Old Feb 08, 2013, 03:24 PM
eranrc is offline
Find More Posts by eranrc
eranrc's Avatar
Joined Feb 2010
Hello GhostFlyer1 ! I keep getting mixed up with the all the screen names, my team mates... :-(
Glad to see ya again :-)
eranrc is offline Find More Posts by eranrc
Old Feb 10, 2013, 09:13 PM
Helitime is offline
Find More Posts by Helitime
Pickering Ontario CANADA
Joined May 2010
Question? I have the DFC head. On the of the "draw bars?" there is a double ended bolt threaded into the bottom to which you thread on the plastic ball link. Should the bolt be lock tited in place or is/can it be used for tracking adjustment??
Kerry
Helitime is offline Find More Posts by Helitime
Old Feb 10, 2013, 09:21 PM
beenflying is offline
Find More Posts by beenflying
as much as I can
beenflying's Avatar
NZ
Joined Jan 2010
The metal to metal side must be thread locked or it will work loose and pull out, over time. Be generous with the thread lock and just wipe off any excess.
Unfortunately zero pitch adjustment is one turn at a time, or a half turn and push the link on backwards, or you can use turnbuckles on the servos, and adjust all three for fine zero pitch.
beenflying is offline Find More Posts by beenflying
Old Feb 10, 2013, 10:14 PM
Helitime is offline
Joined May 2010
Understood.
Thank you sir.
Kerry
Old Feb 11, 2013, 11:21 PM
SoftSpeaker is offline
Find More Posts by SoftSpeaker
Joined Dec 2012
What do you mean by "half turn and push the link on backwards"?
I think my blades are not identical, one seems to have a greater angle than the other. I can't seem to correct it using only full turns on the DFC contol link.
I am getting turnbuckles for my 550. Ideal for setting the swashplate perfectly level.
But I can't seem to find any DFC control link turnbuckles. At least not for KDS.
SoftSpeaker is offline Find More Posts by SoftSpeaker
Old Feb 11, 2013, 11:36 PM
Joined Dec 2012
KDS.
Never mind, I figured out what you meant.
Since this is my first build, I am feeling very protective and would not be willing to risk having the DFC control link pop off in flight.
I am currently investigating whether a DFC turnbuckle from other helicopters could be adapted to my KDS 550.
One last thought, the ball links are not pre-threaded, right?
They acquire their thread when the soft plastic is first screwed onto the link rods.
With an ample supply of fresh links, I could experiment with screwing them on, using different starting angles. Through trial and error I may get that half turn I need.
Please correct me if my thinking is wrong.
Old Feb 11, 2013, 11:37 PM
Helitime is offline
Joined May 2010
The instructions tell you to put the ball links on with the letter "A" facing out. The links are slightly larger on the opposite side to make it easier to put them on or take them off. You can put them on backwards but it takes more force, same on removal. It can also open the link slightly if repeated too many times. If you use one backwards just keep an eye that it doesn't get loose if you put it on and off a lot. Once you get it right you shouldn't need to remove it.
Kerry
Sorry, your second post came up while I was typing s l o w.
Old Feb 11, 2013, 11:42 PM
as much as I can
beenflying's Avatar
NZ
Joined Jan 2010
The only DFC turnbuckle links at the moment are the HeliOption ones for the Align 500/550/600/700. I have these for my 500 and 700, but haven't fitted them yet. They certain look very nice.
Even though the ball links are designed to be pushed on from one side they can still be push on from the other side, with some force, if you really need that half turn of adjustment. The one positive about this is the link is less likely to come off.
Old Feb 11, 2013, 11:43 PM
Helitime is offline
Joined May 2010
Correct.
Old Feb 11, 2013, 11:46 PM
Helitime is offline
Joined May 2010
Dam you guys type fast.
OK I'll bite "turbuckle links" ???
How about a link to a turnbuckle link.
Kerry
Old Feb 11, 2013, 11:56 PM
eranrc is offline
eranrc's Avatar
Joined Feb 2010
I still couldn't order a pinon for the KDS 550 V2 :-( Plz let me know if one finds a link, thank you!
Old Feb 12, 2013, 05:03 AM
as much as I can
beenflying's Avatar
NZ
Joined Jan 2010
Kerry
HeliOptions new products page:
http://www.helioption.com/store/inde...e=products_new
Picture showing the POM lock nut and the length of the threads:
http://www.helifreak.com/showthread.php?t=486844
Old Feb 12, 2013, 06:42 AM
Helitime is offline
Joined May 2010
Interesting.
Thank you
Kerry
Old Feb 12, 2013, 08:35 AM
mhills51 is offline
Find More Posts by mhills51
mhills51's Avatar
kansas city
Joined Feb 2007
I have a 12t for the kds550 if you need one
mhills51 is offline Find More Posts by mhills51
Old Feb 12, 2013, 09:54 AM
Helitime is offline
Joined May 2010
Hobbyking has 12 and 13 tooth pinions in stock.
Kerry
Discussion Kds innova 550 flb lenachen Electric Heli Talk 16 Dec 30, 2011 01:10 AM
Discussion KDS Innova 600 FBL - what Flybarless system? JeremyT Large Electric Helis 9 Dec 23, 2011 04:57 AM
Discussion KDS Innova 700E Unboxing rcgirl99 Electric Heli Talk 14 Nov 29, 2011 09:46 PM
For Sale WTT: Trex 600N FB/FBL for Trex 600E/550E FB/FBL RCDXER Aircraft - Electric - Helis (FS/W) 0 Oct 01, 2011 07:19 AM
