Old Jun 18, 2012, 11:55 PM
Widelec is offline
Find More Posts by Widelec
Simple is the best
Joined May 2011
Originally Posted by microrcfiend View Post
Hi, I have a bambu tricopter and got everything sorted to the point of tuning the giros. I had 6 or 7 arms and short hover before tweaking giros and trying again.
Now I get nothing apart from a quick flash of the kk board led when I try to arm it.
What are suggested settings for giros on this tri and how to get it to arm again or is it time to return a faulty board?
Vid uploaded if anyone can help
http://www.youtube.com/watch?v=0mlfw...ature=youtu.be
edit - If I do the esc calibration then all motors move together perfectly. When I turn off and restart with the pot back at 50% I get nothing.
I don't even get any esc beeps unless in the calibration mode. I still have throws at 100% no dual rates, no expo. Same settings from when I could arm it.
why the receiver led flashing?
is it bind with tx?
Widelec is offline Find More Posts by Widelec
Old Jun 19, 2012, 12:22 AM
Steveis is online now
Find More Posts by Steveis
AVR Dude
United Kingdom, England, Cnwll
Joined Jul 2011
@microrcfiend - What FC firmware are you using? Does it arm when all three pots are at 50%?
Also, as Widelec says, you should really get a solid LED on the receiver. Could be it needs binding again or it could be just because you power cycled the recevier but not the transmitter. Either way, it's not happy and we'd be happier to see a solid LED
Steveis is online now Find More Posts by Steveis
Old Jun 19, 2012, 07:46 PM
microrcfiend is online now
Find More Posts by microrcfiend
microrcfiend's Avatar
United Kingdom, England, Sheffield
Joined Jun 2012
Thanks Steve. I believe it is tricopter firmware 1.5. It came from the bambuucopter site couple months or so ago with this frame. I have not re flashed.
I don't know why the receiver flashes sometimes but it does not perform any different. I can add a servo to the no arming tricopter on any channel and it works. If I calibrate the escs, they all work in unison. I just tried again and even with a solid LED it does not arm like before. I have no problem making another short video for you guys as i'm kinda lost here, will do asap
I did reduce the pots too low possibly while setting the giros as I was getting oscillations whatever I set them at and didn't know which way was low. I think CCW is up but still not sure. They do not arm now when put back to 50% or as close to the centre as I can get them.
EDIT:
MOV00105.3gp (0 min 22 sec)
Pretty sure the flashing led is due to not cycling the tx when the rx is. If I turn em both off and back on it's solid every time. 2 of the same rx do the same thing so no problems there.
ESC calibration still works fine but arming does not seem t want to play. I never liked the arming sound but now I would love to hear it just once. I don't even get any ESC noises now. When should I hear those?
microrcfiend is online now Find More Posts by microrcfiend
Old Jun 20, 2012, 01:38 AM
AVR Dude
Joined Jul 2011
Double check your wiring between rx and fc board. I think that is where the problem is. Make sure the correct signals go to the correct fc pins.
Old Jun 20, 2012, 05:00 AM
Joined Jun 2012
Yup. All connections correct that I can see and has not been unplugged or changed since I could arm this ok - only the giros were moved and power cycled.
Aileron channel uses a normal 3 pin servo plug into the board. The throttle, elevator and rudder all just use the signal pin only and connect to signal pins on the kk board only. Do you need macro pics to see my wiring?
I have another kk board but I really want to use that for a small quad and have all the bits ready to go. Moving this board now the frame is all glued together is just gonna create a mess. Plus I don't think it's faulty as it calibrates the esc fine and everything spins up.
I also read of other people with the same problem now - once worked fine and nothing was changed apart from giros and then not able to arm. Convinced that's it's a simple fix but i'm too simple to fix it!
Old Jun 21, 2012, 02:33 AM
AVR Dude
Joined Jul 2011
Could you supply micro pictures. What receiver are you using? Is the transmitter on the right model memory and right mode?
Old Jun 21, 2012, 06:17 AM
Joined Jun 2012
Bambuu finally emailed me to tell me he cannot help with this problem and send it back if faulty but I still don't think it is faulty.
Perhaps a reflash would let me start at the beginning again?
Will add pics later to see if that sheds any light on the problem. Thanks for your input
Old Jun 21, 2012, 07:15 AM
Widelec is offline
Simple is the best
Joined May 2011
Dear @microrcfiend
I had Say by email
"I have'n got any expriment for KKmulticopter.
If is it board faulty, I can change the board.
Please confirm setting or board faulty vs."
if esc calibration is working and not arm
I think it's about rx tx setup.
Maybe reflash solves the problem, but as I said I'm not KKmulticopter expert
If there is anything else I can do
Regards
Old Jun 21, 2012, 12:27 PM
carl1864 is offline
Find More Posts by carl1864
Joined Jan 2010
So what is everyone using for Thread Locker, if anything?
I read the sticky at the beginning of the thread, and post that tested all the standard threadlockers, and found them to harm the plastic.
Anyone find anything good to use, or do you guys just not use any?
carl1864 is offline Find More Posts by carl1864
Old Jun 21, 2012, 03:01 PM
Joined Jun 2012
Steveis - I uploaded some pics that should help you see my wiring.
https://picasaweb.google.com/1012182...eat=directlink
One of the thin frame supports for the triangle underneath the tricopter has already broken, anyone else had issue with this or am I just lucky here?
It can be glued but I had no hard knocks at all yet.
The frame was useless unless glued together and now it's glued I can't return it. I just saw the new KK2 board and the standard giro controls, easy arming and self leveling. It's the same price from hobby king with buddy code as this kk board from bambuu.
Old Jun 21, 2012, 05:01 PM
AVR Dude
Joined Jul 2011
The only thing I can think of is that one of the wires is broken (red or orange on the individual wires). Can you test them with a multimeter?
Old Jun 21, 2012, 05:48 PM
Joined Jun 2012
Good idea, although no cigar. They all test fine with the multimeter.
This is beyond frustrating now, gonna shelf it for a few days and perhaps try a reflash when I hate looking at it less than now. Thanks anyway
I'd be interested if Widelec had any returns like this as I still think it's a calibration issue due to esc working perfectly in their calibration mode and previously having it hover with a few osscilations.
Old Jun 21, 2012, 05:56 PM
FlyinGizm0 is offline
Find More Posts by FlyinGizm0
FlyinGizm0
FlyinGizm0's Avatar
Austria, Ktn., Villach
Joined Mar 2012
deleted
FlyinGizm0 is offline Find More Posts by FlyinGizm0
Old Jun 22, 2012, 01:02 PM
Joined Jun 2012
Tried a a frsky and a frysky receiver and just the same, tried a new model with blank settings multiple times with no change.
What is anyone's preferred tricopter firmware and applicable giro settings for the crab tricopter using the kk board please? Gonna try a re flash before giving up and sending this back.
Edit.
A reflash got it responding again but after trying to get rid of the giro wobble and a few light drops to the floor from a couple of feet I see more breakage in the frame and where the pin for the pivot goes through it has worn. I have shimmed to get rid of the slop but how is this and unbreakable frame if it cannot take a few light drops on carpet?
Widelec
This the the broken unbreakable frame and no heavy use at all. Did I get a dud or am I expecting too much from an 'unbreakable frame' ?
https://picasaweb.google.com/lh/phot...eat=directlink
Old Jun 26, 2012, 02:23 AM
Widelec is offline
Simple is the best
Joined May 2011
I can send to you replacement parts.
which arm? back or front (right left)
Discussion BambuCopter *BlueBird QuadCopter, BlueBird TriCopter* SmallQuad 450 AirFrames Widelec Multirotor Talk 343 May 25, 2013 03:00 PM
Discussion HK has a new mini quad frame Pintac Multirotor Talk 20 Sep 28, 2011 10:04 AM
Sold Quad frame for sale!!! previously listed. as full quad. tc3wins Aircraft - Electric - Multirotor (FS/W) 3 Aug 25, 2011 08:56 AM
Sold Mini Quad with G10 frame RXR tc3wins Aircraft - Electric - Multirotor (FS/W) 4 Jul 21, 2011 11:05 PM
