Joined Nov 2011
Welcome back,
How do you find the time to do all those mods, when I thought you'd be catching up on some sleep, with the new born around. Great mods too. In regards to the forwards / backwards movement, if you favor forwards on the swashplate, backwards flight suffers and visa-versa. How did you like the 9958's with the standard flybar against the mSR flybar? I like the mSR flybar better for quicker cyclic response. |
Joined Jun 2012
I managed to solve my problem with tx. Today, I took tx apart and connected precise digital 5k(502) pot to PCB. I found out that for some reason PCB thinks that throttle is 0% when input voltage from pot is 0V and 100% when voltage 0.815V ( on default it should be 100%, 3.3V) so I used digital 503 pot wich I put between pozitive input voltage from PCB and pozitive input pin for pot and set pot to around 24k ohm resistance (I just lovered input voltage on throttle pot to 0.815V and preserve linearity). If PCB again change required voltage for 100% throttle I will just readjust digital pot with a screwdriver. I have tested it on heli and respond is very linear without any RPM jump or dead zone. Thank you very much for your help. |
Australia, VIC, Melbourne
Joined Jun 2012
Joined Jun 2012
![]() I have been flying all day and it is blast: heli responds very nice and it seems that this mod is working. 503 pot is common pot on ebay http://www.ebay.com/itm/2-x-50K-OHM-...item3a6806d14a You can also find it in a set of pots on ebay. When I turn tx on, move stick to max, I have only few bars on LCD. When I go in menu and do do same, I have all bars (heli respond the same way as bars when menu on tx is opened). |
Joined Jun 2012
Hello Forum!
New user with what I hope is a simple problem - haven't been able to find solution through searching this thread (very long thread). Any help with troubleshooting would be great. DH 9116 came configured for Mode 2. Everything works fine in Mode 1 but I have a servo throw problem in Mode 2 for operation of ELEV. When throwing the elevator into full forward only the right servo (looking at the 9116 from the rear) kicks up to move the swash-plate. Servo on the left sits at center value and is unresponsive, causing the swash-plate to angle forward with a considerable lean. I can manually over-ride it if I push the elevator/aileron stick towards the upper right corner but it just doesn’t feel right. Backwards operation of elevator works fine pulling the elev/aile stick straight back; swash-plate is evenly situated with a backward angle but not vice versa. Almost seems as if the transmitter isn’t properly linking both servos for forward flight? Like I said, works fine in Mode 1 but I prefer Mode 2. Any help would be greatly appreciated. And also – sorry if this has come up before, tried my best to search the forum but no luck. -T |
Which reminds me, today I flew my 9116 which I've been having some trouble with. I had a new vibration last week so I checked the balance bar and straightened it out. Eyeballing it, it seems like it's within 1% tolerance of straight. I still had vibration so I tried replacing the blades and checking all the screws. Seems like it's all good. I had a light breeze today after a week of wind & rain so I gave it a try in the field but it's acting very strange. Someone had suggested my OEM battery is fubar and I think that makes sense. Sometimes the controls seem unresponsive. I can try and spin and nothing seems to happen. I can push forward and nothing happens. Then it's like slowly it decides to push and away it goes. I'm going to try a battery I have here from an F45 and see what happens. Thanks all for the tips and suggestions an all the mod info you post. Us n00bs are learning a lot and realizing there's way more potential to these little beasts than we may have realized when we picked them up. |
| Thread Tools | |
| New Product the first double horse 2.4G and 4CH single blade helicopter 9116 | hkmtk | Beginner Training Area (Heli-Electric) | 32 | Yesterday 01:27 PM |
| Help! Heli Spins out when ascending (Z101, looks like the double horse) | Shlofter | Electric Heli Talk | 5 | Aug 16, 2012 01:59 AM |
| Discussion Double Horse 9097 24" Heli | Jake8131 | Electric Heli Talk | 8 | Mar 14, 2012 07:05 AM |
| Sold 9089 Double Horse Shuttle Electric Heli w/Video DVR | Senor Jack | Aircraft - Electric - Helis (FS/W) | 0 | Apr 10, 2011 08:15 PM |
