Old Nov 16, 2011, 12:37 PM
DOOMSman is offline
Find More Posts by DOOMSman
DOOMSman
Joined Nov 2011
Ice boats
HELLO, brand new to the site and RC. I and some neighbors are discussing
some simple ice boats, the basic rules to be hull to start as a 1x3 36 inches
long and the rigger to start as a 1x2 24 inches.
the sail to be contained in a square 20 x 24 inches.
Being mostly retirees we are looking at hobby king radios.
Ideas or a separate area on the forum?
DOOMSman is offline Find More Posts by DOOMSman
Old Nov 16, 2011, 08:36 PM
Dick L. is online now
Find More Posts by Dick L.
Dick L.'s Avatar
Minnesota, USA
Joined Aug 2002
http://iceboats.tripod.com/
Owned by Tony Johnson (Minneapolis) who is also a decent softwater r/c sailor. He and Bill Korsgard (now deceased) from Madison WI were pushing the idea and r/c iceboat / landsailer classes.
Dick L. is online now Find More Posts by Dick L.
Old Nov 17, 2011, 08:47 AM
DOOMSman is offline
DOOMSman
Joined Nov 2011
Dick thank you for the link. Those are some very nice
ice boats and I got some ideas looking at them.
Old Nov 20, 2011, 10:07 AM
Brooks is offline
Find More Posts by Brooks
Damp and Dizzy member
Brooks's Avatar
Bozeman, Montana, United States
Joined Aug 2003
Simple iceboats for sail or motor:
http://www.rcgroups.com/forums/showt...86#post8648677
Brooks is offline Find More Posts by Brooks
Old Nov 28, 2011, 01:35 PM
DOOMSman is offline
DOOMSman
Joined Nov 2011
Thank you Brooks, I like the springs on the steering,
I was wondering about servo damage.
I wonder would a third channel for a fork brake
be worth the money and extra weight?
Old Nov 29, 2011, 05:55 AM
Brooks is offline
Brooks's Avatar
Joined Aug 2003
Fork brake was for the powered version, fun, but not necessary. Helps with racing, just like brakes on a car, but not needed for a sailboat. Adding weight is a good thing, servo or lead: it gives the craft more momentum for completing a tack, and will also increase the allowable windspeed if the weights are on the outriggers. I used velcro straps to attach the lead (shot in a 35mm film container). This way I could remove them if I wanted.
When making the skates, be sure to grind the V on the bottom for a 90 angle. I sharpened mine to less than 90 degree to reduce skidding....but the skates then dug into the ice too far, and the boat would not move, hoho. There is usually plenty of power to move the craft, as long as the skates are not digging in too deep. Ice boats are faster than water boats due to the very small drag of skates compared to a hull in water.
Old Nov 30, 2011, 08:50 AM
1967250s is offline
Find More Posts by 1967250s
1967250s's Avatar
United States, VA, Alexandria
Joined Sep 2008
Dang it, wrote this once and lost it.
This reminds me of my ice rink days and sharpening days. Ice skates have a concave ground into the bottom. Speed skates are actually flat to get the least resistance. I would recommend about a 2 or 3 inch radius groove on these little blades. This will give enough surface to hold the ice boat up, without digging in and grabbing the ice. The sharpened edges will keep it from skidding. When it gets worn down, often a quick swipe along the edges with a sharpening stone will be enough, depending on the surface you run on. I would often sharpen my stainless steel skates only 2 or 3 times a season, and I skated a lot! Maybe angle the blades inwards a degree or two.
Speed skates are stoned in a special jig that holds both blades next to each other, perfectly parallel. A stone is run forwards and backwards, gently, until you have perfect square edges. Beware, the edge will cut you. This would get you the most speed, I believe.
You see, skates actually ride on a layer of water. The larger the surface, the more support the water gives. Of course, too much will slow you down. Speed skates are very narrow, only 1/16th, but long and with little rocker. Hockey skates are a little wider, with figure skates the widest. Hope this helps with the season here. More pictures and videos, please.
1967250s is offline Find More Posts by 1967250s
Old Dec 12, 2011, 02:09 PM
DOOMSman is offline
DOOMSman
Joined Nov 2011
I am ready to order a system and need to know about servos.
How do you know what connectors are on hobby kings receivers and servos?
Are most servos 40 degree travel as listed?
Thank you.
Old Dec 12, 2011, 07:05 PM
Dick L.'s Avatar
Minnesota, USA
Joined Aug 2002
Most of the time, you will be sailing close hauled if ice/land yacht. Will never be sailing dead downwind (tack upwind and down for speed), so servo needs to have torque to hold sail in - and at the same time have speed to "dump" the if you happen to get overpowered.
Old Dec 28, 2011, 04:28 PM
DOOMSman is offline
DOOMSman
Joined Nov 2011
Got started on two low buck ice boats. Kind of wondering about low buck 2.4 radios from hobby king but the freight starts to make me think about 15/ 20 dollars more from a local hobby shop. we are two retired men and want to keep it cheap so others will maybe join us.
Also look at the front steering runner, steering horn below the 1x3 or above? We have built mostly with dumpster gold so far.
Old Dec 28, 2011, 05:41 PM
Dick L.'s Avatar
Minnesota, USA
Joined Aug 2002
Do a search on DN Iceboats (the real ones) and you will pick up a lot of info. A double steering runner isn't necessary - you can get by with a single runner.
Also visit RCSailing.net site and do a search on iceboats or landyachts.
Discussion Tug Boats and Tow Boats Stu Kerrn Scale Boats 27 Feb 07, 2012 10:13 PM
Sold FS: CC ICE 60 HV, ICE 75 and ICE 80 HV All NIP cheeseboy Aircraft - Electric - Power Systems (FS/W) 3 Jul 12, 2010 05:27 PM
For Sale Boats, More Boats and Gas Boats for sale! Jon Koppisch Boats (FS/W) 2 Jan 17, 2008 06:21 PM
For Sale Lot of 4 boats and 3 engines. Trade for Helis/other boats. warrgy69 Boats (FS/W) 0 Aug 21, 2005 01:47 PM
3 deg. F. and -19 Windchill=Ice Boats rccrashed Aerial Photography 6 Jan 26, 2003 10:16 PM
