Old Nov 17, 2011, 08:39 AM
Voguna is offline
Find More Posts by Voguna
Norway, Oslo
Joined Jun 2010
Servos doesn´t work when they get cold? Then start working at room temp again.
I was going out and flying, but one servo didnt work when I tried to start up the plane. I walked for 5 min from my home to the field, and in that time, they have gotten to cold and dont work. When I take the plane inside again, they start working again.. I have a hacker 55 esc.. Anybody had the same problems?
Voguna is offline Find More Posts by Voguna
Old Nov 17, 2011, 08:43 AM
ashdec87 is offline
Find More Posts by ashdec87
ashdec87's Avatar
United States, MI, Detroit
Joined Feb 2004
how cold? The grease inside might be gumming up
ashdec87 is offline Find More Posts by ashdec87
Old Nov 17, 2011, 09:35 AM
Voguna is offline
Norway, Oslo
Joined Jun 2010
Its 0-3 C here in Norway now.. I just did a test, had the plane inside for 1 hour, then all servos worked. Took it out for 15 min, then the servos didnt work. They have got warmed up again now, and work again. Maybe they dont "start" in cold? I will try to "start" them inside, take the plane out for 15 min, and see if they stop working..
Old Nov 17, 2011, 09:48 AM
houstonderk is offline
Find More Posts by houstonderk
United States, MD, Clinton
Joined Oct 2010
interesting... what kind of servos are these?
houstonderk is offline Find More Posts by houstonderk
Old Nov 17, 2011, 09:53 AM
ashdec87 is offline
ashdec87's Avatar
Joined Feb 2004
I wonder if there's a loose solder joint that's breaking the connection when it gets cold..
Old Nov 17, 2011, 11:51 AM
Voguna is offline
Norway, Oslo
Joined Jun 2010
I bought them from Klique. Standard servos. Can It be the esc BEC that doesnt work in the "cold"? Hmm, strange.. I havent lost servo control in the air. It seems to be just when I start up in the cold. They dont "activate"..
Old Nov 17, 2011, 12:08 PM
DarkHeli is offline
Find More Posts by DarkHeli
Future-proof EVERYTHING
DarkHeli's Avatar
NY
Joined Jul 2008
I wouldnt get back in the air with that problem! fix it first before you have to fix it all.
DarkHeli is offline Find More Posts by DarkHeli
Old Nov 17, 2011, 02:49 PM
Voguna is offline
Norway, Oslo
Joined Jun 2010
I dont quite understand what to fix, haha. It can be the ESC or the servos..
Old Nov 18, 2011, 07:58 AM
GliderLover is offline
Find More Posts by GliderLover
Joined Apr 2008
...or simply the battery
GliderLover is offline Find More Posts by GliderLover
Old Nov 18, 2011, 08:04 AM
nabazul is offline
Find More Posts by nabazul
Joined Jun 2010
Try to remove the grease of the gears. it can become solid at low temperatures. However this will dramatically reduce the live of your servos.
nabazul is offline Find More Posts by nabazul
Old Nov 18, 2011, 08:10 AM
pda4you is offline
Find More Posts by pda4you
pda4you's Avatar
USA, TX, Trophy Club
Joined May 2002
I have flown in 20 below zero with no servo issues.
Old Nov 18, 2011, 10:00 AM
ashdec87 is offline
ashdec87's Avatar
Joined Feb 2004
me too, which is why I'm thinking solder. Try swapping out components to see what's giving you issues.
Discussion Servo doesn't work when plugged into elevator channel komodomoe 3D Electric Heli Flying 0 Sep 22, 2011 04:00 PM
Discussion IL-2 Sturmovik...joystick didn't work, then worked, then stopped working. T.D. Simulators 1 Jun 11, 2011 10:50 AM
Discussion High stiffness epoxies for wet layup at room temp. smed Composites Fabrication 4 Apr 30, 2011 09:10 PM
Blue bird servo doesn't work in cold temp rocstar Foamies (Kits) 0 Nov 30, 2004 10:55 PM
