So far I have mine all together and the CG can be moved back to about 45mm with a 2650 3s as far back as possible in the battery bay. I get the feeling that this needs to have the CG just behind the spar? Am I wrong?
Will dial in lots of expo to make the wing less twitchy. The instructions if you can call them that are very lacking on the amount of up/down elevator. I am going to use 3/4" high and 5/8" on low rates. Will start with the same on the ailerons also. I am mixing about 50% into the rudder from the ailerons like on my Roswell. If the weather here in the Great North Wet is good like today will try and maiden her. Wish me luck! |
The instructions SAY ... 40mm +-2mm back from the LE.
That is WELL AHEAD OF THE SPAR !!! It is just ahead of the Former which is behind the wheel. The spar is back behind that former. Flying Wings need a CG ahead/forward of CG's on Regular planes. I would NOT even try fly mine with the CG behind the spar ! IMHO It's already tomorrow in OZ so this may be Too late :-( Oh wait !? ! Outback Joe is showing OR as a location - now i'm confused ! Wait again ... I get it. Lakeview OR is about as outback as you can get in the States ! Possibly the Alvord desert and Fields Station is more out back "-) Bob |
| Thread Tools | |
| Discussion Figuring out electric engine size for my flying wing. | peternemser | Flying Wings | 5 | Nov 07, 2011 04:08 PM |
| Wanted 48" Flying Wing/Combat Wing Electric | wbrannies | Aircraft - Electric - Airplanes (FS/W) | 8 | Sep 30, 2011 08:20 PM |
| For Sale electric boomerang flying wing | glennjunior1 | Aircraft - Electric - Airplanes (FS/W) | 4 | Jul 25, 2011 10:36 AM |
| Discussion Will this Wing work for flying electric | kallie20 | Flying Wings | 7 | May 09, 2011 04:23 AM |
