Old Jun 06, 2012, 04:10 PM
WiseDuck is offline
Find More Posts by WiseDuck
Mmmmmmm!
WiseDuck's Avatar
Kingdom of Sweden, Dalarna County, Sater
Joined Oct 2011
The instructions online for all the Bambucopter frames say that epoxy should be used.
As soon as you epoxy the parts together it will be nice and rigid. I would use hot glue instead though, so you can take it apart if anything breaks in a crash. And yes I had some issues assembling the tail too, I thought I would break it! But it eventually snapped into place.
WiseDuck is offline Find More Posts by WiseDuck
Old Jun 06, 2012, 04:11 PM
Freakazoid is offline
Find More Posts by Freakazoid
Freakazoid's Avatar
Roosendaal, Netherlands
Joined Dec 2004
Haha oh yes, I was working from the bottom up on my Y6 and had the little nuts right at the bottom.
It took me a while to figure out you had to work towards the middle from both sides, quite smart really.
With the tricopter im not so sure to be honest, the triangle in the middle has a bit of a swashplate tilting action going on this way.
And im not sure if this would go away with a few tierips, since theid only hold the arms tight, not the base.
Maybe the giant paperclips hold the secret, since there happens to be 3 of them?
Hotglue wont melt polycarb? I thought it was near the same melting point?
Would make the frame a little ugly though I guess.
Freakazoid is offline Find More Posts by Freakazoid
Old Jun 06, 2012, 04:14 PM
WiseDuck is offline
Mmmmmmm!
WiseDuck's Avatar
Joined Oct 2011
The paperclips are for making your own yaw mechanism. Don't miss this: The triangular top plate has one side which is slightly thinner. This should point forward if you want the tri to look nice and symmetrical. I missed this and can't turn this part now that's it's been glued into place, book!
Old Jun 06, 2012, 04:17 PM
Freakazoid's Avatar
Joined Dec 2004
Haha, OCD gland overdrive right there!
I also noticed this after putting it on the tri and it sent my symmetry madness haywire,
so I picked it back out and put it in right. luckily no glue was used yet at this point.
And theres a way of making a yaw mechanism that takes up three entire paperclips?
Or has Erman so little confidence in me that he predicted some major frekups on my part?
Old Jun 07, 2012, 01:04 AM
Kris... is offline
Find More Posts by Kris...
Registered Addict
Kris...'s Avatar
United Kingdom, Stoke-on-Trent
Joined Jul 2010
Is Hot glue safe to use then or not ?
Kris... is offline Find More Posts by Kris...
Old Jun 07, 2012, 01:10 AM
WiseDuck is offline
Mmmmmmm!
WiseDuck's Avatar
Joined Oct 2011
Try it on one of the spare pieces or something first. I don't see why it shouldn't work.
Old Jun 07, 2012, 01:16 AM
Kris... is offline
Registered Addict
Kris...'s Avatar
Joined Jul 2010
What spare pieces
Old Jun 07, 2012, 06:38 AM
Freakazoid's Avatar
Joined Dec 2004
I got a whole buncha spare tail bits with my tricopter.
Old Jun 16, 2012, 05:31 AM
alphaquad is offline
Find More Posts by alphaquad
Joined May 2012
Just received my miniquad!
Description:
Showing the rough setup of my first quad. I notice the esc wire (to motor side) is very long, did you guys cut it to be shorter?
Also, I order the 3blade prop and realize one thing: the prop saver seems only to be used only for 2 blade? Just my observation based on the symmetry look, is prop adapter a better idea?
alphaquad is offline Find More Posts by alphaquad
Old Jun 16, 2012, 07:56 AM
Widelec is offline
Find More Posts by Widelec
Simple is the best
Joined May 2011
Attachment 4941844
I'm folding long cable bottom of the ESC.
Don't forget protective layer onthe surface
Widelec is offline Find More Posts by Widelec
Old Jun 16, 2012, 08:15 AM
skellator is offline
Find More Posts by skellator
9W2DLR
Malaysia, Pahang, Temerloh
Joined Nov 2011
Attachment 4941844
i solder my motor wire directly to esc
skellator is offline Find More Posts by skellator
Old Jun 16, 2012, 01:20 PM
leprud is offline
Find More Posts by leprud
Trying to learn.
leprud's Avatar
Moscow, Russia
Joined Jun 2010
Me too. Great weight saver
leprud is offline Find More Posts by leprud
Old Jun 17, 2012, 01:17 AM
Joined May 2012
Okay, you must have hidden them well .
Thanks, guess I will solder them as well.
Old Jun 18, 2012, 04:08 PM
WiseDuck is offline
Mmmmmmm!
WiseDuck's Avatar
Joined Oct 2011
So, I might get a Y6 before the end of the summer/fall. Proper landing gear is a must. Does anyone know where I can find landing gear that works with this little thing?
Old Jun 18, 2012, 05:57 PM
microrcfiend is offline
Find More Posts by microrcfiend
microrcfiend's Avatar
United Kingdom, England, Sheffield
Joined Jun 2012
Hi, I have a bambu tricopter and got everything sorted to the point of tuning the giros. I had 6 or 7 arms and short hover before tweaking giros and trying again.
Now I get nothing apart from a quick flash of the kk board led when I try to arm it.
What are suggested settings for giros on this tri and how to get it to arm again or is it time to return a faulty board?
Vid uploaded if anyone can help
FAULTY KK BOARD? NO LONGER ARMS (0 min 46 sec)
edit - If I do the esc calibration then all motors move together perfectly. When I turn off and restart with the pot back at 50% I get nothing.
I don't even get any esc beeps unless in the calibration mode. I still have throws at 100% no dual rates, no expo. Same settings from when I could arm it.
microrcfiend is offline Find More Posts by microrcfiend
Discussion BambuCopter *BlueBird QuadCopter, BlueBird TriCopter* SmallQuad 450 AirFrames Widelec Multirotor Talk 343 May 25, 2013 03:00 PM
Discussion HK has a new mini quad frame Pintac Multirotor Talk 20 Sep 28, 2011 10:04 AM
Sold Quad frame for sale!!! previously listed. as full quad. tc3wins Aircraft - Electric - Multirotor (FS/W) 3 Aug 25, 2011 08:56 AM
Sold Mini Quad with G10 frame RXR tc3wins Aircraft - Electric - Multirotor (FS/W) 4 Jul 21, 2011 11:05 PM
