Old Oct 31, 2012, 07:42 AM
OrangeBird is offline
Find More Posts by OrangeBird
Wow, the sky is clear
OrangeBird's Avatar
Canada, QC, Chicoutimi
Joined Aug 2012
Originally Posted by Pa flyer View Post
Has anyone tried putting different rotor blades on their 9116? I would like something about an inch longer and stiffer than the stock ones. I was wondering if maybe 9117 blades would work: they would have the length but I don't know about the stiffness.
Hi
DH9100 ( 4 channels )
I did some tests with longer blades (blade FX059) 1 CM longer than OEM ( for each main blade ). Result, I believe it is slower to react. But I could not test it without wind ....
I also back the tail assembly 1 CM, because the main blade touching the tail blade.
I also changed the tail blade for FX059 including the white gear.
I also removed the screw head to replace it with a piece of electrical copper wire, so I can change the head in 5 seconds
You see also spacer for each main blade ( very important )
You see also home made holders canopy ( no OEM holder in stock )
You see also tail protector ( upright tail blade ) protec tail motor and tail blade
Gilles
Description: Name: DH9100 tail.jpg
Description: Name: DH9100 Head.jpg
Description:
OrangeBird is offline Find More Posts by OrangeBird
Old Oct 31, 2012, 10:52 AM
Balr14 is offline
Find More Posts by Balr14
Cranky old fart
Balr14's Avatar
Germantown, WI.
Joined Oct 2007
Longer blades have more stability because they increase blade tip speed.
Balr14 is offline Find More Posts by Balr14
Old Oct 31, 2012, 02:23 PM
warbstar is offline
Find More Posts by warbstar
Joined Sep 2012
Originally Posted by ZaZ View Post
Wind died down enough this evening to get out and give my new DH9116 a second try. The thing would not stop spinning clockwise no matter how much trim I applied. Crashed several times and put the flybar through the canopy twice. So the canopy is pretty much trash and flybar was bent so I just straightened it out. But everything else seems to work if I can get it to stop spinning. I saw the Swashplate to Servo Arm Adjustable Linkage by Stormforce. I am guessing that this is what I need to do? I am new to this and not sure how hard this would be to do. I was hoping to be able to just change some setting on the controller.
Doug
Stormforce did an excellent job with the tutorial. The only thing missing follows:
As you all know by now the manual for the 9116 is worthless. Start by referencing the following manual:
http://www.rcgroups.com/forums/attac...mentid=4971241
This will teach you everything you need to know with one exception. That is how to trim out the 9116 when it is pulling back on the take-off. What I found is that there is a problem with the center of gravity (COG). The COG was too far to the rear.
Here is a reference on where the COG should be located:
http://2bfly.com/knowledgebase/fligh...ncing-and-c-g/
The image shows that the COG should line up with the main shaft. To determine if the COG is too far to the rear, put a rod underneath the landing skids. Roll the 9116 forward and backward on the rod to determine the COG. The rod should line up with the main shaft almost perfectly. Mine was too far to the rear of the 9116. In other words, the 9116 balanced on the rod when the rod was to the rear of the main shaft. To compensate, I put fishing weights into the nose of the 9116. When done, the 9116 balanced on the rod at the COG. It is okay if it is off a tiny bit. That can be compensated for in the trim. Just try to get as close as possible.
That was all it took. After that the 9116 trimmed out I had a near perfect take-off and hover. It was necessary to do some minor adjustments to the trim while in flight. Beyond that there was no further problem.
Finally, be certain to follow the instructions in the manual to learn about leveling the swash plate if there continues to be hovering/take-off issues.
Woot! Have a good time with this one. It is great fun!
warbstar is offline Find More Posts by warbstar
Old Oct 31, 2012, 02:31 PM
mikefromgermany is offline
Find More Posts by mikefromgermany
Not here to help stupids
mikefromgermany's Avatar
Germany, Berlin
Joined Jun 2012
Mick (stormforce) must have forgotten to add it - nevertheless he posted it
http://www.rcgroups.com/forums/showp...postcount=2986
regards
-mike-
mikefromgermany is offline Find More Posts by mikefromgermany
Old Oct 31, 2012, 02:38 PM
warbstar is offline
Joined Sep 2012
Double Horse 9116 Trim - Pulling Backwards on Takeoff
Old Oct 31, 2012, 02:45 PM
Germany, Berlin
Joined Jun 2012
warbstar, thanks for the reminder - I've added it in my Troubleshooting manual
http://www.rcgroups.com/forums/showt...0#post22988195
-mike-
Old Nov 01, 2012, 07:02 PM
Chaplin is offline
Find More Posts by Chaplin
Joined Oct 2012
Hey guys! Been reading this thread for a bit over a week now, up to page 136. I'm feel that I know most of y'all pretty well by now.
I've only been flying for a few weeks now and I already have in my hanger a 9116, 9117, and my starter the MJX F649. I've been having just as much fun modding these heli's as I have been flying them.
Most of my questions have been asked by others and answered, but I have one that involves all these batteries that I got laying around.
I'm needing a balance charger that I can charge more that one battery and charge them correctly. Can ya help me out? What do I need?
Thanks guys, I off to catch up on this thread.
Chaplin is offline Find More Posts by Chaplin
Old Nov 01, 2012, 10:30 PM
Germany, Berlin
Joined Jun 2012
You can buy any decent charger - a lot of B6 clones are available.
I use an Accucell 6 - with the right harness I can serial-charge up to 3 2S-packs at the same time.
Unfortunately you have to make some serial harnesses - or buy them - according to the pic (for 2 2S-packs) below.
-mike-
Old Nov 02, 2012, 02:01 AM
letsstart78 is online now
Find More Posts by letsstart78
Canada, BC, Vancouver
Joined Jul 2012
hello fellows, I have an easy question,
I have this charging cable http://www.banggood.com/Wholesale-Ba...r-p-51891.html and a B6 charger, and 3 1 cell 3,7v 600 mah li-po batteries.
to charge them at the same time what option should I chose? 3 cell 11,1 v or 1 cell 3,7 v at 600 mah?
letsstart78 is online now Find More Posts by letsstart78
Old Nov 02, 2012, 09:07 AM
Steve_ is offline
Find More Posts by Steve_
Venting Nowlege
Steve_'s Avatar
United States, WI, Beloit
Joined Nov 2012
Found this on YouTube:
Double Horse 9116 , 9117 Transmitter Backlight Mod (1 min 7 sec)
Steve_ is offline Find More Posts by Steve_
Old Nov 02, 2012, 09:15 AM
CrazyLegsFE is offline
Find More Posts by CrazyLegsFE
Joined Oct 2012
letsstart78,
This thread covers your situation nicely. http://www.rcgroups.com/forums/showthread.php?t=932319
To start you need to determine how the cable is wired. Once that is determined you can select the appropriate method from the thread above.
-Josh
CrazyLegsFE is offline Find More Posts by CrazyLegsFE
Old Nov 02, 2012, 10:00 AM
Germany, Berlin
Joined Jun 2012
3 cell 11.1V @ 400mA
or Auto @ 400mA
-mike-
Old Nov 02, 2012, 11:50 AM
OrangeBird's Avatar
Joined Aug 2012
Hi
It is useful to keep the backlight on for TX ?
Gilles
Old Nov 02, 2012, 12:20 PM
Germany, Berlin
Joined Jun 2012
Originally Posted by OrangeBird View Post
Hi
Gilles
not really imho.
you only need the display for programming it or setting subtrims - no need to look on the display while flying - the only buttons you will need the are the trim buttons.
-mike-
Old Nov 02, 2012, 06:47 PM
Chaplin is offline
Joined Oct 2012
Thanks Mike
If I was to charge more than one battery can the be difference mah's?
New Product the first double horse 2.4G and 4CH single blade helicopter 9116 hkmtk Beginner Training Area (Heli-Electric) 32 May 21, 2013 01:27 PM
Help! Heli Spins out when ascending (Z101, looks like the double horse) Shlofter Electric Heli Talk 5 Aug 16, 2012 01:59 AM
Discussion Double Horse 9097 24" Heli Jake8131 Electric Heli Talk 8 Mar 14, 2012 07:05 AM
Sold 9089 Double Horse Shuttle Electric Heli w/Video DVR Senor Jack Aircraft - Electric - Helis (FS/W) 0 Apr 10, 2011 08:15 PM
