Old Nov 15, 2011, 10:38 PM
Drusky is offline
Find More Posts by Drusky
just a rumour
Drusky's Avatar
South Africa, EC, Port Elizabeth
Joined Jun 2006
StevensAero - re-Run™
I really like the lines of this little chuck glider from Stevens Aeromodels. It has a classic charm.
Forgive the videography. It was a bit silly of me to maiden and record at the same time. I think the model is a bit nose heavy.
P1100156 (1 min 9 sec)
The fuselage is made up of three slabs of balsa. The middle one can be cut out to accept your 1s Lipo and micro receiver. Servos can be mounted as you see fit.
Drusky is offline Find More Posts by Drusky
Old Nov 15, 2011, 11:18 PM
Xpress.. is offline
Find More Posts by Xpress..
Team Hitec, Customer Support
Xpress..'s Avatar
United States, CA, Poway
Joined Oct 2007
That's awesome. I could slope off of ant farts.
Xpress.. is offline Find More Posts by Xpress..
Old Nov 16, 2011, 12:52 AM
MiguelC is offline
Find More Posts by MiguelC
Springs soarer
Colorado springs
Joined Apr 2005
THat is awesome!!! Bill really has some great planes.. I now need to go get one of these..
MiguelC is offline Find More Posts by MiguelC
Old Nov 16, 2011, 02:22 AM
bjaffee is offline
Find More Posts by bjaffee
Brett
bjaffee's Avatar
So Cal
Joined Apr 2002
That is cool. The Stevens Aero kits are great.
bjaffee is offline Find More Posts by bjaffee
Old Nov 16, 2011, 06:01 AM
Drusky is offline
just a rumour
Drusky's Avatar
Joined Jun 2006
This is the first balsa kit model I have ever built. It went together in an hour, faster than any arf I've built. Be sure to read the instructions carefully and then think about the required action before applying superglue. I made one or two silly mistakes that simply could not be undone, fortunately they were not significant errors
The kits are very inexpensive and come with a coin for ballast (moneyback scheme ).
The wing is undercamber and I set cg halfway along the rib closest to the fuselage. If I did this again I would buy two kits. One built as a chuck glider could be used to determine CG.
I see more balsa in my future.
Old Nov 21, 2011, 09:01 PM
Tick Point is offline
Find More Posts by Tick Point
Tick Point's Avatar
Joined Mar 2008
pardon me
bungee maybe?
whats your Rx system? JR compatible?72mhz
i want a wrist-rocket style launch, micro thermal riding machine.
Have you found it?
I'd begin to design one if I had the radio gear. What's it take?
Dave
Tick Point is offline Find More Posts by Tick Point
Old Nov 23, 2011, 02:02 PM
Drusky is offline
just a rumour
Drusky's Avatar
Joined Jun 2006
Hi Dave,
I wouldn't call the result a thermal machine but it slopes quite nicely.
Gear is as follows:
2 of these: http://www.hobbyking.com/hobbyking/s...dProduct=17540
1 of these: http://www.hobbyking.com/hobbyking/s...dProduct=18827
1 of these: http://www.hobbyking.com/hobbyking/s...dProduct=11874
I look forward to seeing your design
Andrew
Old Nov 25, 2011, 12:10 PM
Tick Point's Avatar
Joined Mar 2008
Thanks for the referrals, Andrew. Great prices for each($10Rx, $2batt,$3servo). I'd have to pick up a 2.4ghz Tx, and didn't see a combo available from HobbyKing.
My interest is in building a "low" performance 2ch glider that JrHigh students could build and launch with a small bungee. We have no slope, but would enjoy a short flight, with maybe a loop before touchdown.
My search continues, and I thank you for sharing your design.
Would it handle a bungee launch (light weight elastic cord from the fabric store) or maybe a tow launch from running students?
Old Nov 25, 2011, 02:18 PM
Drusky is offline
just a rumour
Drusky's Avatar
Joined Jun 2006
Not my design Dave. You should consider something like the Fling by Great Planes. Side arm launch type glider would be better in my opinion.
Sold StevensAero SPORTstik slogo Aircraft - Electric - Airplanes (FS/W) 1 Nov 18, 2011 06:54 AM
Mini-Review A Look at StevensAero MR.hooha Electric Plane Talk 26 Jul 15, 2011 08:42 PM
Wanted StevensAero - Dystraction forsakenrider Aircraft - Electric - Airplanes (FS/W) 2 Jun 13, 2011 08:37 PM
Wanted Stevensaero Micro Shaft yood Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 0 May 17, 2011 01:20 PM
Sold Micro Re-run glider toxic-trip Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 1 Mar 07, 2011 03:25 PM
