I remember you Ribble, youv'e helped me before, Thank you, DJ |
United States, MD, St. Mary's
Joined Dec 2011
Found my performance problem - the battery
I've been having issues with loosing power while flying and then it would recover, fly for a while, then loose it again, all within the span of a few minutes. Noticed the battery was puffy and decided since I had two (these are the ones from ebay) and this one had probably 200 flights on it, was time to change. Performance was restored and better than ever. And yes, I use a high quality balance charger w/temp probe but I think 200 cycles is probably the outside limit of these batteries in a high drain application like a heli.
So, if you start getting strange performance behavior, check the battery for swelling even though your balance charger seems to be charging it just fine. |
United States, PA
Joined Dec 2011
"bind the good DH9116 to the other transmitter to see what a new binding is like" What I meant was that simply power on transmitter and helicopter is not binding. Binding is making a new transmitter talk to an old helicopter. |
Joined Nov 2011
I can't say what is going on with the 9116 in your vid. Obviously it's an issue with the pcb, possibly a fault in the ic or intermittent wire contact or dry solder on a component. Dry solders will make any electronic device behave erratically, because of the variable resistance values the contact makes. This is especially crucial if the contact that is supplying power to an ic relies on variable resistance to trigger certain actions. Unfortunately this is beyond my capabilities to suggest a fix, as there are just too many things to test. My only suggestion is to test each contact for continuity or re-soldering each and every solder point on the pcb. If it still doesn't work, you have two choices, part it out or get a new pcb ($15) and try again. On the 9958's. I've noticed a slight TBE on my 9958's now that I've fitted them with the mSR flybar too, but the performance enhancements far out way the TBE issue, as it really only shows during a hover, which I don't do much of other than bringing it in to land. I've found after I bound the 9x to my 9958's, I prefer the way the 9958's fly with the oem tx. Maybe it's just that I'm not use to the 9x or I've not set the 9x up properly, but I found it difficult to get the 9x to match the oem tx, than to surpass it in performance capability or ability, which I'm sure it's capable of, I'm just not as capable to program it to that standard, just yet. Unless one fully understands what the 9x is capable of, what it can do and how to adjust it, having more choice with the 9x just makes things more confusing and frustrating, and I already have enough stress in my life at present, and flying these heli's is to help relieve some of that stress, not add to it. So I'm sticking with the oem tx. (BTW, mike, I have a mode 1 oem tx for the 9958 somewhere, as I fly mode 2, if you are in need). |
Canada, BC, New Westminster
Joined Feb 2012
Mike |
United States, PA
Joined Dec 2011
Anyway, a simple test is to bend the FET slightly so the solder connection makes a better contact. Then test with half throttle. If no difference bend slightly the other way and test again. Solder no longer contains lead. Bad factory solder connections are now more common. See "mosFets" in photo. Main motor MOSFET is closest to servo connectors. |
Throttle Problem
FOUND IT!
The problem was a cold solder on a connection pin to the antenna pcb. Everything fine now. (and sold the heli now to a neighbour *gg who visited me to repair his AR Drone) Thanks for all trying to help me with this effect! ![]() Mick - look at this: TBE completely away now, fastest reactions to every little stick movement - but a pain in the a.... to make all things work together, e.g drilling new holes in the carbon shaft... Now I know why the seller of this particular Xieda gave me these parts for free - he wasn't able to mod it by himself. And for the money.. if I had to pay for these parts it would be nearly 30€, it makes no sense to invest this amount in a simple 9958. #edit: Thanks for the offer for the mode1 tx but I use only mode2 ones and have 3 OEM for the Xieda and 4 9116-OEMs already. BTW - can anyone give me advice which settings i have to use in a 9116 stock tx when I want to use it with a Xieda 9958? Mike |
Joined Nov 2011
The servo's should make a sudden short flutter or jitter on power up, as they may have moved when you powered down or the arms may have dropped during storage, so when you power up, they settle back to the position the tx has them set to by the user programming. However, if a servo make's a constant noise or the arms constantly move like they are vibrating (jitter) it is from an over excited step motor within the servo, which usually means the servo motor is on it's way out.
Joined Nov 2011
![]() http://www.hacksmods.com/xieda-9958/ Yes, you can bind the 9958 to a 9116 tx. You will need to increase all the end points (EPA) for throttle, rudder, elevator and aileron to 120% and reverse the direction of the elevator and aileron in the programming. The 9116 will give you a slightly better flight distance than the oem tx, but not much, maybe up to 50m, but at that distance it's hard to see the little guy anyway. Be warned though, the 9958 does not have any "loss of signal" cutoff, like the 9116, so if it gets out of range, it will keep going on with the last throttle and direction command you sent with the tx. Quite a few 9958's have just flown away, presumably back to china, but they will eventually come down when the battery starts to discharge, so my advice is either, don't let it get away from you, or write your name and mobile/cell phone number on the bottom of the canopy, so if it does, and someone finds it, you might have a chance of recovering it later. Also if you fly it at dusk or at night, pop some small 3mm LED's on it, preferably a white flashing led at the anti-rotation point for the swash, above the base of the tail boom meets the main frame, to act as a white strobe, so if it does fly away on you, you can at least follow it and even though the battery might not hold enough power to fly the heli, the led will still flash for a couple of hours after, and the white flashing led will stand out at a greater distance far brighter than any other colored led. |
| Thread Tools | |
| New Product the first double horse 2.4G and 4CH single blade helicopter 9116 | hkmtk | Beginner Training Area (Heli-Electric) | 32 | May 21, 2013 01:27 PM |
| Help! Heli Spins out when ascending (Z101, looks like the double horse) | Shlofter | Electric Heli Talk | 5 | Aug 16, 2012 01:59 AM |
| Discussion Double Horse 9097 24" Heli | Jake8131 | Electric Heli Talk | 8 | Mar 14, 2012 07:05 AM |
| Sold 9089 Double Horse Shuttle Electric Heli w/Video DVR | Senor Jack | Aircraft - Electric - Helis (FS/W) | 0 | Apr 10, 2011 08:15 PM |
