Old Jan 30, 2012, 03:06 PM
jimbo320 is offline
Find More Posts by jimbo320
Slopeaholic
jimbo320's Avatar
Joined May 2011
Yes Wiker, It certainly does look like that was the front runner maybe.
Bob, Yes going to build another fuse with E-Power. Hence the blue decals.
That would be my first E-Glider, so im leaving it for now.
RE the stripes, i like them, its a european look. Ill lay them on and see how they look. I wont stripe the underside. I like a few high vis decals and i think the Alpina will need it as these models have a tendency to be flown in strange orientations...
jimbo320 is offline Find More Posts by jimbo320
Old Jan 30, 2012, 03:14 PM
Wiker is offline
Find More Posts by Wiker
Wiker's Avatar
Norway
Joined May 2003
Isnít she lovely Mmm.. those large obeche wings Ė almost a shame to cover them up.
Wiker is offline Find More Posts by Wiker
Old Jan 30, 2012, 03:22 PM
jimbo320 is offline
Slopeaholic
jimbo320's Avatar
Joined May 2011
Wiker, They are even better in the flesh. The quality is outstanding.
Heres her big sister the 'Vortex'. 5m and 6.75kg.
Old Jan 30, 2012, 05:54 PM
fly2bob is offline
Find More Posts by fly2bob
fly2bob's Avatar
United States, CA, San Diego
Joined Nov 2005
Wilker.......I had just tried to both slightly inward and then outward. Didn't notice much improvement but thanks I'll try bending the rear one like that. Never heard of the Condor. Another beautiful bird. Multiplex sure knew how to make'em !!! Love the MULTIPOXY fuse. You wouldn't happen to have a link for the auto lock stab mechanism, would you ? I've looked all over and can't find it.
Jimbo.......I agree but the vis strips IMHO should be on the bottom. When you get around to it, you'll LOVE the electro version !!!
fly2bob is offline Find More Posts by fly2bob
Old Jan 31, 2012, 04:12 AM
Wiker is offline
Wiker's Avatar
Norway
Joined May 2003
Iíve looked through my boxes. If only I could find the set I bought, but no
Just google: multiplex 725137
http://www.modelmaniacsonline.co.uk/...Pendel+Lock%29
http://www.hobbydirekt.de/Pendel-Loc...137::1986.html
Came across a couple of links that might give some ideas/inspiration to other solutions:
http://www.rc-network.de/forum/showt...er-wie-sichern
http://www.rc-network.de/forum/showt...ruderanlenkung
Bending the rod, it doesnít feel very secure, no, but seems to create enough friction to hold the tail in place. After landing, my tail panels have never been more that maybe 1-2 mm out, and I suspect it happens at touchdown. A more secure solution would make me feel a bit more comfortable though.
Old Jan 31, 2012, 05:07 AM
jimbo320 is offline
Slopeaholic
jimbo320's Avatar
Joined May 2011
I started on the wing install. Should take a few days at least. 6 servos to install which are all slightly too big for the bays. Oh well, i suppose i could of installed something skinny instead and made the job easier but i should get them in.
Regarding the covering, i was chatting to a very experienced local modeller about preparation before covering with oracover.
He mentioned sanding sealer and dope, with a preference for dope as this will dry stiff and provide some additional rigidity and crush resistance (albeit with the caveat that getting any on the foam will screw things up big time).
Old Jan 31, 2012, 06:34 AM
fly2bob is offline
fly2bob's Avatar
Joined Nov 2005
well I tried ( A LOT ) searching for it w/ google, but to no avail. Looks like they are no longer in production and I only found one place that had them, but they don't ship to US. WTH do T/D owners do that have a full flying stab?
Old Jan 31, 2012, 06:44 AM
Shedofdread is offline
Find More Posts by Shedofdread
Deniable plausibility
Shedofdread's Avatar
Derbyshire, UK
Joined Aug 2008
I can't comment on the Alpina but on aeroplanes of mine that feature such a tailplane, the rear joiner (the one that moves in a radial slot) is a smaller dia to the front (pivot) one. This smaller joiner is glued into one tailplane half and the other end has a tiny bend in it (last 15ish mm). Don't go overboard on the bend - you don't need much at all. When I used to do such things, this proved more than adequate for big winch launches etc.
HTH,
S
Shedofdread is offline Find More Posts by Shedofdread
Old Jan 31, 2012, 07:09 AM
Woodstock 1 is offline
Find More Posts by Woodstock 1
Woodstock 1's Avatar
Ireland, County Kerry, Kerry
Joined Dec 2005
There's a reason why these are so scarce: lack of demand. There are millions of models flying with AMT's held in place by simple friction (not even bends in the rods) with no problems ever. In fact, if you can shake a normally-mounted tailplane half free during flight, I'll eat my Alpina.
Woodstock 1 is offline Find More Posts by Woodstock 1
Old Jan 31, 2012, 07:16 AM
jimbo320 is offline
Slopeaholic
jimbo320's Avatar
Joined May 2011
Soldered the other wing connectors. Wow was that tricky.
Also Had a look at the film hinges, again another tricky job. Manual says use a circular cutting disk, i made do with a craft knife.
RE Tailplane joiner, there is a clip on the Pro which secures the two tailplanes halves together.
Old Feb 01, 2012, 01:28 PM
jimbo320 is offline
Slopeaholic
jimbo320's Avatar
Joined May 2011
Wing Install
Well ive done the 'First fix', ie a dry run of all the servos. Not quite sure how i managed to shoehorn those big hitec 5245s in there, but they all fit and the tops fit nicely. It was quite a squeeze. But the wings were thick enough.
The Hs85s on the brakes also fitted ok, i removed some foam to get them to fix.
Next step is the epoxy all the cases/mounting and loom wires in place.
I will also add a little glass in the bottom of each tray to give a little extra strength.
Heres the pic.
Old Feb 01, 2012, 05:59 PM
Trevor1 is offline
Find More Posts by Trevor1
Joined Jul 2007
Ozzie Alpina nut
Hi Alpina lovers, In my Alpina fleet i have 3, Current one in use is a 4001 Cabrbon edition, then a 4001 pro just finished never flown, and a 5001 on the building board waiting for servos,its great to have this thread on rc groups.
long live Alpinas
Trevor1 is offline Find More Posts by Trevor1
Old Feb 01, 2012, 11:00 PM
fly2bob is offline
fly2bob's Avatar
Joined Nov 2005
Niccccce !!!
Old Feb 02, 2012, 01:08 AM
jimbo320 is offline
Slopeaholic
jimbo320's Avatar
Joined May 2011
Three! Wow.
Wheres that lovely beach you're flying from? Looks very green for Ozzie.
Could do with that here, currently -2C
Old Feb 02, 2012, 07:53 AM
jimbo320 is offline
Slopeaholic
jimbo320's Avatar
Joined May 2011
First fix epoxied in place. Fix servos and solder joints tommorrow. Will be time soon to play with the radio and get this bird in the air. Woohoo!
Sold Multiplex ALPINA CARBON MASTER EDITION Rain Maker Aircraft - Sailplanes (FS/W) 54 Nov 14, 2013 11:29 PM
Discussion Alpina 4001 electro master edition hendrix Electric Sailplanes 46 May 08, 2009 02:59 PM
Sold Alpina 4001 Carbon Master Edition kit NIB XB-70 Aircraft - Sailplanes (FS/W) 0 Apr 06, 2009 05:48 PM
Sold Multiplex/Tangent Alpina Pro 4001 Carbon Master Edition sekollera Aircraft - Sailplanes (FS/W) 6 Aug 30, 2007 08:51 AM
For Sale Multiplex Alpina 4001 Carbon Master Edition NIB Mark Miller Aircraft - Sailplanes (FS/W) 4 Aug 09, 2006 10:31 AM
