Rip out all additional weight (pennies...) and finally start trimming the bird mechanically! You will not need any tools than the small philips screwdriver that was delivered with the heli, promised! download this: http://customers.skymesh.net.au/~mat...ech_manual.pdf and follow the instructions "DH9116 Initial Basic Swashplate Leveling Procedure & Mechanical Trimming / Adjustment of the Servo Arms & Linkages" This is the easyest way to get the best out of the bird. Don't forget to reset your TX to factory first - it's also in the manual mentioned above. -mike- |
Take off
After more and more flights on DH9116. If you are not able to make a good take off , and not able to center the tail CWW or CW, close the RX and TX and restart all.
At this new start, gradually add power and center the tail ( with trim on TX ) and make a very good take off, the helico goes up right in front of you. Trim reverse of the tail go.... You may repeat this rule at each flight if the tail not go right in front of you. Bye Gilles |
Took the 9116 out a little while ago, as we finally have a nice day with light winds at 5-10 MPH. I crashed her twice, and both times the flybar struck the canopy and cracked it.
Other than that, she held up well in the crashes, nothing else was broken.I ordered a new canopy today, with a plethora of other spare parts for this bird including rotor blades, tail motor etc. Parts should arrive next week sometime. Considering she's still flyable, I plan to get her in the air again this afternoon sometime. Hopefully, that flight will be more successful than the last...
Flybar
I changed EOM flybar and I added weight adjustable and it seems to go very well. Currently, it has two weights each side, with one weight by side does not work, no stability. The original flybar break the canopy and make a bump to tail boom. The new flybar 6 inches is expected not to break the canopy and no bump to tail boom. She is currently on a DH9100 DH9116 converted, I have not quite finished the conversion, I miss a servo and swachplate. I will give you the results later to see if I will not have more damage. OEM flaybar end ( ball ) = 3.9 gr My 2 weights = 1.9 gr ( you can add more weights if you want more stability) The best combination seems to be 3 weights = 2.7 gr by side See also: http://www.rcgroups.com/forums/showp...postcount=1953 Bye Gilles |
Joined Oct 2012
Ok new to the thread and currently deployed in the middle east. I love the dh 9116 but the other day when I got to take off with it , it starts to rotate. I give it more throttle , it straightens out then I rotate it again and it spins 360 five or six times. I rotate left it turns nicely, rotate right it spins. Then it rotates to the right nicely. I'm thinking it has to be the tranmitter but kinda new at troubleshooting little helis instead of P-3 orion, any help would be nice. Thanks
I find this in other thread for you.... http://www.rcgroups.com/forums/showp...postcount=3084 Bye Gilles |
Joined Aug 2012
| Thread Tools | |
| New Product the first double horse 2.4G and 4CH single blade helicopter 9116 | hkmtk | Beginner Training Area (Heli-Electric) | 32 | May 21, 2013 01:27 PM |
| Help! Heli Spins out when ascending (Z101, looks like the double horse) | Shlofter | Electric Heli Talk | 5 | Aug 16, 2012 01:59 AM |
| Discussion Double Horse 9097 24" Heli | Jake8131 | Electric Heli Talk | 8 | Mar 14, 2012 07:05 AM |
| Sold 9089 Double Horse Shuttle Electric Heli w/Video DVR | Senor Jack | Aircraft - Electric - Helis (FS/W) | 0 | Apr 10, 2011 08:15 PM |
