Old Nov 15, 2011, 03:35 PM
Doubletap is offline
Find More Posts by Doubletap
Si Vis Pacem Para Bellum!
Doubletap's Avatar
United States, CA, El Segundo
Joined Jul 2005
New Product
Extreme Flyers X350 5A2, 5 CH Coaxial, flies in wind/Fast forward Flight capable.
Extreme Flyers 5A2 coaxial 5 CH, 2.4Ghz, brushless upgrade ready.
Specs:
Main Motor: 2x 180#
Tail Motor: N30
LiPo Battery: 11.1V 850mAh 22C LIPO
Balance Charger 15VDC, 2-3S LIPO cells, output: ≤ 1A charge
AC Adapter: 100-240VAC 50/60Hz, output 15V/1A
Transmitter: 2.4GHz 5ch GFSK
RC Distance ≤200 m
Rotor diameter: 476mm
Fuselage length 515mm
Height: 250mm
Weight: 427g
Servo: 2 x 8g
Receiver 5in1 2.4GHz GFSK integrated controller
Patent design of Anti-wind, perfect for out door flight;
Patent No.:PCT/C N2010/002183;
Durable main blades for your practic flight;
Users can fly inlow speed or high speed flight mode;
Smart "5 in 1 " mix controller works with head lock gyro, no need to
adjust any gain or proportional.
"5 in 1 " controller can directly upgrade to brushless motor systems;
5-channel radio system;
http://extreme-flyers.com/en/index.p.../helicopter/74
http://www.hobbypeople.net/index.php...ort-body.html#
http://extreme-flyers.com/en/index.php/helicopter
Extreme X350 Heli (0 min 56 sec)
Doubletap is offline Find More Posts by Doubletap
Old Nov 17, 2011, 01:28 PM
TimJohnson is offline
Find More Posts by TimJohnson
Split S
TimJohnson's Avatar
United States, CA, Rancho Santa Margarita
Joined Jul 2006
This looks like it could be fun! Hmm...Wonder if I can install a camera on it...LOL
TimJohnson is offline Find More Posts by TimJohnson
Old Nov 17, 2011, 08:52 PM
Stamp is offline
Find More Posts by Stamp
Visit My Blog
Stamp's Avatar
Outskirts of Chicago
Joined Nov 2008
I don't know about the whole outdoor thing.
Coaxes don't handle wind well. I'd like to see more outdoor video. Not just a few secs worth.
Jim
Stamp is offline Find More Posts by Stamp
Old Nov 17, 2011, 09:06 PM
Doubletap's Avatar
Joined Jul 2005
Watch this video of the X350 5B1 flying FFF outdoors, notice the flags blowing in the background, pretty good performance and authority in wind. It's obvious how it is done, the 5th channel mixes the pitch with the main motors throttle, so like cheapo 3 channel helis, the tail rotor will pitch the airframe so that the main rotors lift are vectored forward and throttle is applied for forward or rearward thrust,
http://extreme-flyers.com/en/index.p...x350-5b1-video
Old Nov 17, 2011, 09:25 PM
Stamp is offline
Visit My Blog
Stamp's Avatar
Joined Nov 2008
For the price no thanks.
A four channel does the same with a swash instead of a tail rotor.
Any fixed pitch heli will not handle much wind.
Jim
Old Nov 18, 2011, 11:31 AM
Split S
TimJohnson's Avatar
Joined Jul 2006
That is a pretty narrow view on things?
Old Nov 18, 2011, 11:37 AM
Stamp is offline
Visit My Blog
Stamp's Avatar
Joined Nov 2008
Just reality.
Old Nov 26, 2011, 05:40 PM
Sparky Paul is offline
Find More Posts by Sparky Paul
Ascended Master
Sparky Paul's Avatar
Palmdale, CA
Joined Oct 2000
Both of those have swash plates, not relying on only changing rotor speeds for control.
Sparky Paul is offline Find More Posts by Sparky Paul
Old Nov 26, 2011, 06:07 PM
Reluctant is offline
Find More Posts by Reluctant
Joined Nov 2011
Looks like that config would reduce or eliminate blade strike issues requiring one or two less mods. Still wondering if a BNF Eflite CX120 at 129 and 70.00 worth of parts would get me further than this 199.00 coax.
Reluctant is offline Find More Posts by Reluctant
Old Nov 26, 2011, 06:37 PM
Doubletap's Avatar
Joined Jul 2005
No, because you still have the same problem, cyclic alone with any helicopter doesn't provide enough percentage fwd/rwd thrust of the total lift from the main rotors, this includes single rotor fixed pitch and CP setups, to be able to fly effectively into wind, you must have adequate fwd/rwd thrust. the problem with conventional helicopter designs, the percentage of thrust vectored away from the primary lift thrust to just keep the VTOL aircraft aloft by cyclic pitch is just not enough to really yield adequate longitudinal velocity to overcome the prevailing head/tail wind speed with any authority.
Old Nov 27, 2011, 07:17 AM
kodak_jack is offline
Find More Posts by kodak_jack
kodak_jack's Avatar
Hilton (Rochester), NY
Joined Mar 2008
Subscribe. Interesting.
kodak_jack is offline Find More Posts by kodak_jack
Old Nov 27, 2011, 10:44 AM
Split S
TimJohnson's Avatar
Joined Jul 2006
In that video it did not look like the heli had any problem in the wind.
Old Nov 27, 2011, 11:58 AM
kodak_jack's Avatar
Joined Mar 2008
In the case of the RCINTHEBOX 450 size heli, the prop in the back is pushing the heli in FFF. In the case of this X350, the prop is pointing up, just like on 3 channel heli's. If it's pointing straight up and does not pivot, what exactly is that thing doing? That heli, in FFF, looks like any other heli with forward bias from shifted CG. Most of us aren't into 3 channel heli's, so, we don't know about the rear motor and prop.
Old Dec 07, 2011, 09:45 AM
Doubletap's Avatar
Joined Jul 2005
X-350 5A2 now in stock at Hobby People
It's on it's way, ordered today with Hobby People.net Free shipping promotion,
Free shipping is good from 12/7 thru 12/11
anxious to try it out, I am a half mile from the Pacific ocean, and rarely is there a breeze less then 5 mph anytime, typical wind speed here is 8-10 mph. X-350 is rated for 8 mph wind. It would be nice to have a large heli like this that can be flown in my fairly small yards in normal wind conditions. Will post my impressions, pics and flight report upon receipt.
Old Dec 07, 2011, 09:49 AM
Split S
TimJohnson's Avatar
Joined Jul 2006
Yep, can't wait to get mine.
Discussion Best Coaxial for outside in 5 to 7mph wind? ghostware Coaxial Helicopters 4 Mar 23, 2010 04:56 PM
Question Any Micro capable of flying in 5-10 mph wind? CaptPJB Micro Ready-to-Fly 31 Jun 07, 2008 08:25 AM
Discussion HBFP-like heli capable of flight in wind?? stoddardvilla Micro Helis 9 Apr 19, 2007 10:56 AM
