Old Jan 25, 2012, 08:55 PM
Doubletap is offline
Find More Posts by Doubletap
Si Vis Pacem Para Bellum!
Doubletap's Avatar
United States, CA, El Segundo
Joined Jul 2005
Originally Posted by flycracker View Post
Well, I got started with a real bang. Rather not say just how that happened, but I ordered a new fly bar. Have absolutely no idea how I'll get tie pin out and the new one in. All else seems to be ok. Is that going to be a major project requiring a whole new set of special tools?
Guess I now know why I avoided helis all these years.
Any and all comments are welcome.
Rich
If this is your very first helicopter, then I would recommend you get some simulator time, crashes cost nothing, that way you can learn basic control response and orientation. You don't need anything fancy or expensive, just the basics:
http://www.xheli.com/ek2-0905a-flightsimulator.html
Doubletap is offline Find More Posts by Doubletap
Old Jan 26, 2012, 09:45 AM
Thetis is offline
Find More Posts by Thetis
Always, against the wind
Thetis's Avatar
United States, IL
Joined Oct 2011
If you want a freeware Sim with your own PC joystick then:
http://www.marksfiles.net/HeliSim/
Thetis is offline Find More Posts by Thetis
Old Jan 26, 2012, 10:06 AM
flycracker is offline
Find More Posts by flycracker
Rich
flycracker's Avatar
USA, SC, Lexington
Joined Sep 2001
That's all good but I have a Mac and I love it. Just waiting for the rest of the software developers to catch up.
I have mucho years flying RC, just not Heli. I'll get it.
It really creates a major fuss when you accidentally smack the throttle to full while the heli is sitting on the ground. That sucker took off like a rocket.
Luckily there was a nice small fully leafed out tree to intercept.
Thanks guys,
Rich
flycracker is offline Find More Posts by flycracker
Old Jan 26, 2012, 02:39 PM
Kurt is online now
Find More Posts by Kurt
Upstanding Member
Kurt's Avatar
United States, TX, Houston
Joined Sep 2003
Originally Posted by Doubletap View Post
any heat sink for a 20mm motor will work or specifically for 180 brushed motors with the two flats, such as these:
http://www.slickzero.com/page/SRHP/P...rAccess/EA-016
I used those Maxx Prod sinks only because I already had them in my inventory as I use them for 20mm brushless EDF setups.
Does the photo below show 20mm heat sinks? Seems too large, or?
Kurt is online now Find More Posts by Kurt
Old Jan 26, 2012, 02:55 PM
Rich
flycracker's Avatar
USA, SC, Lexington
Joined Sep 2001
Sure looks like no contact tween the heat sink and motors thus no reason for the thermal paste. Good eye Kurt
Old Jan 26, 2012, 05:50 PM
Hellsiege is offline
Find More Posts by Hellsiege
Staying Frosty
Hellsiege's Avatar
United States, CO, Colorado Springs
Joined Feb 2008
Good call, didn't notice that when that photo was posted before, but your right no way that's going to do much for added cooling. Typically you'd see the heatsink up tight against the motor with thermal paste adding to how much heat it can dissipate like in this photo.
Hellsiege is offline Find More Posts by Hellsiege
Latest blog entry: Construction Projects - Updated
Old Jan 26, 2012, 06:35 PM
Kurt is online now
Upstanding Member
Kurt's Avatar
Joined Sep 2003
Yeah unless there's a tight fit between the motor and heat sink all you're doing is adding weight and cutting down on cooling airflow around the motor. Doing more harm than good.
Here's one I'm trying out on my 120SR.
Don't know where I even got this one, found it in a pile of my old RC Motorcycle parts.
With both the inner adapter ring and outer, finned heat sink it weighs in at a beefy 12g, but the scale fuselage I'm currently running requires some extra weight up front, and the Xtreme motor (20mm, maybe these will work with the X350?) will easily lift it so I'll at least use the 4g inner ring to add some extra heat-dissipating metal to the motor.
Old Jan 26, 2012, 11:39 PM
TimJohnson is offline
Find More Posts by TimJohnson
Split S
TimJohnson's Avatar
United States, CA, Rancho Santa Margarita
Joined Jul 2006
Just a heads up, I will have one of these flying at the Arizona Electric Festival this weekend.
TimJohnson is offline Find More Posts by TimJohnson
Old Jan 27, 2012, 06:32 AM
kodak_jack is offline
Find More Posts by kodak_jack
kodak_jack's Avatar
Hilton (Rochester), NY
Joined Mar 2008
The cure for the heat problem was the Aero-Nutz motors with large cooling vents in the can. Unfortunately, the clowns who make them are giving their vendors a hard time on price and quantity and nutzing the whole thing up. They were the #1 replacement for the Lama 4 and CX-2 heli's. Now, we're left with Xtreme motors or going brushless.
kodak_jack is offline Find More Posts by kodak_jack
Old Jan 27, 2012, 02:52 PM
Doubletap's Avatar
Joined Jul 2005
actually those pics were taken after the initial trial fit, but then one of the sinks was removed and trimmed to allow proper clearance and a very tight with the can. 180 brushed motors are 20mm diameter motors with flats on 2 sides, so these 20mm sinks are perfect fit, and make very tight contact on the rounded sides of the can, which is much better than the 180 sinks designed to only contact only some of the flat areas of the can. Also, the thermal compound is SOP when installing sinks especially for PC CPU heat sinks, it will ensure maximum thermal conductance between the heat source and the heat sink across minute imperfections/voids. Had this expensive silver based Arctic Silver compound left over from my PC consulting days, built many dozens of computers back in the day.
Old Feb 03, 2012, 03:58 PM
Thetis is offline
Thetis's Avatar
United States, IL
Joined Oct 2011
X-350 5B1 Military
Did you know that the X-350 5B1 is available?
http://www.casterracing.com/b2b/inde...roduct_id=1337
Old Feb 03, 2012, 05:14 PM
erdnuckel2 is offline
Find More Posts by erdnuckel2
erdnuckel2's Avatar
Joined Mar 2009
yeah!! and it is totally for free ... (or what else does a price of 0.00 in your cart mean ...)
Old Feb 03, 2012, 06:36 PM
Thetis is offline
Thetis's Avatar
United States, IL
Joined Oct 2011
Great for $0000000
Old Feb 03, 2012, 07:11 PM
Lafayette is offline
Find More Posts by Lafayette
'scuse me while I kiss the sky
Lafayette's Avatar
Joined Nov 2009
Has anyone flown with a gopro attached, and if yes how did it perform?
Stable, vibration / jello in the videos?
Does anyone have a link to gopro footage from that heli.
I have a tricopter, but was looking for something simple that could take a bit of wind and easy to fly, stable and maneuvrable.
Thank you very much!
Lafayette is offline Find More Posts by Lafayette
Old Feb 03, 2012, 07:53 PM
Thetis is offline
Thetis's Avatar
United States, IL
Joined Oct 2011
Message #77 he is working on a mount for a Gopro.
Discussion Best Coaxial for outside in 5 to 7mph wind? ghostware Coaxial Helicopters 4 Mar 23, 2010 04:56 PM
Question Any Micro capable of flying in 5-10 mph wind? CaptPJB Micro Ready-to-Fly 31 Jun 07, 2008 08:25 AM
Discussion HBFP-like heli capable of flight in wind?? stoddardvilla Micro Helis 9 Apr 19, 2007 10:56 AM
