Old Jan 10, 2012, 10:28 PM
Doubletap is offline
Find More Posts by Doubletap
Si Vis Pacem Para Bellum!
Doubletap's Avatar
United States, CA, El Segundo
Joined Jul 2005
Compatible 3S lipo for X350
Just received a compatible 3S Turnigy Nanotech from the Hobbyking USA warehouse, for $6.63:
http://www.hobbyking.com/hobbyking/s...dProduct=20417
this battery does come a different connector, included is the JST BEC connector, whereas the stock battery is equipped with a Deans Style T-Type connector, so you would need to either change connector or use an adapter.
It's almost an exact match overall dimensions, the Nanotech is rated for 25C Constant discharge and 40C Burst discharge so better than the stock pack, and approx. 1/3rd the cost.
Doubletap is offline Find More Posts by Doubletap
Old Jan 11, 2012, 10:42 AM
Thetis is offline
Find More Posts by Thetis
Always, against the wind
Thetis's Avatar
United States, IL
Joined Oct 2011
Great find but I need the adapter. I searched HK and I found this:
http://www.hobbyking.com/hobbyking/s...5Fadapter.html
Is this the adapter I need? Thanks
Thetis is offline Find More Posts by Thetis
Old Jan 11, 2012, 11:34 AM
Doubletap's Avatar
Joined Jul 2005
No, that won't work, you need a JST female and a T-Type female, if you know how to solder, it's easily made.Or, just change the connector to a Female Deans T-Type
Old Jan 11, 2012, 11:50 AM
Thetis is offline
Thetis's Avatar
United States, IL
Joined Oct 2011
I checked again HK but there is no such an adapter listed. Do you have by any chance an online address for such an adapter? Thanks
Old Jan 11, 2012, 11:56 AM
Doubletap's Avatar
Joined Jul 2005
Yup, right here:
http://www.slickzero.com/page/SRHP/PROD/Hdw/EA-008
Old Jan 11, 2012, 01:33 PM
kerwin50 is offline
Find More Posts by kerwin50
kerwin50's Avatar
winston mo
Joined Oct 2006
Is this a 4 channel set-up
kerwin50 is offline Find More Posts by kerwin50
Old Jan 11, 2012, 01:35 PM
Razors edge 29 is offline
Find More Posts by Razors edge 29
QuAd FaNaTiC
Razors edge 29's Avatar
Canada
Joined Aug 2009
These are 180 sized motors?
If so, anyone try the Xtreme 180 SE motors?
Razors edge 29 is offline Find More Posts by Razors edge 29
Old Jan 11, 2012, 02:25 PM
Hellsiege is offline
Find More Posts by Hellsiege
Staying Frosty
Hellsiege's Avatar
United States, CO, Colorado Springs
Joined Feb 2008
Wouldn't you need a male on the deans end to work with the HK lipos?
Hellsiege is offline Find More Posts by Hellsiege
Latest blog entry: Construction Projects - Updated
Old Jan 11, 2012, 05:48 PM
kodak_jack is offline
Find More Posts by kodak_jack
kodak_jack's Avatar
Hilton (Rochester), NY
Joined Mar 2008
Xtreme 180 motors have been so-so in other aplications. The favorite 180 motor was from Aero-Nutz, but they have had a bug up their backsides lately and don't want to supply their dealers at reasonable prices and availability. SO, we who fly Lama 4's and CX-2's are talking more and more about going brushless. In the case of Xtreme 380 motors on the beloved HBFP, the 4-in-1's were on the hairy edge with a stock motor in them let alone an aftemarket one. In some cases, the Xtreme 380 blew the 4-in-1's due to a little too much current draw. There can also be a problem when replacing the brushes on Xtreme motors. They don't always want to seat well.
kodak_jack is offline Find More Posts by kodak_jack
Old Jan 11, 2012, 10:13 PM
Doubletap's Avatar
Joined Jul 2005
No,Hobby King hasn't used the T Type connector for a long time now, there are 3 different types of connectors that HK supply with all of their lipos nowadays, and it's d epending on the capacity, very small lipos are equipped with the JST BEC type connector, medium size lipos are shpped with the yellow XT60 type connector, whereas very large lipos come with the big red connector with 4mm bullets. and the male T-Type is already on the speed control's leads as it should be, because the male exposed contacts are in danger of being shorted if was attached to the battery side.
Old Jan 12, 2012, 05:22 AM
QuAd FaNaTiC
Canada
Joined Aug 2009
That sucks
Old Jan 12, 2012, 12:41 PM
kodak_jack's Avatar
Joined Mar 2008
I use these on my 400 coax. They have various adapter cables too:
T-connectors $1.99 http://www.helipal.com/connector-t.html
One complaint on the real Dean's connectors is they're very difficult to pull apart. The edges are smooth and there's not much for your fingers to bite into.
Old Jan 12, 2012, 01:27 PM
QuAd FaNaTiC
Canada
Joined Aug 2009
I always found the 180's more powerful than the Aero's
My cx3 with the Xtreme 180's I had I would be was almost as powerful as a BL version; it had some jam; god I miss her
The wind (damn coax) took her away and way up over some 120 ft pines to never been seen again.
Just after I finished blinking it out; BUT it was a coax, and rudder control in wind was horrible - EVEN programmed with dx6i.
Old Jan 12, 2012, 07:41 PM
Balr14 is offline
Find More Posts by Balr14
Cranky old fart
Balr14's Avatar
Germantown, WI.
Joined Oct 2007
Extreme motors are "hot" rewinds; they like high rpms without a lot of drag. They need modified blades and a friction-free drive train to work well. Otherwise, something is going to burn. I'd like to be able to appreciate the interesting engineering that went into this heli, but it's selling at a price point where there are some pretty good single rotor helis available. You would have to be a real coax fan to appreciate it.
Balr14 is offline Find More Posts by Balr14
Old Jan 13, 2012, 05:42 PM
crashdumby is offline
Find More Posts by crashdumby
TREE TOP PILOT
crashdumby's Avatar
United States, IN, Greenfield
Joined Feb 2007
You got that right cool heli though would like to try it......CD
crashdumby is offline Find More Posts by crashdumby
Discussion Best Coaxial for outside in 5 to 7mph wind? ghostware Coaxial Helicopters 4 Mar 23, 2010 04:56 PM
Question Any Micro capable of flying in 5-10 mph wind? CaptPJB Micro Ready-to-Fly 31 Jun 07, 2008 08:25 AM
Discussion HBFP-like heli capable of flight in wind?? stoddardvilla Micro Helis 9 Apr 19, 2007 10:56 AM
