Old Jan 05, 2012, 08:11 PM
Doubletap is offline
Find More Posts by Doubletap
Si Vis Pacem Para Bellum!
Doubletap's Avatar
United States, CA, El Segundo
Joined Jul 2005
Originally Posted by Thetis View Post
I just came back from a very short outdoor flight. After a soft landing the heli did not lift off with full throttle. I took off the canopy and the red light inside was flashing which means recharge the battery. I did a full first charge before flying the red light was steady on the three green lights were flickering and not flashing so I thought was fully charged after 45 mins charge. After the short outdoor flight returning back home I took off the canopy and tried to charge again the battery. Upon pluging in the red light steady on but the green lights flickering again. Do I have to wait until the flickering goes away and flickering is normal? Is the battery fully charged and i am doing something wrong? Your input is appreciated.
Do you have a multimeter to check the actual voltage of the battery? A fully charged 3S lipo should read 12.60 V.
Doubletap is offline Find More Posts by Doubletap
Old Jan 05, 2012, 08:23 PM
Thetis is offline
Find More Posts by Thetis
Always, against the wind
Thetis's Avatar
United States, IL
Joined Oct 2011
No, but I will buy one tomorrow and check it out.
Thetis is offline Find More Posts by Thetis
Old Jan 06, 2012, 03:42 PM
Doubletap's Avatar
Joined Jul 2005
Here's a good review of the X350:
http://www.rcgroups.com/forums/showthread.php?t=1560657
Old Jan 06, 2012, 07:20 PM
Thetis is offline
Thetis's Avatar
United States, IL
Joined Oct 2011
Well, after the full charge it shows 11.6 Volts. Far below 12.6 Volts !! now what shall I do? This is the second charge with only 2 mins flight so far.
Old Jan 06, 2012, 09:00 PM
Doubletap's Avatar
Joined Jul 2005
A fully charged battery is indicated on the charger when all 3 cell LED's are solid green.
Old Jan 06, 2012, 09:08 PM
Thetis is offline
Thetis's Avatar
United States, IL
Joined Oct 2011
Yes, red light steady on and the three green lights on and flickering!! the tme was around fifty minutes. Is light flickering ok?
Old Jan 06, 2012, 09:13 PM
Doubletap's Avatar
Joined Jul 2005
no, the green lights must be solid,l flickering indicates that the cells are still taking additional charge.
Old Jan 06, 2012, 09:26 PM
Thetis is offline
Thetis's Avatar
United States, IL
Joined Oct 2011
Thank you, I will give it another charge after flying outdoors tomorrow and make sure the green lights are solid green before measuring the voltage.
Old Jan 06, 2012, 09:42 PM
Doubletap's Avatar
Joined Jul 2005
I would recommend that you fully charge the pack before you attempt to fly it again.
Old Jan 06, 2012, 09:46 PM
Thetis is offline
Thetis's Avatar
United States, IL
Joined Oct 2011
WILCO
Old Jan 06, 2012, 09:47 PM
Thetis is offline
Thetis's Avatar
United States, IL
Joined Oct 2011
Yes
Old Jan 06, 2012, 11:18 PM
Anti-G is offline
Find More Posts by Anti-G
Rotory-Winged Animal
The Banning Pass, CA
Joined Sep 2006
Motors cutting out still
Well, I've done what I could to try and alleviate the motors from cutting out in flight, crashed on me again, no damage luckily. Now it seems like the motors are not making power, they probably have around 25 to 30 flights on them by now. Could be that the motors are gonzo, or it may be the ESCs. The 180 motors sure did run extremely hot, and are overburdoned for the application IMO. Looks like I'm going to have to shell out some $$$ for the brushless kit to get a X350 that lasts for more than 20 to 30 seven minute flights.It's a bummer, since I really like this thing, kinda like the Slow Stick of 450 class helis.
Anti-G is offline Find More Posts by Anti-G
Old Jan 07, 2012, 12:27 AM
TimJohnson is offline
Find More Posts by TimJohnson
Split S
TimJohnson's Avatar
United States, CA, Rancho Santa Margarita
Joined Jul 2006
Sounds like may be you should contact hobby people customer service to have the heli looked at. You did not purchase this from hobby ki...... so you actually might get support from the hobby shop you purchased from.
TimJohnson is offline Find More Posts by TimJohnson
Old Jan 07, 2012, 01:18 AM
Anti-G is offline
Joined Sep 2006
RE issue
You've got a point with it ain't from HK. I guess it would be worth a shot to see if they can help.
Old Jan 07, 2012, 12:22 PM
Doubletap's Avatar
Joined Jul 2005
I'll be installing a couple of 20mm heat sinks with Arctic Silver thermal compound on those 180 main motors, gotta keep them cool to prolong their limited lifespan.
Discussion Best Coaxial for outside in 5 to 7mph wind? ghostware Coaxial Helicopters 4 Mar 23, 2010 04:56 PM
Question Any Micro capable of flying in 5-10 mph wind? CaptPJB Micro Ready-to-Fly 31 Jun 07, 2008 08:25 AM
Discussion HBFP-like heli capable of flight in wind?? stoddardvilla Micro Helis 9 Apr 19, 2007 10:56 AM
