this requires somewhere around 10 Mbps. I need to do more accurate measurements there, but it should be possible to contain up to 4 streaming HD video links, assuming there is no congestion on your band. A spectrum analyzer helps there.
A good and bad thing about analog is that you have gradual degradation of the signal. Digital hits a cliff where error correction algorithms suddenly can't deal with the errors any longer and absolutely nothing gets through. Digital however allows you to get picture perfect images from far distances if the link is good and equipment should typically have indications of signal strength and signal quality (the amount of error corrections being done).
Does that answer your question?
radialmind is offline Find More Posts by radialmind
Old Nov 18, 2011, 03:43 AM
fly the best
Joined Apr 2010
thanks, I understand what you're talking about with how digital works vs analog and I actually learned about the differences between analog and digital RF in my spacecraft systems engineering class today in a lecture on TT&C.
But what I want to figure out how to do is a video data link for a small uav. say using something like this, http://www.microhardcorp.com/n2420.php, the idea is to have a video data link similar to what aeroviroment has done with their SUAS DDL in upgrading their MAV's.
another question I have, is the compression of video (say h.264 for example) typically done on the camera unit itself or on the transmitter or somewhere inbetween like with an onboard computer..
Old Nov 21, 2011, 05:28 AM
camship is offline
Find More Posts by camship
Resistance is Futile
camship's Avatar
United States, FL, Panama City Beach
Joined Oct 2001
Generally the encoding is done on a separate dedicated device or by an on board computer.This is a $12,000.00 stand alone video modem you are talking about duplicating. Please note it is a two way active link system. Those are some mighty big pants to try and fill if you just learned about analog vs.digital transmission just the other day.
Everything you are asking about is going to introduce lag into your video system. You will not likely be able to reliably use the video for piloting purposes unless you manage to duplicate AeroVironment's work.
Good Luck,
Rob
camship is offline Find More Posts by camship
Old Nov 21, 2011, 06:41 AM
Don Moretti is offline
Find More Posts by Don Moretti
Joined May 2009
Is there a link to his work?
Don Moretti is offline Find More Posts by Don Moretti
Old Nov 21, 2011, 08:16 AM
camship is offline
camship's Avatar
Joined Oct 2001
If you are wanting AeroVironment, Inc.
Rob
Old Nov 21, 2011, 08:32 AM
Joined May 2009
Superb, thanks
Old Nov 22, 2011, 01:31 PM
fly the best
Joined Apr 2010
let me ask another question guys, I am looking simply for a system to compare with, what are the existing systems that anyone knows about that uses a digital video data link.
and specifically what I really need to know, what is the throughput requried for whatever resolution and framereate of the camera that they are using. the raven uav and other aeroviroment stuff does not list those parameters that I need to know about their camera specs and video link.
Old Nov 26, 2011, 02:10 AM
marhar is offline
Find More Posts by marhar
Mark Harrison
USA, CA, Piedmont
Joined Jun 2010
Originally Posted by Don Moretti View Post
Superb, thanks
BTW, if his name sounds familiar... he's the guy that did the Gossamer Albatross back in 79, the first human-powered flight over the English Channel.
It's great to see he hasn't rested on his laurels the past 30 years!
marhar is offline Find More Posts by marhar
Discussion How does an ESC work? sngehl01 Electric Power Cars 17 Oct 31, 2011 01:24 PM
Help! HEX config using Pro and GPS does not work cicadafx Hoverfly Technologies 2 Oct 23, 2011 09:18 PM
Discussion How does this work? micro_builder Life, The Universe, and Politics 9 Sep 27, 2011 03:56 PM
Discussion How well does the Dream Flyer FHSS module work for fpv? randall1959 FPV Talk 0 Apr 16, 2011 10:07 PM
Discussion Does anybody know how to make decals using PC? (for crashed hawk - see the video) cherokeedriver Electric Ducted Fan Jet Talk 7 Aug 24, 2008 04:29 PM
