Old Sep 06, 2012, 03:09 PM
NeilGerrard is offline
Find More Posts by NeilGerrard
NeilGerrard's Avatar
United States, UT, Draper
Joined Sep 2012
Bought a 9116 from Banana Hobby for $39 + $11 shipping. It's my first upgrade from Coax. Got 2 900mah batteries from ebay, unfortunately I got 15c instead of 20+. I wish I would have read more of this long thread prior but thats how it go's. I for one am interested in making all the adjustments suggested and am excited. I know all you guys have received many thanks but here is one more. Don't have the bucks for anything more expensive but keep my eye open for great deals. I believe from the suggestions here that rather then moding up the 9116 it best to just slowly acquire the mode for my eventual Align/clone. Once again thank you all for taking the time to post your experiences here.
NeilGerrard is offline Find More Posts by NeilGerrard
Old Sep 06, 2012, 05:57 PM
rexless is offline
Find More Posts by rexless
Fly Fast, Fly Hard, Fly Fun
rexless's Avatar
Canada, BC
Joined Apr 2012
Have you tried your 15C batteries? I would guess you should be able to fly just fine with those. I have a 20C 900mah and it does seem a little snappier than the stock battery.
rexless is offline Find More Posts by rexless
Old Sep 06, 2012, 05:59 PM
rexless is offline
rexless's Avatar
Canada, BC
Joined Apr 2012
Imax B6 - Is it normal for these (even my fake one) to have the screen go blank a little while after it finishes a charge? The charging seems fine, the LOUD beeps signal the end, then if I leave it awhile I go back and the screen is completely blank and the buttons don't do anything.
Old Sep 06, 2012, 08:02 PM
Pa flyer is offline
Find More Posts by Pa flyer
Joined Aug 2012
I-max
I also have a fake one. When it's finished charging it flashes "FULL" and beeps. The screen doesn't go black and the buttons still work even if it's been awhile. Doesn't necessarily mean there's anything wrong with yours. As I understand it there are different fakes out there.
Pa flyer is offline Find More Posts by Pa flyer
Old Sep 06, 2012, 09:26 PM
hifinsword is offline
Find More Posts by hifinsword
Blue Skies
hifinsword's Avatar
United States, VA, Williamsburg
Joined May 2012
Welcome aboard Neil. Wow, you got a great deal on your 9116!
Don
hifinsword is offline Find More Posts by hifinsword
Old Sep 06, 2012, 09:40 PM
Joined Sep 2012
Haven't got them yet. Must be on the slow boat from China along with my spare rotors and main blades.
Old Sep 07, 2012, 08:53 AM
john1911 is offline
Find More Posts by john1911
Joined Apr 2012
Some 9116 Mods
Hi All, First of all, many thanks again to Stormforce for helping when I got my 9116 all screwed up back in May!!! I have been flying and crashing it ever since. Now to the mods. The PC board seems good for several good crashes and then it dies. The two most common failures for me have been losing the receiver and losing tail rotor control (Tain rotor spins but tail spins one way with full throttle and the other with low throttle). My fix for both of these has been 5 minute epoxy. The loss of receiver seems to be one of the wires attaching the crystal breaking and the loss of tail control seems to be the little can on the gyro board vibrating loose. Every time a replace a board now, I epoxy the can for the crystal to the board (pretty heavily) and I slide the little piece of shrink tube off the gyro board and epoxy the can to the board and slide the shrink tube back on. This seems to have eliminated those failures with no other ill effects. The other mod seems to result in more crashes and more spectacular crashes, but is still fun!!! I cut off the balance bar weights with a dremel and added the flybar weights from a Trex 450 (my other addiction). These weights are much smaller and make the 9116 MUCH more responsive, perhaps tooo responsive, but it's fun to fly and goes really fast in all directions. Don't get it headed at the ground toooo fast as the motor doesn't have enough power to pull it out quickly and you can end up having the landing skid split the canopy about an inch back! Ouch!!!
Also, more of an FYI, I have gotten a bunch of motors recently that appear to have the timing for the brushes screwed up. They seem to work normally while they are working, but the brushes disappear after about 14 flights and if you don't catch it, you can burn up the MosFet for the main motor. Nothing you can do about this that I am aware of, but watch out and replace motors as necessary. It is always the brush attached to the red motor wire that goes first. The most recent motor I put in has 15 flights and the brushes look almost new, so it seems this one is a good one. Motors now, when I get down to 5 I order 5 more.
Happy flying, John
john1911 is offline Find More Posts by john1911
Old Sep 07, 2012, 12:03 PM
rexless is offline
rexless's Avatar
Canada, BC
Joined Apr 2012
Stormforce is a valuable resource for sure!
I am going to epoxy my components as well. I have a bad PCB on my newest version but hopefully a replacement will love that.
I can't wait to see your fly bar mod. 14 flights per motor seems nuts though. I must be well past due on my first one. Now I'm going to check it out...
Old Sep 07, 2012, 09:44 PM
OrangeBird is offline
Find More Posts by OrangeBird
Wow, the sky is clear
OrangeBird's Avatar
Canada, QC, Chicoutimi
Joined Aug 2012
Test
Bye
I made a test...
Hello, here is a protected propeller tail modified (add 1 CM protection) for DH9119 helico
Bye Gilles
OrangeBird is offline Find More Posts by OrangeBird
Old Sep 07, 2012, 09:51 PM
OrangeBird's Avatar
Joined Aug 2012
Two holes
Hi
For easy access to the main engine 2 screws, make 2 holes in the DH9116 and easy change main motor
Bye Gilles
Old Sep 07, 2012, 10:14 PM
OrangeBird's Avatar
Joined Aug 2012
Blind
Hi
For those who fly at night, I added a piece of paper under the white LED with Scotch tape, because I blinded. With this sticky white sheet of paper, I'm not blind and it is great ....
Bye Gilles
Old Sep 07, 2012, 10:16 PM
OrangeBird's Avatar
Joined Aug 2012
Blind
The photo of white paper......
Bye Gilles
Old Sep 07, 2012, 11:29 PM
Gator3434 is offline
Find More Posts by Gator3434
Joined Aug 2012
I know you get what you pay for, when it comes to the 9116 but I had another servo go out on me today. The first one quit after the second flight the replacement was DOA and today the other side went out.
This issue along with bad PCB causing intermittent failures is really bringing me down. Seems I spend more time waiting for replacement parts in the mail than anything else. Thinking about an blade sr120 or even a mcpx. Supported by my LHS.
Don't get me wrong, I'm glad I got it, just complaining to you guys because I can!
Gator3434 is offline Find More Posts by Gator3434
Old Sep 08, 2012, 12:45 AM
john1911 is offline
Joined Apr 2012
Couple more comments
Hi All, First of all, for Orange Bird, I forgot to mention that I too drilled holes in the bottom plate to access the motor screws. Great Idea!!!
For Gator3434 - The 9116 is a great machine for what it is, but the Chinese QC is CRAP!!!! Having said that, how they can develop, produce and ship a PC board to the us and sell it for $15 is beyond my imagination. You will get some bad parts (I threw away two new servos today that I hadn't tested and they were crap) so just live with that or buy Blade. I have a Blade MCX2. It is fun for inside the house or motorhome, but it's really pricy for something that fits in the palm of your hand. On the other hand I haven't had any bad Blade parts for either the MCX2 or the Blade 450, they are just *way* more expensive. I have several Trex 450 clones and they too are great, but you have to be prepared for parts that are just Crap!!! All in all, most of the Double Horse or Trex clone parts I have gotten are fine and overall I still spent way less than I would have for an actual Blade or Align products but you just have to be prepared to tweak or throw away parts that should have never gotten past any QC inspector. Guess you just can't have it all. Local availability and great QC come at a price. I just ordered another PCB and 3 servos for the 9116 today.
For the old timers....... I know the DH9117 is the new kid on the block, but it seems like there aren't as many sources for the 9116 parts as there have been and it seems like Banana Hobby is getting out of the 9116 and not selling the 9117. Question is, do you think DH will discontinue the 9116 soon and stop making parts???? I have a pretty good stockpile, but........... Your thoughts would be appreciated.
Happy Flying, John
Old Sep 08, 2012, 01:15 AM
john1911 is offline
Joined Apr 2012
DH 9116 Parts
Hi All, I alluded to it in my last post, but I think Banana Hobby is getting out ot the DH business, hence selling their remaining stock of new 9116's for 40 bucks. Egrandmart, normally a Chinese seller, is selling a bunch of 9116 parts that are shipping from Gardena, CA. for Chinese prices delivered. As I mentioned in my last post, I just ordered 3 servos and a PCB from Egrandmart with shipping from Gardena. If you like the 9116 and can afford it, it might be a good investment to snag some of the US stock, assuming you are not one of the Australia contingent..... Happy Flying, John
New Product the first double horse 2.4G and 4CH single blade helicopter 9116 hkmtk Beginner Training Area (Heli-Electric) 32 May 21, 2013 02:27 PM
Help! Heli Spins out when ascending (Z101, looks like the double horse) Shlofter Electric Heli Talk 5 Aug 16, 2012 02:59 AM
Discussion Double Horse 9097 24" Heli Jake8131 Electric Heli Talk 8 Mar 14, 2012 08:05 AM
Sold 9089 Double Horse Shuttle Electric Heli w/Video DVR Senor Jack Aircraft - Electric - Helis (FS/W) 0 Apr 10, 2011 09:15 PM
